POV-Ray : Newsgroups : povray.binaries.images : Molecular beauty Server Time
21 Dec 2025 17:41:54 EST (-0500)
  Molecular beauty (Message 1 to 10 of 14)
Subject: Molecular beauty
Date: 18 Jul 2006 10:15:01
Message: <web.44bcec86bebb893b6b3522e90@news.povray.org>
A little molecule with its packing diagram in the background.
Used a "water"-box to hide the low quality background image, an image of a
plant from which the substance was extracted the first time.
Crystallographic data was exported to pov-format by using ORTEP3 for
Windows.
Best regards to the community, Shu.
Download 'ortep_50.jpg' (249 KB)
Preview of image 'ortep_50.jpg'
Subject: Re: Molecular beauty
Date: 18 Jul 2006 13:23:12
Message: <44bd1900$1@news.povray.org>
Please tell us something about this molecule.
Can you do double bonds?
DLM
"Shurakai" <nomail@nomail> wrote in message
news:web.44bcec86bebb893b6b3522e90@news.povray.org...
> Windows.
Date: 18 Jul 2006 18:15:00
Message: <web.44bd5c8858e02087a55cb6f70@news.povray.org>
It is a nice image, there is something about the colours of certain images
when viewed on LCD monitors that make the image seem more 3D than normal.
It is an interesting effect that is probably lost on anyone who still has
an old CRT monitor. Or maybe I just need new glasses..
Sean
Date: 18 Jul 2006 21:35:01
Message: <web.44bd8a5658e0208721be5c810@news.povray.org>
> Windows.
1:  Looks like you have an opportunity to make 2 renders: 1 for left eye, 1
for right eye, and make it 3D!  Can you do one for us?  They are popular in
chemistry journals.... at least when I used to be research assistant.
2:  What is this software ORTEP3?  Does it import/export to different
models?
Date: 19 Jul 2006 06:33:27
Message: <44be0a77@news.povray.org>
Lovely. I still want to see something like this with the electron fields
rendered instead of the connector sticks. Maybe it would look too
confusing.. or maybe it could look very pretty...
-Nekar Xenos
"The truth is out there"
Date: 20 Jul 2006 12:55:00
Message: <web.44bfb52a58e020876b3522e90@news.povray.org>
> -Nekar Xenos
Hi Nekar,
i also would like to render electron density-maps, because that's what You
measure in a X-ray diffraction experiment. But up to now i didn't find a
way to convert the different slices of fourier-maps or electron density
maps to DF3 format. It would be very nice to render the unit cell, or even
only the asymmetric unit in a way that it represents the electron density
in the space by illuminating clouds. If someone have a good idea i would
appreciate a lot to hear it.
Best ragards, Shu
Date: 20 Jul 2006 13:10:01
Message: <web.44bfb82958e020876b3522e90@news.povray.org>
> models?
Hi EagleSun,
hmmmm stereo view. It should be no problem to render one image with a
camera-position left and one with the position right to the centered normal
vector to the molecule. But the difficulties will start when i need to merge
both images into one using red and blue colors. I think the idea is good but
it's not possible for the complete image including the background. But for
the single molecule alone maybe i can achieve a good looking steroview.
ORTEP3 is a program for displaying the Thermal ellipsoids (ORETP = Oak Rich
Thermal Ellipsoid Plot) of determined X-ray crystal structures. These
ellipsoids represent the space occupied by the electrons of a atomic
nucleous with 50 % propability level. It has nothing to do with POVRAY
except the fact that is exportes very nice *.pov files of the structural
data of a molecule. You can only use it to converst different molecular
structure file formats into each others but You cannot interconvert models
from other sources.
Best regards, Shu.
Date: 20 Jul 2006 13:12:17
Message: <44bfb971@news.povray.org>
Put the two images next to each other, with the right-eye image on the
left, and look at it cross-eyed. Then you don't need glasses or anything.
     This octopus isn't tasty. Too many
     tentacles, not enough chops.
Date: 21 Jul 2006 03:21:44
Message: <44c08088@news.povray.org>
news:web.44bfb52a58e020876b3522e90@news.povray.org...
>> -Nekar Xenos
> Hi Nekar,
I was thinking if you have the mathematical formula for electrion density,
you could use it as a function for media density.
-Nekar Xenos
Date: 21 Jul 2006 09:02:16
Message: <44c0d058$1@news.povray.org>
"Nekar" <ger### [at] rpmmagcoza> wrote in message
news:44c08088@news.povray.org...
>>> -Nekar Xenos
>> Hi Nekar,
>> You
>> even
Perhaps even a simple semi-transparent surface shell for a containing volume
at an arbitrary confidence level?
DLM
