POV-Ray : Newsgroups : povray.binaries.images : Mandelbulb test renders Server Time
13 Mar 2026 05:03:24 EDT (-0400)
  Mandelbulb test renders (Message 11 to 20 of 20)
Subject: Re: Mandelbulb test renders
Date: 30 Nov 2009 05:05:03
Message: <web.4b1397c91cd673e3f99d05c80@news.povray.org>
To continue with test renderings, here's a 1920x1080 view of the tail end of the
power 8, iteration 7 mandelbulb.  [WARNING: 3MB]
To fill the shadows, I've found using radiosity renders quicker than adding even
a tiny area light.
Also, recursive anti-aliasing seems to make the best images.  When using lower
radiosity for darker shadows, the settings +A0.5 +AM2 +R2 -J work well.
Download 'mb8i7_tail.png' (3322 KB)
Preview of image 'mb8i7_tail.png'
Date: 5 Dec 2009 13:15:03
Message: <web.4b1aa2991cd673e3f99d05c80@news.povray.org>
This is the first image I'm really happy with, another view of the tail end of
the power eight mandelbulb after six iterations.  Although I forgot to save the
rendering information for this image, it took about as long as other similar
images with my latest mandelbulb isosurface SDL function, about eight hours on
an eight-core Linux machine using an unpatched POV-Ray beta with radiosity and
recursive anti-aliasing -J +A0.5 +AM2 +R2.  For those interested, I've posted
some more images on my website.
http://wiki.waggy.org/dokuwiki/mandelbulb
Cheers!
Download 'mb8i6_tail_up_1920q4.png' (2813 KB)
Preview of image 'mb8i6_tail_up_1920q4.png'
Date: 9 Dec 2009 08:31:41
Message: <4b1fa6bd$1@news.povray.org>
> Cheers!
The animation is impressive.
Paolo
Date: 16 Dec 2009 11:00:01
Message: <web.4b2903721cd673e3f99d05c80@news.povray.org>
I found a way to make "hybrid" mandelbulbs combining two different powers.  It's
a simple adjustment with no practical impact on computational time.
newx = r^n1 * sin(theta*n1) * cos(phi*n2)
newy = r^n1 * sin(theta*n1) * sin(phi*n2)
newz = r^n1 * cos(theta*n1)
As a sample, I attached a test render of an 8,4-power mandelbulb.
Download 'mb84_full.png' (327 KB)
Preview of image 'mb84_full.png'
Date: 16 Dec 2009 11:20:02
Message: <web.4b2907b11cd673e3f99d05c80@news.povray.org>
The smoothing function I'm using can give an interesting dissolution effect as
well as "free" iterations, and I attached an image to illustrate this.
The iteration level of the power-8 mandelbulb shown varies smoothly from two at
the bottom to six at the top, though the iterating function never went beyond
the four iterations shown in the middle.  The return value after four iterations
can be used to generate a reasonably accurate isosurface of up to about five
iterations.  The number of "free" iterations increases with the number of actual
iterations (the max_iteration parameter).
Beyond those accurate "free" iterations, the smoothing function returns values
that can be used for the interesting dissolution effect seen toward the top.
On another note, I'm satisfied enough with the function to recode it in C++ and
compile it into the current POV-Ray beta.  Preliminary results indicate about a
5-6x speedup over the recursive SDL version.  After a bit more testing I'll post
the patch to the appropriate newsgroup.
Download 'mb8i4q1_vary_i.png' (293 KB)
Preview of image 'mb8i4q1_vary_i.png'
Date: 16 Dec 2009 15:59:58
Message: <4b294a4e$1@news.povray.org>
Woops.  I think the image is of a n1=p_theta=4, n2=p_phi=8 'bulb.  It
was late.
Also, I did a little experimentation (with the SDL version), and it
looks worthwhile to allow three independent powers, like this.
newx = r^p_r * sin(theta*p_theta) * cos(phi*p_phi)
newy = r^p_r * sin(theta*p_theta) * sin(phi*p_phi)
newz = r^p_r * cos(theta*p_theta)
Now I need to refigure what log base to use for the smoothing function
(it was originally just base "p"), then recompile...again...
Would it be worthwhile to add two functions, f_mandelbulb() for the
single-powered 'bulb, and f_mandelbulb3() for the multi-powered one?
I'm thinking of just specifying the triple-powered version, and leave it
to users to declare a single-power function if they so desire...
