Heh. That must have taken a stupid amount of time to render... Looks
good tho! (Altho the brown thing looks slightly stuck on - I can't work
out why.)
> out why.)
Didn't take long actually, even with the focal blur. The stone thing needs
some work, but I just wanted to put something in the scene alongside the
grass. Apart from improving the general shape and textureof the blades the
next trick is variable blade lengths, and also I'd like to be able to
define areas within the grass patch which are flattened, as if objects
really are in contact with the blades.
L
Ah, grass... such a simple idea, but...
The blades are different sizes. Some are frayed at the ends. (Perhaps
slightly brown too.) In generall, all the blades vary slightly in
colour. Few people realise, but there's actually more than one *kind* of
grass. (As in, there are several species. And it's not uncommon for them
to coexist in the same space.) And then there's thicker patches, and
thinner patches, and patches where people have walked or other objects
have flattened the grass. And then if the grass has been mowed there may
be cut marks, and bits of clippings left over. And........
Fortunately, most images don't have that much grass in them! ;-)
But despite all that, what you have looks fairly good as it is. Manages
to look suitably "random" without looking stupid.
Actually I only wanted to get this vaguely correct. The idea for a scene I
intend to use it in isn't as close-up as those examples I posted so
hopefully I won't need to implement too much more detail. Some extra
stragglyness would be nice, and slight variations in colour (particularly
patchy areas of lighter, drier grass) but I expect the general effect to be
ok. The grass won't be the focal point of the image anyway. I'm more
concerned with getting objects to nestle in the grass convincingly.
L
Subject: Re: Grass experiment (How do I attach two images to one post btw?)
Date: 3 May 2005 20:17:20
Message: <42781490$1@news.povray.org>
Loki nous apporta ses lumieres en ce 2005-05-03 11:16:
You are sing Mozilla. After you have attached the first image, you just repeat the
process for the
second and other files. You will see the various files in a list following the first.
> ok.
I've seen people do grass with two layers: one green, one yellow/brown,
with the brown grass being a bit smaller and thinner. It looks quite
convincing if it's done right.
-Xplo
> -Xplo
Nice one, I'll give that a try later on.
@Alain, I'm not using Mozilla, it's IE here I'm afraid...
L
The web interface will indeed only allow a single attachment. IMHO
you're better off using the nntp interface via Outlook or Thunderbird or
some other nntp client.
Cheers!
Rick Measham
Loki nous apporta ses lumieres en ce 2005-05-04 04:08:
>>-Xplo
> L
The header say Mozilla, look at the "x-User-Agent line from the header of your post:
Date: Wed, 4 May 2005 04:08:49 EDT
Newsgroups: povray.binaries.images
Message-ID: <web.4278831144fc1559c5461abd0@news.povray.org>
References: <42784696$1@news.povray.org>
Mime-Version: 1.0
Content-Type: multipart/mixed; boundary="------boundary00xxzz99pov77ccvv44"
X-Source:
+BQH/zIl/fwDCAP0BhMLNQgw8x81CSHrBjMADzUADwntMgAJlYl454PCi5/dlaikwrqHy666p92c3WqV3YyowsfAg6Ddv37Z
X-Newsreader: POV-Ray Web Interface
---> X-User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR
1.1.4322)
NNTP-Posting-Host: 203.29.75.35
> of your post:
> .NET CLR 1.1.4322)
Alain, read again .. It says MSIE 6.0. Most broswers claim to be a
Mozilla browser and then include the word 'compatible'. If you read the
previous line, you see that the newsreader is the web interface which
only allows a single attachment per post.
Cheers!
Rick Measham
