POV-Ray : Newsgroups : povray.binaries.images : Just meshin' around Server Time
15 Mar 2026 04:54:05 EDT (-0400)
  Just meshin' around (Message 21 to 30 of 39)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Just meshin' around
Date: 28 Oct 2007 20:15:00
Message: <web.47253342e80243ea93ac1e080@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote:
> what else ... probably 9 other issues
mirc has safety switches for running dll and remote scripts.
You'll have to set things up if it isnt already.
what else ... probably 8 other issues
Date: 28 Oct 2007 20:35:00
Message: <web.4725380ae80243ea93ac1e080@news.povray.org>
http://members.aceweb.com/alphaquad/meshedit2.zip
uploaded new file because previous loaded same file
(missed the '2')
and max pnt fce info transposed, is really
50,000 triangles 25,000 pnts
what else ... probably 7 other issues
Date: 28 Oct 2007 21:15:00
Message: <web.472540f5e80243ea93ac1e080@news.povray.org>
The scripting environment is space chr(32) parsed so filenames and paths iwth
spaces will tend to fail. There are some work-arounds but is best avoided.
no "program files" dir
what else ... probably 6 other issues
Date: 28 Oct 2007 22:10:00
Message: <web.47254ea7e80243ea93ac1e080@news.povray.org>
path used by script:
subdir to mircdir "creation" needs to be created.
pov files and files used by pov script here:
c:\mirc\creation\*.png etc
what else ... probably 5 other issues
Date: 29 Oct 2007 00:50:00
Message: <web.4725736ce80243eab23aa5d0@news.povray.org>
If you're reading this for the first time,
download zip again 317,648
probably an error will be thrown by dialog if it cant find icon
2 icons added
4 issues left ... 10 wasnt a bad guess?
Date: 29 Oct 2007 09:28:38
Message: <4725ee16$1@news.povray.org>
Hi alphaQuad;
  Thanks for the dl.  I'll give it a try this evening.  It could be a really
useful tool for me.  Thanks again...gjw
"George J. Wallace" <geo### [at] msncom> wrote in message
news:4724f8eb$1@news.povray.org...
> Hi alphaQuad - did you ever release that mesh viewer/exporter ?  If so,
I'd
> really like to get a copy.  TIA...gjw
> "alphaQuad" <alp### [at] earthlinknet> wrote in message
> news:web.4723dfb1e80243eab2f189180@news.povray.org...
> > > > Just meshin' around
> > > Wow, 5 starts for each!
> > > What are the render times for these beauties?
> > > How did you make the meshes?
> > > Leef_me
> > 2 minutes roughly @ 800x600
> > all meshes are a dodecahedron.
> > the model's history is from either calculation or an existing wrl.
> > remember my mirc mesh viewer pov exporter? It can take
> > shapes from a wrl library and export to pov.
> > Another method is to calc it this way(I think these are left faces):
> > alias initDodecahedron {
> >   npts = 20
> >   nfaces = 12
> >   A = 1.618034
> >   ;/* (sqrt(5) + 1) / 2 */
> >   B = 0.618034
> >   ;/* (sqrt(5) - 1) / 2 */
> >   C = 1.0
> >   vertexes = (-(A)) 0 B : (-(A)) 0 (-(B)) : A 0 (-(B)) : A 0 B : $&
> >     B (-(A)) 0 : (-(B)) (-(A)) 0 : (-(B)) A 0 : B A 0 : $&
> >     0 B (-(A)) : 0 (-(B)) (-(A)) : 0 (-(B))  A : 0 B A : $&
> >     (-(C)) (-(C)) C : (-(C)) (-(C)) (-(C)) : C (-(C)) (-(C)) : C (-(C))
C
> >     (-(C)) C C : (-(C)) C (-(C)) : C C (-(C)) : C C C
> >   polygons = 1 13 11 12 17 : 2 18 9 10 14 : 3 15 10 9 19 : 4 20 12 11 16
> >     5 15 3 4 16 : 6 13 1 2 14 : 7 18 2 1 17 : $&
> >     8 20 4 3 19 : 9 18 7 8 19 : 10 15 5 6 14 : 11 13 6 5 16 : 12 20 8 7
17
Date: 29 Oct 2007 10:00:00
Message: <web.4725f423e80243eab23aa5d0@news.povray.org>
"George J. Wallace" <geo### [at] msncom> wrote:
> Hi alphaQuad;
Useful indeed. You can debug any math logic, write test functions without a
compiler. go from tested logic to literal translation in other languages you
can write. add DLL speed of comiled functions where script is too slow. write
complete progams others can improve, edit or use parts of.
I was going to do wavefront exporter/reader next, along with 9 other projects
Script currently running with version 6.14 32 bit
Date: 29 Oct 2007 11:35:00
Message: <web.47260ba0e80243ea18afe7e20@news.povray.org>
using the POV tab meshexport button.
pov-mesh.txt is your template and must edited to your POV needs.
pov-mesh.txt will be copied, object added and sent to POV for render.
any declarations of map files in the example provided must be removed.
smooth value of 0 runs a scripted (bit slower than a smooth mesh)
creation of a mesh2 { needs work & C translation, first mesh export I wrote }.
smooth value in degrees makes a mesh { smooth_triangles }
this area has room for improvement in capability of output options
uv mapped / mesh or mesh2 / etc / etc
Date: 29 Oct 2007 15:05:00
Message: <web.47263bcce80243ea18afe7e20@news.povray.org>
basic model (.mod) support is in some alpha state but can send multiple objects
with non-UV map alignment, texture or color to POV
Download 'modsupport.jpg' (74 KB)
Preview of image 'modsupport.jpg'
Date: 30 Oct 2007 12:55:00
Message: <web.47276f11e80243ea2c951cbb0@news.povray.org>
 ;com id objfile color map/ambient/Tname [ mapname filesuf wraptype scalev
rotatev map_alignv/find 0 0 ] finish...
added better than mirc-style comment support in that spaces around the
semi-colon are irrelevant. empty lines allowed.
See example:
warbird-chrome.mod
lastest release with all previous notes:
318,909 bytes
link in previous post
