POV-Ray : Newsgroups : povray.binaries.images : The Cabal Server Time
23 Mar 2026 11:20:31 EDT (-0400)
  The Cabal (Message 21 to 26 of 26)
Subject: Re: The Cabal
Date: 3 Jan 2009 08:10:00
Message: <web.495f63004e21d8cc8f3cb1a30@news.povray.org>
>   I remember *someone* *somewhere* mentioning a reworking of the
> bounding system for 3.7. It might have been Chris or Thorsten
> themselves. It might even be mentioned in the beta release notes somewhere.
I recall something about area lights. Wasn't important enough for me to still
remember what it was exactly... I moved it to the swap file, so to speak.
Date: 3 Jan 2009 08:20:38
Message: <495f6626@news.povray.org>
High!
RobF schrieb:
> Will a New Year bring a New World Order?
So, the conspirationist paranoia finally made it to povray.org... but I
wonder that, when looking to the world map at the left, Afghanistan is
not under the influence of this congregation of
Illuminati/Bilderbergers/Reptiloids/Greys - neither are also most
Commonwealth countries! Strange, strange...
See you on www.khyberspace.de!
Yadgar
Now playing: Delta One (Synergy) - not $cientologic synarchy, but Larry
Fast!
Date: 3 Jan 2009 12:32:12
Message: <495fa11c@news.povray.org>
Warp wrote:
> clipka wrote:
>> "Kenneth" <kdw### [at] earthlinknet> wrote:
>>> Clipka mentioned in a recent post that bounding in 3.7 has been
>>> re-worked;
>> Never did. So that was either someone else, or a misunderstanding.
> somewhere.
There is a whole new bounding algorithm in 3.7. But it's not enabled by
default, you need a command-line switch to select it.
IIRC.
Date: 3 Jan 2009 16:10:01
Message: <web.495fd3f94e21d8ccf50167bc0@news.povray.org>
> > > Clipka mentioned in a recent post that bounding in 3.7 has been re-worked;
> Hm... well, maybe did after all, I guess... in conjunction with area lights.
Yes yes. Having to do with a looks_like object. But since then, I've noticed a
render time difference re: bounding (in 3.6.1), even without that object. Some
of it due to the area_light itself, but some that I can't account for. In any
case, 3.7 seems to have an improved auto-bounding scheme, if I read your notes
correctly. Which is good news!
Ken W.
Date: 4 Jan 2009 02:40:00
Message: <web.496066f94e21d8cc2d55026c0@news.povray.org>
Area lights! The Cabal scene had 25 area_lights.
As an experiment, I removed a few elements from the scene to see if I could
isolate the cause of the speedup.
Here are the render times in seconds (does not include parsing time):
(hope this table formats properly)
                                         v3.6    v3.7   speedup
basic scene                               130      36     3.6X
basic scene + radiosity                  1014     127     8.0X
basic scene + area lights                3121     181    17.2X
basic scene + area lights + radiosity    3401     255    13.3X
Radiosity and area lights appear to be much faster on v3.7, faster than just the
multicore speedup. I suspect the algorithm and/or compiler have generated much
more efficient code in v3.7.
Cheers,
Rob.
Date: 9 Jan 2009 22:54:50
Message: <49681c0a$1@news.povray.org>
This scene has something exciting. Probably becaue the atmosphere, the
setting of that all. That kind of international background. Many powerful
men from all parts of the world, united in this room. Well, I like the scene
and the idea!
Tea cups? Hmm. A proposal: use glasses, their transparency might bring some
additional details into the scene. Also, I think the skin colors are too
similar, use some slightly or a few stronger different shades. And some
skins are smoother, some aren't.
Just some ideas. But it is becoming a great work, well done!
Sven
Some hairs of distant persons looks a bit too shiny on light, and some faces
need some more detasils, wrinkles or skin irregularities, I believe.
"RobF" <nomail@nomail> wrote in message
news:web.495db135fbe3038a2d55026c0@news.povray.org...
> This render took 6.8GB, mostly from the high resolution textures used on
> the
> characters. I experimented with both v3.6 and v3.7. The render took about
> 7h50m
> on v3.6. Surprisingly, the render took about 40 minutes with v3.7! On my
> Quad
> Core, I was only expecting a 4X increase, but it looks like there are some
> other cool optimizations in v3.7. There are a few radiosity artifacts in
> the
> 3.7 version of the image, but overall the two images are very similar.
> Comments welcome.
> Rob.
> Rob Fitzel
> fitzel.ca/dart
