POV-Ray : Newsgroups : povray.binaries.images : IsoStones Server Time
5 Apr 2026 05:24:28 EDT (-0400)
  IsoStones (Message 28 to 37 of 37)
Subject: Re: IsoStones
Date: 18 Sep 2005 11:05:01
Message: <web.432d812e81952861093c2050@news.povray.org>
Chris Cason <nos### [at] deletethispovrayorg> wrote:
> PM 2Ring wrote:
> > This group of stones is a single isosurface. The wet sand is a
> > normal-perturbed plane. The stone textures are the standard textures
> > in stones.inc.
> This is nice work. Perhaps once you've finished with your tweaks to it you
> may like to consider submitting it (or a variation thereof) for consideration
> as a standard POV-Ray example scene.
Thanks, Chris! I would be delighted to submit a variation of this scene for
consideration as a standard POV-Ray example scene. I've (almost) given up
improving the stone displacement, but I've been polishing up the code,
adding comments & better identifiers. I'll post my latest version in a day
or so, when I get the chance.
I could add a sand isosurface & maybe even a water object, but I don't want
to make the scene too complex. Besides, from my tests today, the minor
visual improvements don't justify the increased render time.
Date: 18 Sep 2005 11:20:00
Message: <web.432d849281952861093c2050@news.povray.org>
"William Pokorny" <pok### [at] attglobalnet> wrote:
> As someone else said your IsoStones are very instructive - thanks for
> posting the source.
Thanks, William.
> The stone textures - in fact most of the old 3.1 textures - have never been
> updated to account for the resulting image being gamma corrected. The 3.1
> stone textures for example were to be rendered with an assumed gamma of 2.2.
> The automatic portfolio set up INGO put together rendered them with an
> assumed gamma of 1.0 just as you too used them. However, used in this way
> all these textures will appear washed out compared to the creators intent.
Ok.
> For good reasons we should be using the assumed gamma of 1.0 for renders,
> but the majority of the sample textures look washed out if you do it. Leads
> to some confusion I think - it certainly confused me for a time.
Me, too! I'm still easily confused about how assumed_gamma & display_gamma
work together. :)
> A_stones.jpg  is my render of your original source using 3.6.
> B_stones.jpg uses the assumed gamma of 2.2 so the stones look as they did in
> 3.1, but naturally the sand and lighting is darker than you intended because
> no gamma correction was done - my display gamma is set to 2.2 as is true for
> most PC users (1).
> C_stones.jpg takes a stab at un-gamma correcting the stone textures so that
> when the gamma correction is done the stones appear as I think intended by
> the texture creators, but with your lighting and sand color.
> (1) - Most all PC displays have a display gamma of about 2.2 except for
> Apple, SGI and perhaps a few other less common platforms.
This old monitor is very bright. I have the brightness as low as it can go,
but it's still a bit too bright for me. I have set my Display_Gamma to 2.6,
but I think I should re-calibrate it. All my images look too bright on
other peoples' monitors & my lcd monitor at work.
At first, this didn't worry me, as I've seen some fantastic pictures here
that were using gamma 2.2 that were so dark I had to gamma-correct them to
view them. Fortunately, my video card lets me do this pretty easily.
Your picture C looks too dark to me, B is just right. As I said, I've got to
do something about this monitor. :)
Message: <web.432d859581952861093c2050@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote:
> A derivative work, hopefully okay since the SDL was shared...
Sure! But you don't need to make the text quite so big, Greg. :)
I tried putting a mandelbrot onto a stone, but it looked ugly.
Date: 18 Sep 2005 11:30:00
Message: <web.432d871681952861093c2050@news.povray.org>
rock <roc### [at] almostbestwebnet> wrote:
> PM 2Ring wrote:
> > Also, isosurfaces can be faster than you might think. I have a sofa object
> > derived from one of Jaime's LightSys demo scenes. The original is built
> > from isosurface{f_rounded_box()}, I converted it to use superellipsoids,
> > but the isosurface version was the faster! IIRC, I posted the scene file in
> > p.b.i a couple of weeks ago; look for the very shiny blue sofa.
> well, one sofa is different from many stones: completely
> different from the original picture posted.
