On 05/10/2021 12:48 am, Bill Pragnell wrote:
> Thomas de Groot <tho### [at] degrootorg> wrote:
>> You might want to
>> try using different sized stones instead of bricks for a change, or in
>> addition to bricks. And maybe make the arches and window frames out of
>> stone instead of bricks. They would react differently to decay.
> Filling space with irregularly-shaped bricks or stones is a non-trivial problem,
> one I've often thought about but never seriously attempted! However, discrete
> layers of different brick sizes would be feasible without effort (if
> architecturally realistic!).
> Arches and window frames made more carefully from larger custom components would
> be my next step I think. More open structures like cloisters or church-style
> windows would look great as ruins.
> Bill
Looking good.
For blocks of different sizes it might be worth looking at Block Wall
Macros by Chris B.
<http://lib.povray.org/searchcollection/download.php?objectName=blockwall&contributorTag=chrisb&version=1.1.1>
Looks like the site is down just now :(
m@
Download 'blockwall.jpg' (53 KB)
Preview of image 'blockwall.jpg'
> Macros by Chris B.
The Object Collection has not been rebuilt since the server crash in
March. The BlockWall files are available at:
https://github.com/LeForgeron/PovContributions/tree/master/blockwall/chrisb%201.1.1
At this time, I do not know how to download the whole directory at once.
>> Macros by Chris B.
It's github: clone the whole repository and voilà.
Ok, there might be some git magic to only get some portion of the
repository and only at the latest revision, but this is left as an
exercise for the reader.
"Samuel B." <stb### [at] hotmailcom> wrote:
> Looks good, Bill! The parse time must have been pretty high, but maybe not.
Thanks! Not excessive really, parsed in about a minute, rendered in about 15
(UberPOV on a 2012 Mac).
The bricks are rounded-box meshes, an instance per block/turret, and of course
half of them are simply omitted by the exclusion test, so it's not a
memory-intensive scene either. Yet...
Bill
"Bald Eagle" <cre### [at] netscapenet> wrote:
> I think that trying to fit existing stones into a wall is the REALLY hard
> part, but I think there has to be:
> 1. a way to make a pseudo-mathematical texture like crackle/Voronoi
This would seem to be the best way to go, but I'm no mathematician. Some day
I'll spend some time reading up the matter!
> 2. a way to generate pieces to fit into a given empty space.
> Maybe a way to loop through y values and combine that with a crossing number
> algorithm to find the edges of the already filled space as a place to start
> making a new block.
Actually I did once play with a similar concept - with spheres, in 2d, and it
wasn't easy, and only partially successful. However your suggestion is a little
different, perhaps I should revisit it.
Bill
> Macros by Chris B.
Thanks for the pointer, I wasn't aware of this. I'll have a look!
Bill
Looks pretty good from a distance, would be nicer if the collapsed parts had
eroded edges but I imagine that would be pretty tricky to do. This looks more
like it has just been knocked down, maybe next step should be modelling a
catapult and adding a pile of rubble ;-)
Sean
