POV-Ray : Newsgroups : povray.binaries.images : The Pi Pool Balls Server Time
14 Mar 2026 05:32:45 EDT (-0400)
  The Pi Pool Balls (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: The Pi Pool Balls
Date: 22 Nov 2005 17:47:00
Message: <43839fe4$1@news.povray.org>
Just plain sweet me likes.
"the_ajj" <nomail@nomail> wrote in message
news:web.4382fbe3663c0519a43155f60@news.povray.org...
> "Frango com Nata" <nomail@nomail> wrote:
> > I find it nice, too. By the way, how did you get pi's digits? Did you
just
> > write the first 45 of them, or did you use some algorithm to calculate
as
> > many as wanted?
> Nothing too fancy I'm afraid.  I got the digits themselves off the web.  I
> then created an image map for each of the balls with the relevant digits.
Date: 23 Nov 2005 09:30:00
Message: <web.43847c62663c051974786be00@news.povray.org>
"the_ajj" <nomail@nomail> wrote:
> By the way, how did you get pi's digits? Did you just
> > write the first 45 of them, or did you use some algorithm to calculate as
> > many as wanted?
If you like, I can translate a short Pi generator into POV SDL that will
give about 700 digits before it gets overflow errors. On a related note, I
posted a POV scene file a few months back that can calculate e to millions
of digits. I'll repost it if you like.
PS. Nice concept. Years ago, I wrote a PostScript program to print pi in an
exponential spiral, and I've recently been thinking of converting it
(somehow) into POV SDL.
Date: 23 Nov 2005 10:15:01
Message: <web.4384873a663c0519663e2c5e0@news.povray.org>
I'd like just to know the method...
This reminds me a long-silenced doubt on why quaternion Julia fractals are
restricted to square and cube functions, being it that exponentials and
trigonometrics, as well as their inverses, can actually be generalized to
quaternions, and I wonder where the advantage of our so-called hypercomplex
numbers is. I can't expect to be the first one to point this out, but have
never read a message explaining what happens to POV-Ray's fractals
regarding this issue. Well, perhaps I should make my question in
povray.newusers...
Date: 24 Nov 2005 08:35:00
Message: <web.4385c094663c0519a43155f60@news.povray.org>
> Right. That is great. Where is the 1600x1200 Version to use it as a
> desktop background?
I will render it at a higher resolution this weekend and will post on my web
site.  Let you know when it's there!
Adrian
Message: <web.4385c133663c0519a43155f60@news.povray.org>
Pi generator would be cool! Could generate some very nice abstract images
then!  Be great if you could post it.
Yeah i was think of a spiral too.  My other concept was placing the balls on
a sine curve in the xz plane and use less focal blur.....lot of image maps
using this message.  Would look nice though ! :-)
Date: 25 Nov 2005 05:20:01
Message: <web.4386e4ae663c05192eef1b3b0@news.povray.org>
Here's a Pi spiral. I think I may have a PostScript spiral program that
works better with proportional fonts, but I'd have to hunt for it...
Download 'pispiral0k.png' (54 KB)
Preview of image 'pispiral0k.png'
Date: 25 Nov 2005 07:15:00
Message: <web.4386ff4d663c05192eef1b3b0@news.povray.org>
(I thought I replied to this bit already, but I can't see my reply anywhere.
Oh well...)
I'll work on converting Dik T. Winter's Pi program into POV SDL this
weekend. It shouldn't take too long - I'll just modify my e calculator.
Here's Dik's C source for this algorithm, which can actually do a little
over 800 digits.
int a=10000,b,c=2800,d,e,f[2801],g;main(){for(;b-c;)f[b++]=a/5;
     for(;d=0,g=c*2;c-=14,printf("%.4d",e+d/a),e=d%a)for(b=c;d+=f[b]*a,
     f[b]=d%--g,d/=g--,--b;d*=b);}
Do a Google Groups search on
 Dik T. Winter Pi digits
for more info.
Date: 28 Nov 2005 00:45:00
Message: <web.438a98df663c0519ad93754b0@news.povray.org>
> over 800 digits.
> for more info.
Ok, I've now got a working POV version of the above obfuscated C program.
I'll post it tonight. Sorry about the delay, I got distracted... :)
Date: 28 Nov 2005 03:05:01
Message: <web.438ab998663c0519f3708fad0@news.povray.org>
> > over 800 digits.
