POV-Ray : Newsgroups : povray.binaries.images : Untitled S.F. [W.I.P] take 2 Server Time
6 Mar 2026 01:56:36 EST (-0500)
  Untitled S.F. [W.I.P] take 2 (Message 1 to 10 of 18)
Subject: Untitled S.F. [W.I.P] take 2
Date: 26 May 2011 18:25:01
Message: <web.4dded27b2653feab9c4fb0ad0@news.povray.org>
Partially solved my atmosphere problem... next part is detailing the gate.
I'm also thinking about adding a moon.
Render time: ~ 14h 8m
Comments, suggestions?
A.D.B.
Download 'workshop.png' (263 KB)
Preview of image 'workshop.png'
Subject: Re: Untitled S.F. [W.I.P] take 2
Date: 26 May 2011 20:39:32
Message: <4ddef2c4$1@news.povray.org>
> A.D.B.
Going on nicely.
A suggestion: Comment out the planet while working on the gate. It will
be much faster to test.
Date: 27 May 2011 13:53:43
Message: <4ddfe527$1@news.povray.org>
Anthony D. Baye escreveu:
completely unacceptable render time for such a flat, untextured scene.
Specially considering space scenes should not even need radiosity for
GI... hope you're rendering in a smartphone. :p
a game sig: http://tinyurl.com/d3rxz9
Date: 29 May 2011 18:35:08
Message: <4de2ca1c$1@news.povray.org>
well I suppose the planet is using a lot of media although
it may be overkill at such a scale. I wonder if SSLT would be
appropriate for distant planetary views where the atmosphere
appears to be very thin.
I'm not sure about that. Parts of the gate that are pointing
away from the Sun may be indirectly illuminated by opposing parts
that are in sunlight.
Date: 29 May 2011 18:54:35
Message: <4de2ceab$1@news.povray.org>
Am 30.05.2011 00:35, schrieb Christian Froeschlin:
I don't think so; the SSLT math presumes that the medium is very "dense".
Date: 30 May 2011 08:15:00
Message: <web.4de3891cd55febddb4f109e70@news.povray.org>
Are you using scattering media for the atmosphere? I suggest using emissive
media with a gradient map instead. Renders much faster, gives you more artistic
control and looks better as you don't geht a sharp shadow at the terminator.
This is what i've been using:
#declare R0 = 10; // planet radius
#declare ah = 0.25; // atmosphere height
sphere { 0, R0 } // the planet
sphere { // the atmosphere
  0, 1 pigment { rgbf 1 } hollow
  interior {
    media{
      emission 2.2*1/255 //scale to need
      density {
        spherical
        density_map {
          [ah/(R0+ah)*0.00 rgb <  0,  0,  0>]//sky
          [ah/(R0+ah)*0.20 rgb <  9, 10, 18>]
          [ah/(R0+ah)*0.30 rgb < 10, 14, 21>]
          [ah/(R0+ah)*0.40 rgb < 14, 18, 28>]
          [ah/(R0+ah)*0.50 rgb < 20, 23, 38>]
          [ah/(R0+ah)*0.55 rgb < 27, 33, 52>]
          [ah/(R0+ah)*0.60 rgb < 29, 39, 61>]
          [ah/(R0+ah)*0.65 rgb < 30, 45, 74>]
          [ah/(R0+ah)*0.70 rgb < 30, 54, 90>]
          [ah/(R0+ah)*0.75 rgb < 37, 67,109>]
          [ah/(R0+ah)*0.80 rgb < 48, 82,190>]
          [ah/(R0+ah)*0.85 rgb < 61, 99,151>]
          [ah/(R0+ah)*0.90 rgb < 80,118,171>]
          [ah/(R0+ah)*0.95 rgb <104,139,187>]
          [ah/(R0+ah)*1.00 rgb <154,173,203>]//ground
      density {
        gradient y
        translate -y/2
        scale 2
        density_map {
          [0.00 rgb <10,  8,  8>/255]//day side
          [0.40 rgb <10,  8,  8>/255]
          [0.45 rgb <37, 12,  6>/255]
          [0.50 rgb <59, 34, 15>/255]//terminator
          [0.55 rgb <66, 58, 56>/255]
          [0.60 rgb 0.65]
          [1.00 rgb 0.65]//night side
  scale R0+ah
Regards Roman
Download 'atmosphere.jpg' (88 KB)
Preview of image 'atmosphere.jpg'
