POV-Ray : Newsgroups : povray.binaries.images : Bathtub - take 2 Server Time
22 Mar 2026 08:58:09 EDT (-0400)
  Bathtub - take 2 (Message 26 to 35 of 65)
Subject: Re: Bathtub - take 2
Date: 19 Dec 2008 03:02:43
Message: <494b5523$1@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> schreef in bericht
news:web.494ad7956655db18e157c2430@news.povray.org...
> did anyone mention
> global_settings { number_of_waves Count }
No. But that can also be used of course :-)
> 3.5.11.35  Waves
> When used as a normal pattern, this pattern uses a specialized normal
> perturbation function. This means that the pattern cannot be used with
> normal_map, slope_map or wave type modifiers in a normal statement.
Whatever the docs say, it works for me anyway... :-)
> OK now I'm just a little ichy ... grain of salt eh?
Shower in mineral water... :-)
Date: 19 Dec 2008 03:10:35
Message: <494b56fb@news.povray.org>
news:web.494b47636655db18ab3d2ec40@news.povray.org...
Those images look allright though... What code did you use here?
Date: 19 Dec 2008 13:50:01
Message: <web.494bec5f6655db18c18a63f20@news.povray.org>
> Thomas
Well now that you mention it, I looked over what I grabbed for testing...
Really sloppy chrome, actually. I don't write stuff like this, but have been
know to paste it. Wont do that again.
all. The page had 6 lights, no radiosity used: this is water "11" in the 4-by
image, using the posted norms. (I dont think I changed them)
global_settings {
  number_of_waves  2
  assumed_gamma 1.9
  max_trace_level 5
  location <0, 50, -560>
  look_at <0,-7,0>
  angle 25
light_source { <0, 8000, 0> color White
    spotlight
    point_at <0,0,0>
    radius 10
    falloff 90
light_source {<4000,-250,-4000> color Gray30
 fade_distance 8000 fade_power 2
light_source {<-5000, 2500, -5000> color Gray40
light_source {
<0, 1200, 0>
color White
spotlight
point_at <0,0,0>
radius 10
falloff 110
light_source {
<40,-2.5,-40>
color Gray60
fade_distance 80
fade_power 2
light_source {
<-50, 25, -50>
color Gray50
fade_distance 80
fade_power 2
#declare Bigripple =
normal {
  waves 1
  frequency 6
  turbulence 0.8
  scale <0.5, 0.2, 0.2>*0.5
  translate -100*z
  rotate -30*y
#declare Smallripple =
normal {
  ripples 1
  frequency 3
  turbulence 0.5
  scale <0.35, 0.25, 0.25>*0.2
  translate 100*z
  rotate -10*z
#declare RippleNorm =
normal {
  average
  normal_map {
    [0.9 Bigripple]
    [0.8 Smallripple]
#declare water5 = plane {
    y,-50
       T_Chrome_3C
       pigment{ rgb <0.3,0.4,0.85>*0.6 }
       //normal { Bigripple scale 5000 }
       normal { RippleNorm scale 5000 }
       finish { ambient 0 }
   translate x*-18000
object { water5 }
thanks for posting code. One day we'll see a great picture for the effort.
Date: 19 Dec 2008 13:55:00
Message: <web.494bed9d6655db18c18a63f20@news.povray.org>
> Thomas
I forgot the sky, of course.
#declare sky_blue =
sky_sphere {
        gradient y
        color_map {
         [0.0 rgb <0.6,0.7,1.0>]
          [0.7 rgb <0.0,0.1,0.8>]
sky_sphere { sky_blue }
Date: 19 Dec 2008 15:50:00
Message: <web.494c08bf6655db1881c811d20@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote:
> Today I tried to find a suitable replacement for my Lego water:
>  <web.49472c24399f7e1d778c150@news.povray.org>
> I could not. I was able to make some watery chrome.
> I'd love to see someone find something better than f_ridge for the Lego pool.
The water probably doesn't look that bad.  The issue with water that makes it
interesting looking it what is available to reflect.  Your sky and background
is rather simple which ends up making the reflection very simple and chromey
looking.
I always point out that reflective surfaces only look as good as what is
available for them to reflect.
