POV-Ray : Newsgroups : povray.binaries.images : House Project Server Time
27 Mar 2026 18:57:18 EDT (-0400)
  House Project (Message 14 to 23 of 23)
Subject: Re: House Project
Date: 3 Mar 2008 10:58:57
Message: <47cc2041$1@news.povray.org>
> And an area light was used once, but it added a ton of extra time for the
> animation, and It wouldn't have been done in time for the actual due date.
Did you see my previous post? I have access to some 8-core machines.
Date: 3 Mar 2008 16:03:17
Message: <47cc6795$1@news.povray.org>
Nimish Ajmani nous apporta ses lumieres en ce 2008/03/03 07:58:
> "Kirk Andrews" <kir### [at] tektonartcom> wrote:
>> Hmmm...what radiosity settings are you using?  And do you have ambient lighting
>> turned off?
>> If you really want to add some extra realism (and extra render time), use an
>> area light.  Don't use it in the animation, of course.
> I am using the default radiosity settings.  I never used radiosity before this,
> but I am still toying with effects.
> I'll toy with the settings a bit more.  If you have any ideas, by al means, I
> would like to know them.
> -Nimish
A way to greatly accelerate area_light is to add adaptive 0 or adaptive 1 if you
get artefacts. That way, your area_light is almost as fast as a regular light
for most of the scene, it only slow down in the penumbrae. Optimum aray for
adaptive are: 5, 9, 17, 33, 65,... Even in the penumgrae, an adaptive area_light
don't sample every points of the array, just those whose neibours are different.
You know you've been raytracing too long when you read about an algorithm or
datastructure and your first thought is: "How can I use this to speed up
raytracing?"
Christoph Rieder
Date: 4 Mar 2008 12:31:14
Message: <47cd8762@news.povray.org>
"Nimish Ajmani" <nomail@nomail> wrote in message
news:web.47cb1c9ccfb38859835874580@news.povray.org...
     Very nice, but my only crit would be to tan the coffee table glass a
little as it's quite hard to see at the moment, (for me anyway), but keep up
the good work, it's looking good!
        ~Steve~
> -Nimish
Date: 4 Mar 2008 19:55:00
Message: <web.47cdee50cfb38859835874580@news.povray.org>
Thanks to everyone for all of the critique.  WE had to show our teacher to day
our progress, and he was extremely pleased with my work.  Thanks to all who
helped with it.
I'll post new pics soon, but I've started the animation portion, so I might
intersperse an animation here or there.
Date: 4 Mar 2008 21:33:49
Message: <47ce068d$1@news.povray.org>
A suggestion for the animation...  take the ceiling off all the rooms
and start your flight path by looking down from above...  like a floor
plan or 2-D drawing...  then drop down into one of the rooms and wander
about on a spline path.
Love the work so far.  Won't be offended if you ignore this suggestion :-)
> helped with it.
Date: 4 Mar 2008 22:10:00
Message: <web.47ce0ea7cfb38859835874580@news.povray.org>
I had already planned a spline for a fly-around, but I love the idea of
"dropping in a room."  I will include it, and thank you for your suggestion.
-Nimish
Date: 5 Mar 2008 15:07:22
Message: <47cefd7a$1@news.povray.org>
>> I did that so I could have an animated tour made for the house.
>> Unfortunately,
>> radiosity makes that kinda diffucult, as the project is due friday,
>> and It's
>> taking several minutes per frame, for nearly 10000 frames.
> I can help you with slow renders, but unfortunately my system might
> cause problems with radiosity... Could be worth a try anyway. Email me
> the sources as they are now (unfinished), and I'll try a few dozen
> frames. If it ends up working correctly, I could do the full render when
> you're done modeling.
I tried a radiosity scene to see if it worked correctly. And indeed, I
have a problem... The progress bar goes *nuts* during the prerender
radiosity passes :) But that seems to be the only problem.
Date: 5 Mar 2008 15:12:58
Message: <47cefeca$1@news.povray.org>
>> when you're done modeling.
[oops, accidentally sent before finishing]
My offer stands: email me your sources and I'll render your animation
using a few 8-cores and a dozen dual-cores :)
Date: 5 Mar 2008 17:10:01
Message: <web.47cf19ebcfb38859835874580@news.povray.org>
Thank you very much for the offer, but I managed to tie some of my own computers
together, and, using school resources, got it to render a lot quicker.  I posted
the 20 second animation on youtube, at the folowing location:
http://www.youtube.com/watch?v=7PekTXAfhQY
I admit it fell victim to Youtube's compression system, but that animation shows
of my entire house, including a few unrealistic passing through walls and glass.
I managed to do a trick with frames so that the roof only apears after you
enter, and therefore could do a drop into a room.
I will be duplicating this message in the animation section as well, but though
I should include a copy in the thread of this project.
As always, comments are welcome and greately appreciated.
Date: 6 Mar 2008 04:40:00
Message: <47cfbbf0$1@news.povray.org>
"Nimish Ajmani" <nomail@nomail> schreef in bericht
news:web.47cf19ebcfb38859835874580@news.povray.org...
What you can do is use interior_texture for your roof/ceiling. Use
pigment{Clear} for the outside and the current ceiling texture inside.
