POV-Ray : Newsgroups : povray.binaries.images : Giving back to the group in shades Server Time
8 Apr 2026 09:34:42 EDT (-0400)
  Giving back to the group in shades (Message 70 to 79 of 79)
Subject: Re: Giving back to the group in shades
Date: 19 Jul 2009 12:45:00
Message: <web.4a634d6742435b22234595d50@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote:
> Ode to the Future
> Clearly the clouds in my coffee/planet/tea foretell the future
> They're coming to get us, ho ho, ha ha, he he
> This vast hemoglobin feeding ground for sure
> Reclaimed for the dark empire's greed
> They haven't technology to save the moms
> And defend against
> The time and space distorting gravity bombs
> Sadly as of yet
> If they did, would reality remain intact
> Only room for one dark overlord in fact
> Here's the "Where's Waldo" image, actually Waldo and one of his clones. Can you
> tell which one is the clone?
Here's an Earth shot I did recently. I did a lot of color correction on the
texture map to make the features match up better with actual photos taken from
space. For this pic, I placed a sphere within a sphere and subdivided both
pretty heavily, then applied a displacement map for the cloud level and the
Earth level to add some ruddiness. Not perfect, but not obviously CGI either.
Download 'earth_pov_scene.jpg' (46 KB)
Preview of image 'earth_pov_scene.jpg'
Date: 19 Jul 2009 13:20:01
Message: <web.4a6354d242435b22eecd81460@news.povray.org>
I guess the clouds would be less blueish.
Date: 19 Jul 2009 16:35:00
Message: <web.4a6382c042435b22234595d50@news.povray.org>
Heh, good eye, bad light. Clouds can look bluish because you can see through
them just a bit and see ocean of course. The light was the problem, fixed now.
Thanks. :O)
Date: 19 Jul 2009 17:10:00
Message: <web.4a638ae042435b2269d21dbe0@news.povray.org>
> Thanks. :O)
Wanna see--- plz! :)
Date: 19 Jul 2009 18:15:00
Message: <web.4a6399bb42435b22234595d50@news.povray.org>
Subtle difference, definitely an improvement, otherwise the same. Sometimes when
you have a goal in mind, like making the displacement maps work, which they do,
you forget other fundamentals.
Download 'earth_pov_scene.jpg' (44 KB)
Date: 19 Jul 2009 18:50:01
Message: <web.4a63a2fb42435b2269d21dbe0@news.povray.org>
Hm... displacement maps? So you're using isosurfaces?
(BTW, still not happy: Now I think the clouds look a bit too greenish - and the
Andes a bit too redish...)
Date: 19 Jul 2009 23:20:01
Message: <web.4a63e21e42435b22234595d50@news.povray.org>
The clouds are OK, I've done color readings on them and they're straight on the
RGB scale. I don't use CSG at all. Those are imported .obj models. The
displacement I did in Poseray. If you think the Andes look bad, I won't show
you Sahara/Africa. That correction still needs work. It looks orangeish from
space, but the texture maps are more yellowish.
Date: 20 Jul 2009 08:15:00
Message: <web.4a645e9742435b221e3715ac0@news.povray.org>
> RGB scale.
Define "color readings".
If you're saying that you picked those colors from Photoshop or the like,
chances are they're wrong for POV-Ray, as they'll usually be
gamma-precorrected, while POV-Ray needs linear color values.
Try raising all colors to the power of 2.2, as in:
    color rgb <pow(R,2.2),pow(G,2.2),pow(B,2.2)>
or to the power of 1/2.2 (I never can seem to remember which way round is
needed).
Again, I suspect gamma issues to be at least partially responsible. Solving
these with texture maps is not so easy though, as you need external tools to
"gamma-un-correct" the images.
There was a thread on povray.tutorials (IIRC) recently about gamma handling, in
which some methods were described to achieve proper gamma adjustment.
(Note that if gamma is wrong, there's no way you can properly fix it with
anything other than gamma (un-)correction.)
Date: 20 Jul 2009 20:45:01
Message: <web.4a650f4542435b22234595d50@news.povray.org>
That;s my standard assumed gamma, 2.2,  and I've got the color and greyscale
bars and they read fine. ;O)
Date: 21 Jul 2009 08:00:00
Message: <web.4a65ad0242435b22537313280@news.povray.org>
Note that assumed_gamma doesn't change how POV-Ray handles colors specified
directly in the source file: They're always expected to be linear.
Similarly, I'm not sure about assumed_gamma and input images.