(see :
http://news.povray.org/povray.binaries.images/message/%3Cweb.464c611a4ef76416c150d4c10%40news.povray.org%3E/#%3Cweb.464
 for an example)
-tgq
Date: 19 Dec 2008 16:20:01
Message: <web.494c0f496655db1881c811d20@news.povray.org>
> looking.
> (see :
64
>  for an example)
> -tgq
I played around with coming up with a nice water today.
Download 'legopool1.jpg' (84 KB)
Preview of image 'legopool1.jpg'
Message: <web.494c0f736655db1881c811d20@news.povray.org>
> looking.
> (see :
64
>  for an example)
> -tgq
Again, but with an environment map rather than plain sky.
Download 'legopool2.jpg' (80 KB)
Preview of image 'legopool2.jpg'
Date: 19 Dec 2008 16:25:00
Message: <web.494c10106655db1881c811d20@news.povray.org>
> looking.
> (see :
64
>  for an example)
> -tgq
The actual water (as a heightfield as in the renders):
//start
#declare ASiz=250;
#declare RHIT=0.25;
#declare FREQ=15;
#declare WDep=75;
#declare WHit=0.45;
#declare TDep=WDep+WHit+RHIT+1;
#declare TFunk1=function{max(min(abs(x),1)-0.5,0)/(1-0.5)}
#declare PPIG3= //Pool Side Ripples
    function{TFunk1(x,y,z)}
    pigment_map{
      [0.0 rgb 0]
      [1.0 function{TFunk1(x,y,z)} frequency ASiz/FREQ sine_wave]
    scale 1/2
    poly_wave 3
    translate x*1/2
    scale 5
    warp{turbulence 0.05*x}
    scale 1/5
#declare WCol=rgb <0.51373, 0.70588, 0.70588>; //Water colour
#local FD=-60/ln(0.58);                        //Fade distance
#declare RScal=1/10;
#declare RFreq=50;
#declare SRip =
function{
    marble
    frequency ASiz/RFreq*RScal
    scale 1/5
    warp{turbulence 1.5}
    scale 5
    warp{turbulence 0.5}
    sine_wave
    scale RScal
#local FTILEA = function {SRip(x,y,z).gray*0.5+SRip(y,x,z).gray*0.5}
#local FTILEB = function {pigment{PPIG3 }}
#local FTILEC = function {pigment{PPIG3 rotate z*90}}
#declare aaa=WHit/TDep;
#declare bbb=RHIT/TDep;
#local FTILE = function
{FTILEA(x,y,z)*aaa+FTILEB(x,y,z).gray*bbb+FTILEC(x,y,z).gray*bbb+(1-aaa-bbb*2)}
#declare WW2=
height_field{
  function 600,600 {pattern{function{FTILE(x,y,z)}}}
  smooth
  hollow
  scale <ASiz,TDep,ASiz>
#declare MWater=
  material{
    texture{
      pigment{rgbt 1}
      finish{conserve_energy  diffuse 0.0  ambient 0  reflection{0 1 fresnel on
metallic 0}}
    interior{
      ior 1.33
      media{
        absorption rgb 1-WCol
        density{rgb 1/FD}
// water
intersection{
  box { <-8, -77, -8> <216, 1, 216>}
  object{WW2 translate <-10,-76,-10>}
  hollow
  material { MWater translate <-10,0,-10>}
//END
it can also be expressed as a normal by using modifying and using the function:
//START
#declare ASiz=250;
#declare RHIT=0.25;
#declare FREQ=15;
#declare WDep=75;
#declare WHit=0.45;
    pigment_map{
      [0.0 rgb 0]
    scale 1/2
    poly_wave 3
    translate x*1/2
    scale 5
    scale 1/5
#declare RFreq=50;
#declare SRip =
function{
    marble
    scale 1/5
    scale 5
    sine_wave
    scale RScal
#declare THit=WHit+RHIT*2;
#local FTILE2 = function
{FTILEA(x,y,z)*WHit/THit+FTILEB(x,y,z).gray*RHIT/THit+FTILEC(x,y,z).gray*RHIT/THit}
//#declare WW2=
//height_field{
//  function 600,600 {pattern{function{FTILE(x,y,z)}}}
//  smooth
//  hollow
//  scale <ASiz,TDep,ASiz>
#declare MWater=
  material{
    texture{
      pigment{rgbt 1}
metallic 0}}
      normal{function{FTILE2(x,z,y)} scale <ASiz,TDep,ASiz> bump_size 0.1}
    interior{
      ior 1.33
      media{
        density{rgb 1/FD}
// water
intersection{
  //object{WW2 translate <-10,-76,-10>}
  hollow
//END
-tgq
Date: 20 Dec 2008 01:15:01
Message: <web.494c8c2a6655db18fb8a7bfa0@news.povray.org>
Indeed.