Sure they're different, but the point I was making is that isosurfaces can
render faster than a more conventional shape.
> >>I picture something like ... defining 12 different rock shapes.
> >>Then, whenever you place a rock, randomly pick which of the 12
> >>pre-defined rock shapes to place.  Rotate it randomly y before
> >>placing it.  As each one is placed, randomly texture it.
> > Sure, I can do that:). However, you don't really save memory (in the current
> > version of POV) by doing this, unless you're doing it with mesh objects.
> Memory was not the concern of my posting; render time was.
> If I wanted many stones in a single isosurface, my poor
> CPU would kick it's little feet in the air and expire.
> Or at least my patience would.  :D
The attached image uses individual isostones, layed out in a slightly
randomized Archimedean spiral pattern (parametrized by arclength). It
renders much more slowly than the equivalent all-in-one isosurface.
> > For an interesting variation on this theme, see my two recent threads,
> > "MultiMesh" in the General area and "Grass using MultiMesh" in p.b.i.
> Errrrr, I can guess that "multimesh" uses MESH objects,
> What does that have to do with isosurface pebbles?
Read the threads & find out, rock. :) The connection is in efficiently
creating large numbers of similar objects, and hiding the fact that you're
using lots of copies of the same thing.
Download 'isoballsh3s.jpg' (162 KB)
Preview of image 'isoballsh3s.jpg'
Date: 19 Sep 2005 20:38:09
Message: <2879.432f5947.19457@localhost>
  http://www.deviantart.com/view/23117961/
Date: 20 Sep 2005 10:05:01
Message: <web.433014ed8195286cf00e1300@news.povray.org>
Nice, but think this machine would be thrashing the swap file with that
scene, povray!
I don't know if those lobe-shaped stones look real though... and what are
those strange speckled patches on the sand? Totally transparent stones,
coincident with the ground, maybe? I suppose both of these effects could be
intentional.. the lobed stones remind my of an X-files episode, where
Mulder finds a pair of intersecting coins.
I've worked out how easy it is to place my IsoStones on an isosurface, but I
haven't got the look quite right yet.
Date: 20 Sep 2005 10:15:01
Message: <web.4330189c8195286cf00e1300@news.povray.org>
Here's my latest polished-up version. Um, I suppose I should ask, how do I
submit it for consideration, Chris? :)
// Persistence of Vision Ray Tracer Scene Description File
// File: IsoStones.pov
// Vers: 3.6
// Desc: Tumbled stones in a square grid using a single isosurface
// Date: 2005.09.03
// Auth: PM 2Ring
// -D +A0.1 +AM2 +R2
// -F +A0.6 +AM2 +R2
#include "stones.inc"
#include "functions.inc"
global_settings {
  assumed_gamma 1.0
//Scene control
#declare Do_Sky = 1;              //Render sky sphere
#declare Do_Ground = 1;           //Render ground plane
#declare Do_Water = 1;            //Make ground plane reflective
#declare Use_SpotLight = 1;
#declare Use_AreaLight = 0;
//Stone parameters
#declare GridSize = 4;            //Total number of stones =
GridSize*GridSize
#declare Width = 1/GridSize;      //Cell width.
