POV-Ray : Newsgroups : povray.binaries.images : WIP: We check the union Blender - Povray Server Time
25 Mar 2026 03:29:22 EDT (-0400)
  WIP: We check the union Blender - Povray (Message 12 to 21 of 51)
Subject: Re: WIP: We check the union Blender - Povray
Date: 29 May 2015 16:10:00
Message: <web.5568c758b92297fd7a3e03fe0@news.povray.org>
Sorry!
Download 'pattern_modern1.jpg' (327 KB)
Preview of image 'pattern_modern1.jpg'
Date: 29 May 2015 16:50:01
Message: <web.5568d04bb92297fd7a3e03fe0@news.povray.org>
Napkin
Download 'pattern_modern2.jpg' (218 KB)
Preview of image 'pattern_modern2.jpg'
Date: 20 Jun 2015 17:20:00
Message: <web.5585d821b92297fd7a3e03fe0@news.povray.org>
I added a glass to a curtain.
Glass - lathe(bezier_spline).
Photons count - 20 000.
Download 'wip.jpg' (149 KB)
Preview of image 'wip.jpg'
Date: 21 Jun 2015 03:04:22
Message: <558661f6@news.povray.org>
I am somewhat surprised by the strong, black shadow, but as the glass is
rather thick-walled that must be correct I suppose.
Date: 21 Jun 2015 06:25:06
Message: <web.55868fcfb92297fd7a3e03fe0@news.povray.org>
> Thomas
Yes, glass thick.
And the environment isn't present, walls very dark.
Lighting needs to be adjusted, but it in the final:
area_light takes a lot of time for a render.
Date: 21 Jun 2015 06:56:38
Message: <55869866$1@news.povray.org>
>> Thomas
> Yes, glass thick.
True indeed, but the glass is nice. It reminds me somehow of some
electrical isolators I used as paper weights in the past.
Date: 21 Jun 2015 08:40:01
Message: <web.5586af8fb92297fd7a3e03fe0@news.povray.org>
> > Yes, glass thick.
> Thomas
I made a mirror of a prism.
I applied UV-mapping to lathe.
Download 'wip1.jpg' (42 KB)
Preview of image 'wip1.jpg'
Date: 21 Jun 2015 10:02:56
Message: <5586c410$1@news.povray.org>
>>> Yes, glass thick.
>> Thomas
The uv_mapping gives an interesting effect. You can also achieve this
with a gradient texture along the y-axis.
Date: 21 Jun 2015 11:05:03
Message: <web.5586d1bdb92297fd7a3e03fe0@news.povray.org>
> Thomas
Thanks!
Problem:
mesh2 glass vase
Download 'scene.jpg' (69 KB)
Preview of image 'scene.jpg'
Date: 21 Jun 2015 13:58:19
Message: <5586fb3b@news.povray.org>
>> Thomas
> Thanks!
> Problem:
> mesh2 glass vase
You should use spacing instead of count for your photons.
That way, you set the density of the photons coverage and don't spread
your photons between the various objects and light_source.
Also, if one object seems to receive enough photons, but the other
don't, you can use target float.
The float value is to be used as a multiplicator for the spacing.
target 0.5 will reduce the effective spacing for that object by half,
for 4 times as many photons.
If you want the photons to be reflected by the mirror, using target 2 or
3 will reduce the number of photons dirrected at the mirror. As it's a
flat surface, it don't need as much coverage as the glasses.