Date: 31 May 2011 01:20:07
Message: <web.4de47962d55febdd7ab7c0b80@news.povray.org>
Hi Anthony,
Since your planet is far away, you may also want to consider using the aoi
pattern to fake an atmospheric glow. Although it doesn't give that soft/hazy
look, it renders very fast.  Here's a code snippet and an example of what it
looks like (with the USS Enterprise, of course! :-)
#declare p_planet_atmosphere =
      pigment {rgbt <0.5,0.5,0.5,0.5>}; // adjust transparancy component to
change atmospheric translucency
#declare p_planet_atmosphere_glow =
    pigment {rgb <0.9,0.95,1>*1.8}; // atmospheric glow
  aoi
  pigment_map {
  [0.5 p_planet_atmosphere_glow]
  [0.7 p_planet_atmosphere]
#declare t_planet_atmosphere =
      texture {pigment {p_planet_atmosphere}
              finish {ambient 0}
    union {
      sphere {0,3   texture {T_Stone22  finish {phong 0 ambient 0 reflection 0}}
}  // planet surface
      sphere {0,3.0001 texture {t_planet_atmosphere}}
   // planet atmosphere
// need a bright light to make it glow
Rob.
Rob Fitzel
www.fitzel.ca/dart
Download 'aoiatmosphere.jpg' (176 KB)
Preview of image 'aoiatmosphere.jpg'
Date: 31 May 2011 04:02:55
Message: <4de4a0af$1@news.povray.org>
Nice.
I am still surprised at the render time. My planets with the given *Tek
atmosphere*, render in less than an hour....
Date: 31 May 2011 11:59:10
Message: <4de5104e$1@news.povray.org>
On 31/05/2011 7:15, RobF wrote:
> Hi Anthony,
you could give it a soft/hazy look, even with some atmospheric
discoloration near the terminator:
--- START CODE ---
#version 3.7;
global_settings {
   assumed_gamma 1
#local SunLocation=<500,300,200>*1000;
   location -z*3
   look_at 0
light_source {
   SunLocation
   rgb <1.5,1.4,1.3>
// the planet itself
sphere {0,1 pigment {crackle solid scale .1} finish {ambient 0}}
//the atmosphere
#local Atmosphere=<.4,.5,.9>;
sphere {
   0,1
     pigment_pattern {
       slope {point_at SunLocation}
       pigment_map {
         [.5 rgb 1]
         [1 rgb 0]
     poly_wave 2
     pigment_map {
       [.5
         pigment_pattern {
           pigment_pattern {aoi color_map {[0 rgb 1][.5 rgb 0][1 rgb 1]}}
           color_map {
             [0 rgb 0]
             [.15 rgb 1]
             [.5 rgb 0]
         color_map {
           [0 rgb Atmosphere transmit 1]
           [1 rgb .25+Atmosphere transmit .35]
         poly_wave 2
       [1
         pigment_pattern {
           color_map {
             [0 rgb 0]
             [.15 rgb 1]
             [.5 rgb 0]
         color_map {
           [0 rgb 1-Atmosphere transmit 1]
           [1 rgb .25+(1-Atmosphere) transmit .35]
         poly_wave 2
   finish {diffuse 1 ambient 0}
   scale 1.02
--- END CODE ---
(It's the technique I used in my Babylon-video)
cu!
ZK
Date: 31 May 2011 14:35:01
Message: <web.4de533c3d55febdd9c4fb0ad0@news.povray.org>
> Nice.
> Thomas
I'm going to guess that your planets are all unit spheres, or not much bigger.
My planet has a radius of 63730 units: 1 unit = 100m, the atmosphere is 1000
units - 100 scale km - thick (density varies appropriately, 99% is below 36km,
50% is below 5.5km).  I'm not terribly concerned about the render time, although
it would be impossible to animate.
As for it being flat and textureless: It isn't.  The planet is a combination of
isosurfaces, one for land, one for ocean, and the water is my best water texture
yet (although I did remove the dispersion).
So, maybe it's a bit overkill, but I like it.
I appreciate all the advice, it's been very helpful.
A.D.B.
