POV-Ray : Newsgroups : povray.binaries.images : A little progress on the hand grenade Server Time
16 Mar 2026 20:43:55 EDT (-0400)
  A little progress on the hand grenade (Message 11 to 15 of 15)
Subject: Re: A little progress on the hand grenade
Date: 9 May 2010 12:25:00
Message: <web.4be6e157113fead1cba3fb0f0@news.povray.org>
> Am 06.05.2010 01:11, schrieb Dre:
> Hey, the radiosity feature /is/ fully operational in the current 3.7
> betas for quite some months already (except if Dave needs to use the
> abort/continue feature)...
Uh-oh, that means I've done something wrong again... There are two objects that
I have to comment out to render the whole scene with radiosity activated, or
else the radiosity pre-trace steps seem to go on forever. Version 3.62 will
render the scene without problems, so I assumed the radiosity feature wasn't
quite implemented yet in version 3.7. Thanks for the tip!
Dave Blandston
Date: 10 May 2010 04:59:56
Message: <4be7cb0c$1@news.povray.org>
Am 09.05.2010 18:22, schrieb Dave Blandston:
I'd be interested in details, because that shouldn't happen, so maybe
there's still some problem in certain situations.
Date: 10 May 2010 06:35:01
Message: <web.4be7e038113fead1cba3fb0f0@news.povray.org>
Here's a complete but simple scene demonstrating the situation. Version 3.7 will
eventually render the scene, but when the object is used in a more complex scene
the radiosity step goes on seemingly forever. There is one more object I've come
across that causes the same phenomenon, which I can post as well if you wish.
Dave Blandston
//Version 3.7 Beta 37a takes 24 minutes 55 seconds to render at 512 x 384 +am2
+r3.
//Version 3.62 takes 6 minutes 31 seconds to render with the same settings.
//Measured on a computer with four processors.
global_settings {
   radiosity {
      count 300
      error_bound .02
      pretrace_start .08
      pretrace_end .004
      recursion_limit 2
      normal on
   } //radiosity
} //global_settings
   location <0, 0, -3>
   direction <0, 0, 4/3>
   look_at <0, 0, 0>
} //camera
#local Dome = object {
   difference {
      sphere {0, 20001}
      sphere {0, 20000}
   } //difference
         gradient z
         color_map {
            [0, 1 color White * 1.8 color White * .6]
         } //color_map
      } //pigment
      finish {ambient 1 diffuse 0}
      scale <1, 1, 20000>
   } //texture
   no_reflection
} //object
object {Dome}
plane {z, 4 inverse texture {pigment {color rgb <213, 250, 81> / 255 * .6}}}
#local RingDiameter = 1 + 5/32;
#local RingWireRadius = 3/64;
#local Ring = object {
   #local NDegrees = 360 + 180;
   #local DeltaTheta = 15;
   #local NPoints = NDegrees / DeltaTheta + 3;
   #local DeltaZ = RingWireRadius / (360 / DeltaTheta) * 2;
   sphere_sweep {
      b_spline
      NPoints
      #local Theta = -DeltaTheta;
      #local CurZ = -DeltaZ;
      #local I = 0;
      #while (I < NPoints)
         <RingDiameter / 2 * cos (radians (Theta)), RingDiameter / 2 * sin
(radians (Theta)), CurZ>, RingWireRadius
         #local Theta = Theta + DeltaTheta;
         #local CurZ = CurZ + DeltaZ;
         #local I = I + 1;
      #end //#while
   } //sphere_sweep
   texture {pigment {color Yellow}}
} //object
object {Ring}
Date: 10 May 2010 07:57:43
Message: <4be7f4b7$1@news.povray.org>
Am 10.05.2010 12:31, schrieb Dave Blandston:
Hm... is the other a sphere_sweep object as well?
At present I'm pretty much inclined to think that this is not an issue
of radiosity /per se/, but rather a general performance issue with 3.7's
implementation of sphere sweeps, which is only emphasized by the numer
of rays shot for radiosity.
As far as this particular object goes, I suggest you try using a set of
half-tori instead of the sphere_sweep.
Date: 10 May 2010 08:50:00
Message: <web.4be80035113fead1cba3fb0f0@news.povray.org>
The other object is a little harder to pin down - it's a union of several boxes
and a couple intersections (with bounded_by containers) comprising the Metallica
logo. It's very low-tech CSG originally made with POV-Ray version 1, but it has
bevelled edges and reflection. Depending on what other objects I include in the
scene, render times vary quite a bit when using radiosity. I'm trying to narrow
the problem down more...
Thanks for the advice regarding the sphere_sweep!
Dave Blandston
