POV-Ray : Newsgroups : povray.binaries.images : Bathtub - take 2 Server Time
15 Mar 2026 15:39:01 EDT (-0400)
  Bathtub - take 2 (Message 11 to 20 of 65)
Subject: Re: Bathtub - take 2
Date: 16 Dec 2008 12:10:00
Message: <web.4947e0b56655db18c549be300@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> Ny further critique, suggestions are more than welcome.
> -tgq
Don't know if you posted any script or what youre using for normals.
Here's a Cousin Ricky norm and the one I did for the Lego pool.
not in that order
#declare n_surface = normal {
         function { f_ridge (x, y, z, 0.1, 1.0, 7, 0.7, 0.7, 0) } 2
//   function { f_ridged_mf (x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2) } 2
 //f_ridge = function { internal(58) }
// Parameters: x, y, z
    // Six extra parameters required:
    // 1. lambda
    // 2. octaves
    // 3. omega
    // 4. offset
    // 5. Ridge
    // 6. noise
    // 1. H
    // 2. Lacunarity
    // 3. octaves
    // 4. offset
    // 5. Gain
    // 6. noise
Date: 16 Dec 2008 15:15:00
Message: <web.49480bd26655db1881c811d20@news.povray.org>
> > -tgq
> not in that order
>     // 1. lambda
>     // 2. octaves
>     // 3. omega
>     // 4. offset
>     // 5. Ridge
>     // 6. noise
>     // 1. H
>     // 2. Lacunarity
>     // 3. octaves
>     // 4. offset
>     // 5. Gain
>     // 6. noise
The water surface is f_ridged_mf(x,y,z, 0.1, 3, 7, 0.7, 0.7, 2) plus procedural,
hand placed ripples.  It is not a normal though, but actually a heightfield.
-tgq
Date: 16 Dec 2008 16:55:01
Message: <web.494822a26655db18ecb6e40e0@news.povray.org>
> I wasn't originally going to go in this direction, but with some of the comments
> on my previous render I ran through some alterations.
Awesome!
But there's something lacking to give the whole thing a scale of sorts... the
way it is now, it could just as well be the size of a toy.
Maybe add some bump map decoration to the feet?
Date: 16 Dec 2008 17:10:01
Message: <web.4948263b6655db18ecb6e40e0@news.povray.org>
.... or use a shallower angle for the camera..?
Date: 16 Dec 2008 17:20:00
Message: <web.494828e36655db18ecb6e40e0@news.povray.org>
> > I spit out a few quick examples with different environments.
> > Excuse the aliasing, I know it can be painful!
Of these, I'd take the bottom left one.
Date: 17 Dec 2008 03:55:27
Message: <4948be7f@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> schreef in bericht
news:web.49480bd26655db1881c811d20@news.povray.org...
> procedural,
> heightfield.
I am not entirely sure if this function is really natural to a bathtube or
any confined water surface, up to a certain scale. I think that wave and
ripple are dominant, and often combined together. As an example, here
follows the code I am currently experimenting with. The scaling is optional
but can be used for fine-tuning the whole. Frequency and turbulence are the
main parameters. Note also the difference in the rotation.
// start of code
#declare Bigripple =
normal {
  waves 1
  frequency 6
  turbulence 0.8
  scale <0.5, 0.2, 0.2>*0.5
  translate -100*z
  rotate -30*y
#declare Smallripple =
normal {
  ripples 1
  frequency 3
  turbulence 0.5
  scale <0.35, 0.25, 0.25>*0.2
  translate 100*z
  rotate -10*z
#declare RippleNorm =
normal {
  average
  normal_map {
    [0.9 Bigripple]
    [0.8 Smallripple]
// end of code
Date: 17 Dec 2008 21:10:00
Message: <web.4949b0236655db18c67b294d0@news.povray.org>
Download 'btub2.jpg' (130 KB)
Preview of image 'btub2.jpg'
Date: 17 Dec 2008 21:55:00
Message: <web.4949bb3e6655db18abad780@news.povray.org>
The hose seems too thin to me.
Date: 18 Dec 2008 01:55:00
Message: <web.4949f2a26655db1885de7b680@news.povray.org>
> not in that order
I got the 2nd function from Christoph Hormann's water tutorial.
The "2" on the end is mine, though.  A plane with a surface normal is not
realistic near the horizon.  I was spurred to investigate when the real-life
sea outside my car window looked nothing like my render.  An isosurface (or
height field) looked a lot more like the real thing.  The "2" was an attempt to
compensate for the difference without giving up the speed advantage of a plane.
Date: 18 Dec 2008 03:40:33
Message: <494a0c81$1@news.povray.org>
"Cousin Ricky" <ric### [at] yahoocom> schreef in bericht
news:web.4949f2a26655db1885de7b680@news.povray.org...
>> not in that order
> real-life
> (or
> attempt to
> plane.
Hm. I am not entirely convinced, although your function looks better than
Christoph's. I have some doubts about the use of f_ridge for ripples/waves
anyway. I prefer (for the time being) my own method (see above) with wave
and ripple patterns. Using judiciously the ripple origin, you can even make
interference patterns with that. Anyway, in most cases, ripples look like...
ripples and waves look like... waves in nature.
