Still playing with the X', tying to make a texture with it. But I encounter
black lines and can't find a reason for it in the scene. What causes it? Or
is it inaccuracy of Povray (MegaPov)?
Ingo
#version unofficial MegaPov 0.5;
global_settings {assumed_gamma 1.0}
light_source {
< 500,500,-500>
rgb 1
location <0,0,-6.0>
look_at <0,0, 0.0>
#declare Letter= text {
//X: <0,0,0>,<0.70314,0.6773,1>
ttf
"times.ttf"
"X"
1,0
scale <1/0.7,1/0.66,1> //<1/0.7,1/0.665,1>
translate <0,0,-0.5>
/*#declare xPigm= function {
proximity {
Letter, 0.2
method 0
samples 5 //25
sample_bailout 500
max_density 1.0
type 1
sides 1
warp {repeat x}
warp {repeat y}
object {
Letter
pigment {rgb 1}
pigment {rgb 0}
warp {repeat x}
warp {repeat y}
#declare xWrink= function {
agate
colour_map {
[0, rgb 0]
[1, rgb 0.8]
#declare XsinPigm= pigment {
function {xPigm(sin(x),sin(y)^2,z) & xWrink(x,y,z)}
scale 1 //0.6
//rotate <90,0,0>
colour_map {
[0, rgb 1]
[1, rgb 0]
box {
<-7.5,-5,0>,<7.5,5,0.1>
pigment {XsinPigm}
Pov-Ray : http://members.home.nl/seed7/
Download 'XXX#3.jpg' (22 KB)
Preview of image 'XXX#3.jpg'
In article <8F3BD8EFAseed7@204.213.191.228>, ing### [at] homenl (ingo)
> encounter black lines and can't find a reason for it in the scene.
> What causes it? Or is it inaccuracy of Povray (MegaPov)?
It is a precision problem, similar to the coincident surfaces problem.
Try replacing xPigm with this version, scaled and translated to avoid
the problem:
#declare xPigm =
function {
object {Letter
pigment {rgb 1}
pigment {rgb 0}
warp {repeat x}
warp {repeat y}
scale < 1, 1.00002, 1>
translate < 0,-0.00001, 0>
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
Personal Web page: http://chrishuff.dhs.org/
>the problem:
Thanks Chris, that does the trick.
Ingo
I tried it with arial.ttf and i get them too.... strange... maybe it is the
way Povray(Megapov) reads the files....
> Ingo
> light_source {
> < 500,500,-500>
> rgb 1
> camera {
> location <0,0,-6.0>
> look_at <0,0, 0.0>
> ttf
> "times.ttf"
> "X"
> 1,0
> pigment {
> proximity {
> Letter, 0.2
> method 0
> samples 5 //25
> sample_bailout 500
> max_density 1.0
> type 1
> sides 1
> warp {repeat x}
> warp {repeat y}
> pigment {
> object {
> Letter
> pigment {rgb 1}
> pigment {rgb 0}
> warp {repeat x}
> warp {repeat y}
> pigment {
> agate
> colour_map {
> [0, rgb 0]
> [1, rgb 0.8]
> scale 1 //0.6
> //rotate <90,0,0>
> colour_map {
> [0, rgb 1]
> [1, rgb 0]
> box {
> pigment {XsinPigm}
> Photography: http://members.home.nl/ingoogni/
> XXX#3.jpg Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