#declare Radius = Width*.70;      //Stone radius
#declare DRate = .875/Radius;     //Radius deformation rate
#declare Height = .55;            //Stone height
//---Functions------------------------------------------------
//Positive modulus: never returns negative values
#declare smod = function(A,B){mod(B + mod(A, B), B)}
//Centred modulus
#declare cmod = function(A,B){smod(A, 2*B) - B}
//2D cells: returns a random value for each unit square
#declare f_cell2D = function(x,z){f_snoise3d(floor(x), 0, floor(z))}
//Noisy modulus. Makes a random centre for each stone
#declare f_modnoise =
function(x,z){cmod(x, Width) + (Width-Radius)*f_cell2D(x*.5/Width,
z*.5/Width)}
//Randomized radius for tumbled stone shape
#declare f_Rad = function{1 + .45*f_snoise3d(x*DRate, y*DRate, z*DRate)}
//Displaced, vertically squashed spheres
#declare f_Stone = function{f_r(f_modnoise(x,z), y/Height,
f_modnoise(-z,x))}
//---Textures-------------------------------------------------
#declare StoneMax=44;             //Number of stone textures
//All the textures from stones.inc
#declare T_Stones =
array[StoneMax]{
  T_Stone1, T_Stone2, T_Stone3, T_Stone4, T_Stone5,
  T_Stone6, T_Stone7, T_Stone8, T_Stone9, T_Stone10,
  T_Stone11, T_Stone12, T_Stone13, T_Stone14, T_Stone15,
  T_Stone16, T_Stone17, T_Stone18, T_Stone19, T_Stone20,
  T_Stone21, T_Stone22, T_Stone23, T_Stone24, T_Stone25,
  T_Stone26, T_Stone27, T_Stone28, T_Stone29, T_Stone30,
  T_Stone31, T_Stone32, T_Stone33, T_Stone34, T_Stone35,
  T_Stone36, T_Stone37, T_Stone38, T_Stone39, T_Stone40,
  T_Stone41, T_Stone42, T_Stone43, T_Stone44,
//Build a random cellfield of all the stone textures
#declare MultiStone =
texture{
  //function{.5+f_cell2D(x,z-7)}
  cells translate y*.5
  texture_map{
  #declare I=0;
  #while(I<StoneMax)
    [I/StoneMax T_Stones[I]]
    [(I+1)/StoneMax T_Stones[I]]
    #declare I=I+1;
//---The scene------------------------------------------------
//The stones. Scaled so that textures appears the same,
//no matter how many stones are done.
isosurface{
  function{f_Stone(x,y,z) - Radius*f_Rad(x,y,z)}
  //function {f_r(cmod(x, Width), y/Height, cmod(z, Width)) - Radius}
  contained_by{box{<-1,-Width*Height,-1>, <1,Width*Height,1>}}
  max_gradient 5
  accuracy 5e-3
  texture{MultiStone scale 2*Width}
  //scale 1.7             //Fill view with stones
  rotate -3*y
  translate <0, .35*Radius*Height-1, 1>
#if(Do_Sky)
  sky_sphere {
      gradient y
      color_map {
        [.4 rgb .1]
        [.9 rgb .8]
        [1 rgb 1]
#else
  background{rgb .5}
#if(Do_Ground)
  plane {
    y, -1.0001
    pigment {rgb <1, .915, .620>}
    finish{
      ambient 0 diffuse .85
      specular .25 roughness 1e-3
      #if(Do_Water) diffuse 0.65 reflection{0, .9} #end
    normal {
       ripples .075
       turbulence .175
       frequency 12
       scale .4
       translate -1
  location  <.45, 8, -8> * .2
  direction z
  right     x*image_width/image_height up y
  look_at   y*-.175
  angle 40
light_source {
  <-1, 1, -1> * 30
  rgb 120 fade_distance 3 fade_power 2
  #if(Use_SpotLight)
    spotlight point_at <-1,-1,0> falloff 2.25 radius .35
  #if(Use_AreaLight)
    area_light 9*x,9*z,7,7 jitter adaptive 1 orient circular
Date: 20 Sep 2005 22:09:58
Message: <4330c0f6@news.povray.org>
PM 2Ring nous apporta ses lumieres en ce 2005-09-20 10:00:
> scene, povray!
It looks like the top layer used in some layered stone textures, without any base
layer.
Date: 21 Sep 2005 09:47:54
Message: <2336.4330a6fc.58560@titanic>
> scene, povray!
Heheh: your machine must be even older than mine.  ;)
After posting it I kind of think they look like cookies.  :D
Mmmmmmm.  :)
Still, now you get the idea what what I was originally talking
about.
I kinda threw the file together quickly.  I arbitrarily took the
first 40 or so textures from stones1.icn without even looking at
them.  That transparent speckle texture is one of the textures in
stones1.inc.
Keep at it.  You'll get there.  :)
Date: 26 Sep 2005 21:20:01
Message: <web.43389e218195286ad93754b0@news.povray.org>
Here are some IsoStones on a sandy isosurface. Max memory = 1082530 bytes.
Download 'isoballsfd0.jpg' (97 KB)
Preview of image 'isoballsfd0.jpg'