Here it is: Pi in the sky. :)
// Persistence of Vision Ray Tracer Scene Description File
// File: ECalc.pov
// Vers: 3.6
// Desc: High precision calculation of pi
//       using Dik T. Winter's method.
// Date: 2004.09.05
// Auth: PM 2Ring
// -F -A0.5 +AM2 +R1
// -D +A0.1 +AM2 +R3
#declare Use_Light = 1;         //0=self-luminous. 1=use light source
#declare Use_Sky = 1;           //0=grey background. 1=Sky sphere with
clouds
global_settings {
  assumed_gamma 1
  max_trace_level 10
#include "skies.inc"
camera{
  //orthographic
  location -z * 70
  look_at 0
  right x*image_width/image_height up y
  direction z
  angle 30
#if(Use_Sky)
  sky_sphere {S_Cloud2 rotate <65, -175, -3> scale .25}
#else
  //background{rgb .5}
//0: self luminous
#if(Use_Light)
  light_source {<0.0, 150.0, -250.0> rgb 1}
  #default {
    finish{
      specular 0.75 roughness 0.045
      phong .5 phong_size 200
      metallic
      reflection{
        0.6
        metallic
      ambient 0.05 diffuse 0.7
    pigment{ rgb<1.0, 0.75, 0.175> }
#else
  #default {
    finish{ ambient 1 diffuse 0 }
    pigment{ rgb<1.0, 0.8, 0.2> }
//Progressively print passed strings, with line wrap. Can't break up long
strings.
#declare Txm=18;                //Right margin
#declare Lx=-Txm;               //Left margin
#declare Tx=Lx;                 //Cursor position
#declare Ty=11.5;               //Top margin
#declare Dy=1.1;                //Line height
//Newline
#macro NL()
  #declare Tx=Lx;
  #declare Ty=Ty-Dy;
//Print string. Works better with a monospace font like "lucon.ttf"
#macro print(s)
  #local TBlock = text{ttf "cyrvetic.ttf", s .5, 0}
  #local Dx = (max_extent(TBlock) - min_extent(TBlock)).x;
  #if(Tx+Dx>= Txm) NL() #end
  object{TBlock translate <Tx, Ty, 0>}
  #declare Tx=Tx + Dx;
#include <stdio.h>
int main(void)
    int a = 10000, b = 0, c = 2800, d = 0, e = 0, f[2801], g;
    while (b!=c)
        f[b] = a/5;
        b = b + 1;
    g = c*2;
    while (g)
        d = 0;
        b = c;
        while (b)
            d = d + f[b]*a;
            g = g - 1;
            f[b] = d % g;
            d = d / g;
            g = g - 1;
            b = b - 1;
            if(b) d = d * b;
        c = c - 14;
        printf("%0.4d", e + d/a);
        e  =  d % a;
        g = c*2;
    printf("n");
    return 0;
#declare a = 10000;
#declare c = 2800;
#declare e = 0;
#declare f = array[c+1];
#declare b = 0;
#while (b!=c)
  #declare f[b] = 2000;
  #declare b = b + 1;
#declare f[c] = 0;
union{
  print("800 digits of pi.") NL()
  #debug "nStarting Pi calculation. This scene requires the parsing of over
22300K tokensn"
  #declare g = c * 2;
  #while(g)
    #declare d = 0;
    #declare b = c;
    #while(b)
      #declare d = d + f[b]*a;
      #declare g = g - 1;
      #declare f[b] = mod(d, g);
      #declare d = floor(d / g);
      #declare g = g - 1;
      #declare b = b - 1;
      #if(b) #declare d = d * b; #end
    #declare c = c - 14;
    #declare dd = e + floor(d/a);
    print(concat(" ", str(dd, -4, 0)))
    #declare e  =  mod(d, a);
    #declare g = c*2;
    //#debug "."
  //#debug "nFinished calculatingn"
  rotate -20*y/2
  translate 1.5*x
//--------------------End of scene-----------------------------
Don't forget to restore the backslashes in the #debug statements.
Download 'picalcas.jpg' (250 KB)
Preview of image 'picalcas.jpg'
Date: 28 Nov 2005 13:10:00
Message: <web.438b46f2663c0519a43155f60@news.povray.org>
That's great - thanks - now for some more interesting pool ball images!!!
