POV-Ray : Newsgroups : povray.binaries.images : Sci-Fi Scene Assets Server Time
13 Mar 2026 01:14:20 EDT (-0400)
  Sci-Fi Scene Assets (Message 51 to 60 of 97)
Subject: Re: Sci-Fi Scene Assets
Date: 5 Mar 2021 12:40:01
Message: <web.60426c72a906d8e3d98418910@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> wrote:
> I don't think I've ever tried posting a video here before but I'm attaching a
> short MP4 clip of the animated engine media, hopefully it works.
Your final ship is really gorgeous, and the animation of the engine 'ion
exhaust' looks great! It's a nice and sophisticated use of media. Btw, thanks
for the description of your ship's surface texture; I had originally thought
that you had used one of POV-ray's newer 'pavement' patterns (perhaps that is
part of the mix), but your averaging(?) of simple box and rectangle
shapes/images makes perfect sense. I look forward to experimenting with that
technique.
Your work has really paid off! It's inspiring.
[As is usual with videos uploaded here-- at least through the newsgroups' web
portal-- the downloaded animation doesn't play in Windows Media Player, even
though it should. So I've learned to use a different media player app to play
it. I don't think the problem is with the added  .mp4  suffix here, whether left
as-is or removed; it seems that the upload/download process adds 'something' to
the file, or makes it different somehow. On my own Win 7 computer, I can play my
own animations in WMP; but when I upload them here, then download them, they
don't play. Weird.]
Date: 6 Mar 2021 17:35:02
Message: <web.604401dda906d8e387570eab0@news.povray.org>
> technique.
Thanks Ken! Here's a quick scene file example that creates some random
rectangles to use as a base greeble texture (for bump and reflection mapping,
and as a base pigment layer):
// Command-line: +w1024 +h1024 +fn16 +a0.1
#include "rand.inc"
#default { finish { ambient 1 diffuse 0 } }
#declare R = seed(1);
   orthographic
   location <0, 0, -1>
   look_at <0, 0, 0>
background { rgb 0.5 }
#declare Box = box { -0.5, 0.5 hollow scale z*0.01 }
#declare Border = 0.005;
#declare Max = 500;
#for (i, 1, Max)
   #local Scale = <RRand(0.05, 0.25, R)*(Max-i/Max)/Max, RRand(0.05, 0.25,
R)*(Max-i/Max)/Max, 0.005>/2;
   union {
      object { Box
         scale <Scale.x+Border, Scale.y+Border, 1>
         pigment { rgb RRand(0, 0.1, R) }
      object { Box
         scale Scale
         pigment { rgb RRand(0.1, 0.9, R) }
         translate -z*0.01
      translate <RRand(-0.5, 0.5, R), RRand(-0.5, 0.5, R), 2-0.01*i>
The attached image shows my process for taking the raw render resulting from
this code and making various greeble image maps from it. (A) is the image as
rendered, (B) is that same image with quadrants offset diagonally (this is
important for tiling). The others are composites of (B) layered over (A) using
the different blending modes Darker Color, Multiply and Overlay. This is easily
done in GIMP or PhotoShop, or even directly in POV-SDL using averaged pigment
functions for the die-hard purists out there (hey, I still do it). The cool
thing about this method is that the resulting images tile seamlessy (see the
example in the bottom right).
Thanks again, I really appreciate that. I like to think we all inspire each
other here. I've seen some really interesting discussion and code from you and
Thomas and Bald Eagle in this thread alone, and that's resulted in other new
threads that further expand on and propagate the inspiration. Go Team!
Cheers,
Rob
Download 'creatinggreeblesimagemapsexample.jpg' (1153 KB)
Preview of image 'creatinggreeblesimagemapsexample.jpg'
Date: 7 Mar 2021 02:25:35
Message: <60447fef$1@news.povray.org>
Op 06/03/2021 om 23:32 schreef Robert McGregor:
[snip]
This is excellent! I never went as far as this to tell the truth. Not
inspired enough probably :-)
However, this is an excellent procedure which I shall note carefully
down for future use. My HowTo's are expanding...
Another way using the sdl, would be through pigment_pattern use I guess.
I know! I "discovered" those recently and now I am proselytising in my
naive enthusiasm. ;-)
> Cheers,
> Rob
The great thing about these ng's is the mutual stimulation and
inspiration. I have not experienced it to this high degree anywhere else.
Date: 7 Mar 2021 09:10:06
Message: <web.6044de30a906d8e31f9dae300@news.povray.org>
> don't play. Weird.]
I hated WMP and have only really been using VLC for years.
It may not be "the best" player - but it will open and play damned near
anything.
Date: 7 Mar 2021 11:05:00
Message: <web.6044f8e7a906d8e31f9dae300@news.povray.org>
And this is the part where I always get lost with the tiling thing.
I recall seeing a good tutorial on how to "do this with any image" back in like
1995, but when I searched recently, all I got was very unhelpful, overly
complicated methods.
Does quadrants "offset" diagonally mean _swapped_ diagonally?
Like scale <-1, -1, 1> ?
Date: 7 Mar 2021 11:20:01
Message: <web.6044fceaa906d8e387570eab0@news.povray.org>
Yes, it means swapped diagonally:
upper left and lower right swap places
lower left and upper right swap places
Date: 7 Mar 2021 12:35:00
Message: <web.60450e1ba906d8e36adeaecb0@news.povray.org>
It's even better animated! and nicely stylized with a stop motion cartoony feel.
Date: 7 Mar 2021 13:35:00
Message: <web.60451bf2a906d8e387570eab0@news.povray.org>
Thanks very much, Thomas :)
Yes, pigment patterns are awesome, in some way or another I generally use
pigment patterns in every image. Actually, I remember suggesting to you that you
use a pigment pattern to break up the paver reflections in your image "Paris by
Night - 1951".
I tried to search for that but the "this-site-only" style Google search isn't
working here right now for some reason (it used to, and not long ago). I looked
backward through all threads to almost exactly ten years ago and found these
http://news.povray.org/web.4d8e3a38d16f200e94d713cc0%40news.povray.org
http://news.povray.org/web.4d921a8dd16f200e94d713cc0%40news.povray.org
Date: 8 Mar 2021 02:31:50
Message: <6045d2e6@news.povray.org>
Op 07/03/2021 om 19:31 schreef Robert McGregor:
> Night - 1951".
> posts:
Ah, yes! I do not remember if I used that after all. I shall check, out
of curiosity. Thanks for the reminder!
Date: 8 Mar 2021 03:49:33
Message: <6045e51d$1@news.povray.org>
Robert McGregor wrote on 04/03/2021 17:53:
> Here's an update on my spaceship model and what's probably close to final
> texturing. I've played around with some outer space lighting (i.e., dark) in
> various test scenes and what I have here works pretty well in the setups I've
> tried so far.
#declare luxury_greeble_mode_on=1
A very nice work!
Paolo
