This one takes a pigment and blurs the image by an amount depending on
the color of the pigment. I think it makes a good "rain on the lens"
effect...
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
Personal Web page: http://chrishuff.dhs.org/
Download 'pattern_blur.jpg' (17 KB)
Preview of image 'pattern_blur.jpg'
Hey, it really does look like rain! (You might want to work on the color_map
just a smidgen, though).
Subject: Re: patterned_blur filter - pattern_blur.jpg (1/1)
Date: 28 Apr 2000 12:22:19
Message: <3909babb@news.povray.org>
Is this on a separate plane between the camera and scene?
Not so much a rain on a lens effect as it is a rain on printed paper effect.
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-2CD505.09231628042000@news.povray.org...
| effect...
| TAG Web page: http://tag.povray.org/
In article <3909babb@news.povray.org>, "Bob Hughes"
I'm not sure what you mean...it is a post_process filter, not a part of
the scene, it is applied to the image itself.
What it does is evaluate the the pigment as though the upper-left corner
is <0,0,0> and the lower right is <1,1,0>.(that should probably be
changed to <0,1,0> and <1,0,0> though, to make image_maps easier to use)
Date: 28 Apr 2000 14:22:35
Message: <3909d6eb@news.povray.org>
Oops, my mistake. Wasn't thinking "post-process" entirely.
I got it in my mind this was a type of thing where
you specify color mapping to apply the effect. Akin to HF and such things
where the color value makes the change.
What I'm confused about is about the contribution the scene itself makes.
That only gets affected it appears and does not do the actual effect?
If I'm not confusing you now, what I see when looking at it seems
to be using a normal on a plane having the 'spotted' pattern and a ior in
just those few places instead of throughout. I realize this isn't the case.
news:chrishuff_99-E27878.11505828042000@news.povray.org...
In article <3909d6eb@news.povray.org>, "Bob Hughes"
> Oops, my mistake. Wasn't thinking "post-process" entirely. I got it
> in my mind this was a type of thing where you specify color mapping
> to apply the effect. Akin to HF and such things where the color
That is the way it works...it is just a post_process blur filter where
the amount of blur is controlled by a pigment.
The image of the scene gets blurred...but the amount of blur does not
depend on the scene, just on a pigment.
> case.
It is a blurring effect where the amount of blur is controlled by a
"bozo" pattern. It has a sharp cutoff(partly because of the "plateaus"
of the pattern), so it looks like drops instead of just blurry areas.
Date: 28 Apr 2000 17:27:35
Message: <390a0247@news.povray.org>
Ah, okay. That Jpeg compression doesn't help any when
trying to see what's affected and what's not. I wasn't sure if those spots
were the only areas and I still can't tell when going back to have a
look again. Something to watch out for if accurate representations of such
things are to be seen correctly.
Sure I'm not saying anything you didn't know but just didn't occur to you.
news:chrishuff_99-22E98E.14320828042000@news.povray.org...
| > case.
