POV-Ray : Newsgroups : povray.binaries.images : Invitation: The Gate is Never Locked Server Time
27 Mar 2026 05:48:42 EDT (-0400)
  Invitation: The Gate is Never Locked (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Invitation: The Gate is Never Locked
Date: 14 Jun 2007 21:29:19
Message: <4671eb6f$1@news.povray.org>
Looks nice!
The gate needs hinges though.
Date: 15 Jun 2007 07:38:02
Message: <46727a18@news.povray.org>
Kirk Andrews wrote:
>> Nice gate design - how'd you do it?
>> Stefan
> Thanks!
> Perhaps there is a better way to do it, but I first designed it in a
> vector-editor, and then exported it as a bitmap image.  In POV I turned
> the bitmap into a function, and used the function in an isosurface. The
> bumps were added by subtracting a pigment function in the isosurface.
Yikes! How do you "turn a bitmap into a function"? The isosurface part I
(think) I've got an idea how to do, as well as adding the bumps. But how do
you turn a bitmap into an isosurface function?
Stefan
Date: 15 Jun 2007 08:40:02
Message: <web.46728838753da728d9b8bbd0@news.povray.org>
You can turn any pigment into a function, so first declare an image pattern
pigment, and then declare a function using that pigment.  This is my code:
#declare PGate =
  image_pattern {
    jpeg "Gate/GateStructure4.jpg"   // image file to read
#declare GateF =
function {
  pigment {PGate scale 10000*z}
You'll need a fairly high max_gradient setting (like 35) for it to come out
right.
-- Kirk
Download 'gatestructure4.jpg' (18 KB)
Preview of image 'gatestructure4.jpg'
Date: 15 Jun 2007 08:50:02
Message: <web.46728a4c753da728d9b8bbd0@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote:
> This is looking really good. The isosurface rocks in the foreground look a
> bit smooth for rocks (I mean at a fine detail level if this makes any
> sense), is this just a low quality accuracy setting? What method/patterns
> did you use to make the rock isosurface? I have always found combining
> wrinkles with other patterns good for a rock surface.
Thanks!  I wanted a wanted the rocks to look dry and weathered, so I wanted
them a little smoothe.  For these I just used a bumps pigment with
turbulence -- adding a wrinkles pigment probably would have added some
detail, though.
> I look forward to seeing the next version of this image, what are the render
> times like..
> Sean
It took about 4.5 hours on my 2 GHz machine.
-- Kirk
Date: 15 Jun 2007 09:00:01
Message: <web.46728c33753da728d9b8bbd0@news.povray.org>
"fls13" <fls### [at] netzeronet> wrote:
> One of the finest Povray renders I've seen.
Thank you!  A very flattering compliment indeed!
> How about seeing your light and radiosity settings?
light_source {  //Sunlight
  <0, 0, 0>            // light's position (translated below)
  color rgb <1.5, 1.3, .4>*3.25  // light's color
  translate <-20, 20,  30>*1000
global_settings {
  radiosity {
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.04           // end pretrace at this size
    count 50                      // higher -> higher quality (1..1600) [35]
    nearest_count 5               // higher -> higher quality (1..10) [5]
    error_bound 0.5               // higher -> smoother, less accurate [1.8]
    recursion_limit 1             // how much interreflections are
calculated
    low_error_factor .5           // reduce error_bound during last pretrace
    gray_threshold 0.0            // increase for weakening colors (0..1)
[0]
    minimum_reuse 0.015           // reuse of old radiosity samples [0.015]
    brightness .5                  // brightness of radiosity effects (0..1)
[1]
    adc_bailout 0.01/2
    save_file "InvitationRadiosity"       // save radiosity data
  light_source {  //Reddish foreground light
    color rgb <.5, .2, .2>*.1  // light's color
    translate < 20,  50, -30>
    fade_distance 150
    fade_power 2
    shadowless
--  Kirk
Message: <web.46728cf1753da728d9b8bbd0@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote:
> Looks nice!
Goodness, you're right!  Not only are they unlocked, they don't even have
hinges!  I'll have to fix that.
Date: 16 Jun 2007 06:14:40
Message: <4673b810@news.povray.org>
>> do you turn a bitmap into an isosurface function?
> pattern pigment, and then declare a function using that pigment.  This is
> my code:
Ooooo! Thanks Kirk - I'd never have thought of that myself. Of course, it
probably is there in the docs, but I'd -never- have figured it out / picked
it up myself.
I've just had an epiphany here - you've opened up so many cool ideas my head
is spinning... thanks for sharing the code. You've just stimulated some
serious creativity - this technique offers so many possibilities (for me at
least.)
Thanks again...
Stefan
Date: 16 Jun 2007 09:35:03
Message: <web.4673e5eb753da7247d3ae5e0@news.povray.org>
Great job with the scene, both the architectual and the environmental.
The style appeals to me very, very much!
Date: 17 Jun 2007 19:45:01
Message: <web.4675c75f753da72387a47510@news.povray.org>
> #declare PGate =
> pigment {
>   image_pattern {
> #declare GateF =
> function {
Kirk,
It appears that I need a little help on your "image as function" code.  If I
try to render the object (see below) POVray tells me this:
 function
  GateF(x,y,z)
Parse Error: Expected '.', } found instead
Did I misunderstand your sample?
-Allan
Here is my code...
#declare PGate =
pigment
  image_pattern
    jpeg "GateStructure4.jpg"   // image file to read
#declare GateF = function {pigment {PGate scale 10000*z}}
isosurface
  function
    GateF(x,y,z)
  accuracy 0.01
  threshold 1.0
  contained_by {box {-2,2}}
  max_gradient 35
  uv_mapping
  material
    texture
      pigment {color rgb <0.98, 0.83, 0.58>}
      normal
        brick 0.5 //amount
      finish
        diffuse 0.6
        brilliance 1.0
    interior
      ior 1.3
Date: 17 Jun 2007 20:10:02
Message: <web.4675cbe1753da728d9b8bbd0@news.povray.org>
> Kirk,
>  function
>   GateF(x,y,z)
> -Allan
Pov is looking for "function {GateF(x,y,z).gray}"  It will always require
..gray or .red etc. if you are using a pigment function (including a
bitmap).
Here's my whole code for the gate:
#declare PGate =  //The bitmap pigment
  image_pattern {
#declare GateF =  //convert to function
function {
#declare Gbumps =  //bumps applied
function {
    bumps
    scale .01
    color_map {
      [0 rgb 0]
      [1 rgb 1]
#declare GPlaneF =  //the pigment function is infinite in the z direction.
This limits it and allows for some rounding of the edges when combined with
the bumps pigment
function {
    gradient z
    color_map {
      [0.0 rgb 0]
      [0.1 rgb 1]
      [0.9 rgb 1]
      [1.0 rgb 0]
    scale .1*z
#declare IsoGate =
isosurface {
  function {(GateF(x,y,0).gray -.5 +
Gbumps(x,y,z).gray*.5)*GPlaneF(x,y,z).gray}
  contained_by { box { 0, <1,.999,.05> } }
  accuracy 0.001
  max_gradient 35
  scale 2*y
  translate -1*x
  translate 1*x
