POV-Ray : Newsgroups : povray.binaries.images : Denoising POV-Ray images in Blender Server Time
5 Apr 2026 01:53:16 EDT (-0400)
  Denoising POV-Ray images in Blender (Message 17 to 26 of 51)
Subject: Re: Denoising POV-Ray images in Blender
Date: 17 Jan 2023 21:55:00
Message: <web.63c75ee013ac33282eadabda6e066e29@news.povray.org>
"Samuel B." <stb### [at] hotmailcom> wrote:
> A proximity pattern test. This type of proximity method can be quite noisy at
> times, depending on the number of samples used. This object got 12 samples and
> the scene took 35 seconds to render using low radiosity and focal blur settings.
This is the best example of the denoiser technique that you've posted so far,
IMO. I am amazed that it can discern true noise from your applied ground pattern
that looks *almost like* noise. The foreground detail looks nice and sharp.
It would be interesting to see this same scene denoised but without the original
focal blur-- to see at what point (if any!) in the receding distance the
denoiser might mistake the smaller and smaller actual ground pattern detail for
what it 'perceives' as noise. To see if the denoiser tries to blur it there when
it should not(?)
BTW: A few days ago, I downloaded your 2013 file "ToVolume: Object-To-Volume
Conversion and Rendering Process". It also has an interesting and much more
complex 'proximity' file included. I'm sorry to admit that I haven't yet played
around with your amazing proximity pattern :-( I'm still going through that file
to try and understand its workings; much of it is beyond my brain-power, ha.
Date: 17 Jan 2023 22:30:00
Message: <web.63c766f113ac33282eadabda6e066e29@news.povray.org>
> focal blur--
Oops, what I meant to say was, *with* focal blur (and the inherent noise of low
blur samples) but so that the depth-of-field is much wider and not soft-focus
(if that makes sense.) In other words, noisy but not actually blurry-looking.
I'm wondering if the denoiser can distinguish the ground pattern in the
foreground from the same un-blurred smaller pattern in the receding distance.
Date: 20 Jan 2023 18:00:00
Message: <web.63cb1c0d13ac3328e167b36c6e741498@news.povray.org>
> > A proximity pattern test. (...)
> it should not(?)
Hi Kenneth,
The denoiser was able to preserve the ground bump largely thanks to the normal
pass I included. It also helps that the normal and albedo passes can take more
camera blur samples than the final pass, since they are faster to render.
Regarding what it would look like with no obvious focal blur, I'm /guessing/
that the denoiser would smooth out everything under a certain size and color
threshold.
Re: ToVolume. I can't remember which type of proximity technique I used for
that. And I would probably be a bit lost myself, opening up that file after all
these years... that tends to happen with old projects ;)
Sam
Date: 21 Jan 2023 02:34:26
Message: <63cb9582$1@news.povray.org>
Op 20/01/2023 om 23:56 schreef Samuel B.:
>> it should not(?)
> Hi Kenneth,
> threshold.
> Sam
There are/were also your "fastProx" and "nestProx" includes for doing
proximity patterns. It has been a while since I last used them. They
tended to be /superseded/ by Edouad Poor's "df3prox-0.95" utility in my
(slight) personal choice/preference ;-)
However, they are a notable part of my large collection of POV-Ray
utilities created by the users community. Good opportunity to say a warm
Thank You.
Date: 30 Jan 2023 16:11:50
Message: <63d83296$1@news.povray.org>
Il 14/01/2023 01:50, Samuel B. ha scritto:
Thank you, Sam! A different approach can be a stimulus to revisit old
projects (and I have many, lost in time...).
Btw, a nice and relaxing test image.
Paolo
Date: 2 Feb 2023 19:10:00
Message: <web.63dc4fa213ac3328e167b36c6e741498@news.povray.org>
> > that. (...)
Hey, whatever gets the job done :D
> Thank You.
> Thomas
No problem! It's cool that you are keeping a collection going.
I do wish it was easier to search for old things, though. It seems like all the
search engines only keep a partial index of the newsgroups.
Date: 3 Feb 2023 02:17:13
Message: <63dcb4f9$1@news.povray.org>
Op 03/02/2023 om 01:04 schreef Samuel B.:
It is miscellaneous/monstrous thing ;-)  jr encourages me to make it
better accessible, but /that/ is a hell of a job, and RL is increasingly
interfering.... :-/
Possibly the major crash POV-Ray experienced some time ago destroyed
part of the index too? However, I agree with you: items are often
difficult/impossible to find.
Date: 3 Feb 2023 06:20:00
Message: <web.63dced4113ac33281f9dae3025979125@news.povray.org>
I think there are ways to get search engines to recrawl/reindex a site over time
- might be worth looking into.
Date: 3 Feb 2023 08:27:47
Message: <63dd0bd3$1@news.povray.org>
>> like all the
No, the searches skipped results even before the crash.  I can't count
the number of times I've had to hunt down an old post manually because
the search engine didn't find it.
Date: 3 Feb 2023 13:45:00
Message: <web.63dd555f13ac33281f9dae3025979125@news.povray.org>
There are instructions for "building your own search engine" - and i would
imagine this would be pretty manageable given it could be restricted to just
this site.
No idea who could set up a rudimentary test of this, but at the very least it
would crawl and index the entire site.
I think it would be really great to bea able to scroll through all of the zip,
inc, mcr, and other such files in a "digest" which was just the search
results...
Also, you could search by username, which would be particularly useful when
hunting down a file when you know who the author was.