log_E(0.58)
log(.58)/log(2.7182818284590452353602874713526) =
-0.544727175441672
#local FD=-60/ln(0.58); //Fade distance = 110.146882
so what does .58 refer to?
#declare WHit=0.45;
water-height ??? what does 0.45 refer to?
I can really appreciate the dimension considerations.
Reflection was unconvincing with 2 light-levels in the BG;
 still working on a tile pool perhaps.
Sky and lighting remains the same.
absorption from: 1-<0.51373, 0.70588, 0.70588>
to: <0.272, 0.046, 0.010>
(c_H2O_abs // rgb 1-WCol)
Top quality Lego bricks = parse time. Brick quality should have been a
brick(param), then you could save time where it isnt needed and have highQ
bricks in view.
Download 'legoworld_pool2.png' (107 KB)
Preview of image 'legoworld_pool2.png'
Date: 20 Dec 2008 10:45:00
Message: <web.494d12cf6655db18c67b294d0@news.povray.org>
> Indeed.
> log_E(0.58)
> -0.544727175441672
Um, I don't recall off the top of my head.  This was set up over a year ago.  I
think it was to try to correlate with something but the exact reasoning escapes
me at the moment.
> #declare WHit=0.45;
Sorry, I should've explained the variables.
ASiz=250; //~Length/Width of pool object
#declare RHIT=0.25; //Height of ripples (ripples at the sides of the pool)
#declare FREQ=15;   //frequency of ripples actually period or spacing, higher
number means further apart)
#declare WDep=75;   //Total depth of water
#declare WHit=0.45; //Height of main wave pattern
#declare TDep=WDep+WHit+RHIT+1; //Total depth of water with waves/ripples added
  - actually should be #declare TDep=WDep+WHit+RHIT*2;
#declare RScal=1/10; //relative overall scaling of wave pattern
#declare RFreq=50;   //frequency of waves (similar to FREQ above but for the
main waves)
#local FTILEA = function {SRip(x,y,z).gray*0.5+SRip(y,x,z).gray*0.5}  //main
wave pattern.  two perpendicular marble patterns with sine_wave and much
turbulence
#local FTILEB = function {pigment{PPIG3 }}  //side ripples
#local FTILEC = function {pigment{PPIG3 rotate z*90}} //side ripples
#declare aaa=WHit/TDep; //proportional height of waves
#declare bbb=RHIT/TDep; //proportional height of ripples
//total surface function
Note that when using function patterns/pigments, care must be taken to keep the
maximum total values between 0 and 1 as anything outside that range wraps back
around (ie jumps back down to 0 after 1, etc) and gives wrong and awful
results.
In FTILEA  the two 0.5 values can be altered but make sure they add to 1 (0.4 &
0.6, etc)
In FTILE, the combination of aaa+bbb+bbb+(1-aaa-bbb2) makes the wave pattern
sizing proportional keeping the values between 0 and 1.
As I have said, reflection is generally not helped with lighting, but with what
there is to reflect.  Maybe add a sun where your light is and some clouds to
the sky.
Adding a sun is as simple as making a sphere with high ambient values:
within light source
looks_like{
  sphere{0,1  //size and locate accordingly
    pigment{rgb 1} //or use whatever colour you want the sun to be
    finish{diffuse 0 ambient 10}  //it is important to have a high ambient value
here, otherwise it looks like a plain white ball
Using it with looks_like within a light source automatically lets light pass
through.  If it is not within a light source, add no_shadow to the object so it
doesn't interfere with the light.
-tgq
