POV-Ray : Newsgroups : povray.binaries.images : Sci-Fi Scene Assets Server Time
30 Jun 2024 23:53:13 EDT (-0400)
  Sci-Fi Scene Assets (Message 58 to 67 of 97)
Subject: Re: Sci-Fi Scene Assets
Date: 7 Mar 2021 13:35:00
Message: <web.60451bf2a906d8e387570eab0@news.povray.org>
> This is excellent! I never went as far as this to tell the truth. Not
> inspired enough probably :-)
> However, this is an excellent procedure which I shall note carefully
> down for future use. My HowTo's are expanding...
Thanks very much, Thomas :)
> Another way using the sdl, would be through pigment_pattern use I guess.
> I know! I "discovered" those recently and now I am proselytising in my
> naive enthusiasm. ;-)
Yes, pigment patterns are awesome, in some way or another I generally use
pigment patterns in every image. Actually, I remember suggesting to you that you
use a pigment pattern to break up the paver reflections in your image "Paris by
Night - 1951".
I tried to search for that but the "this-site-only" style Google search isn't
working here right now for some reason (it used to, and not long ago). I looked
backward through all threads to almost exactly ten years ago and found these
http://news.povray.org/web.4d8e3a38d16f200e94d713cc0%40news.povray.org
http://news.povray.org/web.4d921a8dd16f200e94d713cc0%40news.povray.org
Date: 8 Mar 2021 02:31:50
Message: <6045d2e6@news.povray.org>
Op 07/03/2021 om 19:31 schreef Robert McGregor:
> Night - 1951".
> posts:
Ah, yes! I do not remember if I used that after all. I shall check, out
of curiosity. Thanks for the reminder!
Date: 8 Mar 2021 03:49:33
Message: <6045e51d$1@news.povray.org>
Robert McGregor wrote on 04/03/2021 17:53:
> Here's an update on my spaceship model and what's probably close to final
> texturing. I've played around with some outer space lighting (i.e., dark) in
> various test scenes and what I have here works pretty well in the setups I've
> tried so far.
#declare luxury_greeble_mode_on=1
A very nice work!
Paolo
Date: 8 Mar 2021 06:50:00
Message: <web.60460e9da906d8e31f9dae300@news.povray.org>
What was the whole "oval shield" thing about?
Date: 8 Mar 2021 07:38:02
Message: <60461aaa@news.povray.org>
Op 8-3-2021 om 12:46 schreef Bald Eagle:
In France, you will see this (attached image) at the offices of notaries
in particular. On thephotographof 1951, there is one.
Download 'index.jpg' (45 KB)
Preview of image 'index.jpg'
Date: 23 Mar 2021 14:13:44
Message: <605a2fd8$1@news.povray.org>
On 3/7/21 11:18 AM, Robert McGregor wrote:
> Yes, it means swapped diagonally:
> upper left and lower right swap places
> lower left and upper right swap places
I figured it out - but it is NOT like scale <-1, -1, 1>.
the quadrants are swapped by _translating them, and then the middle
cross gets filled in to make the empty edges all nice and pretty.
I got the idea that this could be done using pigment {function{}}, and
it actually _works_   :O
I have it half worked out, it's slow, and I still need to layer the 2
textures to create the final infinitely repeatable tile, but hopefully I
will finish that up after I get some other stuff out of the way.
Date: 6 Apr 2021 18:00:00
Message: <web.606cd909a906d8e387570eabd4644d08@news.povray.org>
I started modeling some new assets for an Earthlike planet-side scene I'm
working on. This is a "beam tower" that will be instanced several times, made up
of a few fairly simple UV mapped meshes. It uses cylindrical media with some
turbulence for the beam and lower glowy bits, and a spherical media at the top
of the spire for a flare effect where the beam emits upward.
And no, I'm not sure what the beam does exactly, but that's part of the beauty
of sci fi - it doesn't really have to make sense to us because we wouldn't
understand the tech anyway (but I suppose the guys that work inside these
buildings would know what it does...)
Download 'beamtowerwipsnomats.jpg' (149 KB)
Preview of image 'beamtowerwipsnomats.jpg'
Date: 6 Apr 2021 18:05:00
Message: <web.606cda58a906d8e387570eabd4644d08@news.povray.org>
Here are a couple of test renders of the beam tower with materials in the
context of my basic planetscape.
Download 'beamtowerwipswithmats.jpg' (542 KB)
Preview of image 'beamtowerwipswithmats.jpg'
Date: 6 Apr 2021 18:25:00
Message: <web.606cde92a906d8e387570eabd4644d08@news.povray.org>
Yes, that's it exactly :)
Of course all seamless tiles are still noticeable as being tiled when they
repeat too many times, but I usually use a pigment pattern to break that up by
using different scales and rotations within the map (sort of what I'm doing for
the ground plane in the beam tower material test renders, using a bozo pattern,
but with two different image maps).
Date: 7 Apr 2021 07:15:00
Message: <web.606d93f5a906d8e36adeaecb3f378f2@news.povray.org>
Looks terrific on outdoor daylight!
