POV-Ray : Newsgroups : povray.binaries.images : IsoStones Server Time
21 Mar 2026 19:53:37 EDT (-0400)
  IsoStones (Message 18 to 27 of 37)
Subject: Re: IsoStones
Date: 14 Sep 2005 10:49:21
Message: <21d7.432838ce.bab81@localhost>
PM 2Ring wrote:
> This group of stones is a single isosurface. The wet sand is a
> normal-perturbed plane. The stone textures are the standard textures
> in stones.inc.
> Now I just need to figure out how to perturb the stones' positions a bit
> more...
Is there a particular reason you desired to make all the stones
one isosurface?  it seems like you'd get a faster render time if
they were seperate objects.  This in turn would allow their
positions to be perturbed more.  I also notice that the rocks
are all smooth.  Perhaps you could use a blob object instead of
an isosurface for a further increase in speed.
I picture something like ... defining 12 different rock shapes.
Then, whenever you place a rock, randomly pick which of the 12
pre-defined rock shapes to place.  Rotate it randomly y before
placing it.  As each one is placed, randomly texture it.
Date: 14 Sep 2005 11:00:00
Message: <web.43283a638195286505e02d50@news.povray.org>
"Nathan Kopp" <pov### [at] nkoppmailshellcom> wrote:
> I never knew that the standard stone textures could look so realistic!
Neither did I, Nathan! Trust me. :)
> I guess they were always used in the wrong context or at the wrong scale.
Well there's no excuse for using them at the wrong scale: it's mentioned in
the include file. :) Of course, we've all probably used them at weird
scales; I know I have. :) You can sort-of get away with it with a plain
granite or other simple fractal, but the complex multilayered textures seem
to have a proper scale associated with them.
> Apparantly you've used them as they were intended to be used.  Very nice!
More luck than true planning on my part, I must confess. I've only recently
started to use lights that fade & they really add to scene realism (thanks
Jaime).
Speaking of Jaime, since reading the LightSys docs I've been seriously
thinking of updating the stones.inc textures. They don't behave well in
radiosity scenes, due to ambient content, but what's worse, they use the
dreaded crand, so they make horrible flying pixels in animations.
These stone textures come from the bad old days, before macros, and probably
before pigment functions (sorry, my POV history is a little rusty at this
hour of the morning :) so I'm sure some interesting things can be done to
modernize these textures and make them more flexible.
Date: 14 Sep 2005 11:35:00
Message: <web.43283e768195286505e02d50@news.povray.org>
> > in stones.inc.
> > more...
For a couple of dozen stones, yes, but not a few million. See the reply I
just wrote to Florian for more on this topic, povray.
> This in turn would allow their positions to be perturbed more.
> I also notice that the rocks are all smooth.  Perhaps you could use
> a blob object instead of an isosurface for a further increase in speed.
Blobs I know well, we had them to play with long before these new-fangled
isosurfaces. :) This scene is partly an exercise in learning how to do
tricky things with isosurfaces.
Also, isosurfaces can be faster than you might think. I have a sofa object
derived from one of Jaime's LightSys demo scenes. The original is built
from isosurface{f_rounded_box()}, I converted it to use superellipsoids,
but the isosurface version was the faster! IIRC, I posted the scene file in
p.b.i a couple of weeks ago; look for the very shiny blue sofa.
Sure, I can do that:). However, you don't really save memory (in the current
version of POV) by doing this, unless you're doing it with mesh objects.
For an interesting variation on this theme, see my two recent threads,
"MultiMesh" in the General area and "Grass using MultiMesh" in p.b.i.
Date: 14 Sep 2005 11:55:00
Message: <web.432846a68195286505e02d50@news.povray.org>
Here it is:  <web.4315a37135b6ce9d60c4f6d10@news.povray.org>
Time it for yourself.
Subject: Re: IsoStones (OT now)
Date: 14 Sep 2005 13:55:10
Message: <432863fe@news.povray.org>
PM 2Ring wrote:
> Thanks, Thomas. If a geologist likes my stones, they must be good! :)
OT, but bumped to mind of this line...
"Everyone, let's thank Thomas"
"Thank you Thomas"
What movie?
Follow-ups to OT...
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 14 Sep 2005 22:16:19
Message: <4328d973@news.povray.org>
As someone else said your IsoStones are very instructive - thanks for
posting the source.
The stone textures - in fact most of the old 3.1 textures - have never been
updated to account for the resulting image being gamma corrected. The 3.1
stone textures for example were to be rendered with an assumed gamma of 2.2.
The automatic portfolio set up INGO put together rendered them with an
assumed gamma of 1.0 just as you too used them. However, used in this way
all these textures will appear washed out compared to the creators intent.
For good reasons we should be using the assumed gamma of 1.0 for renders,
but the majority of the sample textures look washed out if you do it. Leads
to some confusion I think - it certainly confused me for a time.
A_stones.jpg  is my render of your original source using 3.6.
B_stones.jpg uses the assumed gamma of 2.2 so the stones look as they did in
3.1, but naturally the sand and lighting is darker than you intended because
no gamma correction was done - my display gamma is set to 2.2 as is true for
most PC users (1).
C_stones.jpg takes a stab at un-gamma correcting the stone textures so that
when the gamma correction is done the stones appear as I think intended by
the texture creators, but with your lighting and sand color.
(1) - Most all PC displays have a display gamma of about 2.2 except for
Apple, SGI and perhaps a few other less common platforms.
"PM 2Ring" <nomail@nomail> wrote in message
news:web.43283a638195286505e02d50@news.povray.org...
probably
Download 'C_stones.jpg' (95 KB) Download 'A_stones.jpg' (86 KB) Download 'B_stones.jpg' (82 KB)
Preview of image 'C_stones.jpg'
Preview of image 'A_stones.jpg'
Preview of image 'B_stones.jpg'
Date: 14 Sep 2005 23:02:11
Message: <4328e433$1@news.povray.org>
> in stones.inc.
This is nice work. Perhaps once you've finished with your tweaks to it you
may like to consider submitting it (or a variation thereof) for consideration
as a standard POV-Ray example scene.
-- Chris
Date: 15 Sep 2005 03:01:34
Message: <43291c4e$1@news.povray.org>
"PM 2Ring" <nomail@nomail> schreef in bericht
news:web.432834058195286505e02d50@news.povray.org...
> > news:web.43242b50bddb89c077d3bc6c0@news.povray.org...
> > Very, very good!!
<grin>
Date: 15 Sep 2005 21:41:47
Message: <432a22db@news.povray.org>
A derivative work, hopefully okay since the SDL was shared...
Download 'pm2ringstone03.png' (162 KB)
Preview of image 'pm2ringstone03.png'
Date: 17 Sep 2005 08:44:31
Message: <7471.432b7533.6e373@titanic>
well, one sofa is different from many stones: completely
different from the original picture posted.
Memory was not the concern of my posting; render time was.
If I wanted many stones in a single isosurface, my poor
CPU would kick it's little feet in the air and expire.
Or at least my patience would.  :D
Errrrr, I can guess that "multimesh" uses MESH objects,
What does that have to do with isosurface pebbles?
