The leftmost sphere in each image has no dispersion. The remaining
spheres have dispersion_samples set to the number above each. The first
image uses faked caustics and the second uses photons.
It seems that the smaller the dispersion_samples, the darker the glass.
Could this be the 2 missing dispersion samples making their absence felt?
_____________________________________________________________________
#include "consts.inc"
#include "transforms.inc"
#declare Test = sphere
{ y, 1
pigment { rgbf 1 }
finish
{ reflection { 0 1 fresnel } conserve_energy
specular 1 roughness 0.001
photons { target reflection on refraction on collect off }
interior
{ ior Crown_Glass_Ior dispersion Quartz_Glass_Dispersion
#if (!PH) caustics 1 #end //PH is defined elsewhere
union
{ object { Test interior { dispersion 1 } translate -3.6 * x }
#declare T = 4;
#while (T <= 8)
#declare Samps = text
{ ttf "arial.ttf" str(T,0,0) 0.01, 0 scale 0.6
pigment { rgb x }
no_shadow no_reflection
union
{ object { Test interior { dispersion_samples T } }
object { Samps Center_Trans (Samps, x) translate 2.25 * y }
translate (T * 1.2 - 6) * x
#declare T = T + 2;
<Insert witty .sig here>
Download 'dispersion_light.jpg' (51 KB)
Download 'dispersion_light-ph.jpg' (52 KB)
Preview of image 'dispersion_light.jpg'
Preview of image 'dispersion_light-ph.jpg'
Personally, I'm not seeing anything, and I rendered the objects myself with the
latest beta. It might be nice if you included your global photon settings, and
perhaps the light source. The problem might be differences in
viewing angle, angle of incidence, that kind of thing.
Try rendering each one from the same angle. Rather than using a loop render the
scene as frames of an animation with your parameters tied to the frame_number.
Slice the images up and set each sphere side-by-side for comparison.
A.D.B.
> { y, 1
> pigment { rgbf 1 }
> finish
> interior
> union
> #declare T = 4;
> #while (T <= 8)
> pigment { rgb x }
> union
> #declare T = T + 2;
> #end
Top row was run with +kff5 declare=Ph=0 (faked caustics).
Bottom row was run with +kff5 declare=Ph=1 (photons).
Left half of each sphere has no dispersion; right half has dispersion_samples
set to the number in the frame.
#ifndef (Ph) #declare Ph = no; #end
global_settings
{ assumed_gamma 1
max_trace_level 256
#if (Ph) photons { spacing 0.005 autostop 0 } #end
camera
{ location -5 * z
right x up y
angle 30
sky_sphere { pigment { gradient y color_map { [0 rgb 0.9] [1 rgb 0.5] } } }
light_source
{ <0, 1, -1> * 1000, rgb 1
parallel point_at 0
plane { y, -1 pigment { rgb 1 } }
sphere
{ 0, 1
pigment { rgbf 1 }
finish
interior
{ ior 1.5
#if (frame_number > 1)
dispersion 1.05
dispersion_samples frame_number * 2
#if (!Ph) caustics 1 #end
text
{ ttf "cyrvetic.ttf" str (frame_number * 2, 0, 0) 0.01, 0
pigment { rgb x }
scale 0.4
translate <0.65, 0.65, -1>
Download 'splice.png' (69 KB)
Preview of image 'splice.png'