#declare my_mandelbulb = function(x,y,z, my_power,
       my_i_bailout, my_r_bailout)
    f_mandelbulb(x,y,z, my_power,my_power,my_power,
P.S.  I've switched to using a "p" to indicate the [p]ower (as is done
in some of the literature) to avoid confusion with the [n]umber of
iterations.
Date: 16 Dec 2009 21:00:01
Message: <web.4b29908a1cd673e3f99d05c80@news.povray.org>
Here, a cylindrical coordinate transformation splits the power 8 'bulb at the
seam, and unrolls it endlessly along the x-axis.  It might make a nice cornice
or something.
It's called like this.
isosurface{
    function{f_mandelbulb(y*cos(x),y*sin(x),z, mb_power_theta, mb_power_phi,
int(mb_iterations-1), mb_rdiverge)}
  contained_by{box{<-100*pi,0,-1.2>,<2*pi,1.2,1.2>} }
Download 'mb8i5q0_unrolled_640a.png' (307 KB)
Preview of image 'mb8i5q0_unrolled_640a.png'
Date: 17 Dec 2009 01:18:37
Message: <4b29cd3d$1@news.povray.org>
> or something.
> isosurface{
And this is what everyone on the fractal forums is missing - artistic
modifications of the shape just for fun. I can see this type of mapping
producing some very interesting shapes!
I'm very much hoping that your f_mandelbulb() is included in the next
beta, so I can start playing with it. Using the df3 approach is limiting
the resolution for me too much now, and taking way too much time/space
for what can be done better this way.
I'd use the patch now, but don't have the ability to compile windows
builds, and I haven't had luck extending the expiration on home-compiled
linux builds.
Once the number of entries bug is fixed in color_map I'll post my
Fractint color map to pov color map converter, which will let you take
generated maps from ApoMap (and Apophysis itself). Should be a fun way
to get more coloring.
Date: 20 Apr 2011 02:25:00
Message: <web.4dae7c201cd673e33931e4fb0@news.povray.org>
The following code is not very inefficient, but it demonstrates how you can
render the Mandelbulb in POV-Ray as an isosurface using recursive functions:
// Quadratic Mandelbulb: runtime: 4.5 minutes
camera{location <-2.5,5,5> look_at <-0.5,0,0.25> up z sky z angle 25}
light_source{20*z,1}
#declare f=function(i,x,y,z,xc,yc,zc) {select(i>0 & x*x+y*y+z*z<4, 0,
sqrt(x*x+y*y+z*z),
f(i-1,(x*x-y*y)*(1-z*z/(x*x+y*y))+xc,2*x*y*(1-z*z/(x*x+y*y))+yc,-2*z*sqrt(x*x+y*y)+zc,xc,yc,zc))};
isosurface{function{f(24,x,y,z,x,y,z)} threshold 2 max_gradient 10
contained_by{sphere{<-0.5,0,0>,2}} pigment{rgb 1}}
// Power Mandelbulb: runtime: 28 minutes
camera{location <1.75,4,5.5> look_at 0 up z sky z angle 25}
#declare n=8;
sqrt(x*x+y*y+z*z),f(i-1,pow(x*x+y*y+z*z,n/2)*cos(n*atan2(y,x))*cos(n*atan2(z,sqrt(x*x+y*y)))+xc,pow(x*x+y*y+z*z,n/2)*si
n(n*atan2(y,x))*cos(n*atan2(z,sqrt(x*x+y*y)))+yc,-pow(x*x+y*y+z*z,n/2)*sin(n*atan2(z,sqrt(x*x+y*y)))+zc,xc,yc,zc))};
isosurface{function{f(24,0,0,0,x,y,z)} threshold 2 max_gradient 1000
contained_by{sphere{0,1.5}} pigment{rgb 1}}
I also posted this sample code here:
http://www.bugman123.com/Hypercomplex
Download 'mandelbulb.jpg' (47 KB)
Preview of image 'mandelbulb.jpg'
Date: 20 Apr 2011 02:50:00
Message: <web.4dae81a31cd673e33931e4fb0@news.povray.org>
Also, here is some code for a Mandelbrot - Tricorn:
camera{location <-3.5,5,4> look_at <-0.5,0,0.4> up z sky z angle 25}
sqrt(x*x+y*y+z*z), f(i-1,x*x-y*y-z*z+xc,2*x*y+yc,-2*x*z+zc,xc,yc,zc))};
isosurface{function{f(24,x,y,z,x,y,z)} threshold 2 max_gradient 25
Download 'tricorn.jpg' (22 KB)
Preview of image 'tricorn.jpg'
