I have made the following simple image. It renders in under 4 minutes.
To my astonishment the addition of a text object causes a render time
43times longer than without. The source is included and contains the
version with the textobject.
At 576x432:
with Textobject : 2h 54m
without Textobject: 0h 4m
Also the statistics tell me:
Ray->Shape Intersection Tests Succeeded Percentage
True Type Font 60249600 11479 0.02
Why? Can anybody explain?
Lo van den Berg
lov### [at] yahoocom
Download 'joy_0.03.49.jpg' (49 KB)
Download 'us-ascii' (3 KB)
Preview of image 'joy_0.03.49.jpg'
Pardon me for my rudeness but...
What is your point?
Text Objects take a long time to render in Pov?
I cannot provide you with a technical explanation
of this.
You have posted an interesting image.
Peter Warren
war### [at] hotmailcom
> What is your point?
> of this.
From a conversation with Ron Parker:
The text object is represented as a CSG union, with each glyph being a
separate object. A glyph is represented internally as a series of quadratic
curves (which require a large number of mathematical calculations).
To test for insideness, POV first makes sure the point is between the front
and back planes of the glyph, then makes sure the projection of the point
into X,Y space falls inside the glyph representation by counting crossings.
To intersect a ray, POV first finds the intersection points of the ray
with the front and back planes. Those points are projected onto the plane
and tested to make sure they're inside the glyph representation before
being pushed onto the intersection stack. Finally, it projects the ray
itself into the plane (skipping the case where the ray is parallel to the
extrusion direction) and tests the projection of the ray against each curve
in the glyph representation.
Now if we take what we learned above it becomes apparent that the text
object in it's own right requires quite a few calculations to represent
properly. If we now use the text object in a CSG operation we add greatly
to the number of ray intersection tests needed which consequently adds to
the render time of the scene it is used in.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Hello,
a simple solution is to use Elefont (http://www.armanisoft.ch)
it's free. The text will be save as DXF. After you transform DXF to
POV with Crossroad (http://www.europa.com/~keithr/crossroads/) or
with 3DWin (http://www.stmuc.com/thbaier/). Then the text will be a
mesh (use WinMeshComp
(http://www.geocities.com/SiliconValley/Lakes/1434/download/mc21win.zip)
to reduce the size of the include and/or to transform into Mesh2 if you
use MegaPov). Mesh and Mesh2 are much fast to render than text object.
I hope this help.
Fabian Brau.
Lo van den Berg wrote:
> Hi,
> At 576x432:
> Lo van den Berg
> [Image]
> #include "colors.inc"
> #include "metals.inc"
> #include "golds.inc"
> // -----------------TEXTURES---------------
> #declare Tx1=texture {
> T_Gold_5D
> normal {
> granite .35
> turbulence .25
> frequency 5
> scale 2.111
> #declare Tx2=texture {
> T_Chrome_2A
> normal {
> bumps .81
> turbulence .77
> finish {
> reflection 0.1
> metallic
> scale 2.21
> #declare BaseTexture=texture {
> pigment { color White }
> finish { reflection 0.23 }
> #declare RecursionTexture=texture {
> pigment { color Black }
> finish { reflection 0.43 }
> #declare JoyTexture=texture {
> pigment {
> color rgb <24/255,107/255,165/255>
> finish {
> reflection 0.6
> #declare MaterialTexture=texture {
> material_map {
> gif "joy.gif"
> interpolate 2
> texture { RecursionTexture }
> texture { JoyTexture }
> rotate 90*x
> // -----------------MACROS---------------
> #macro RecText( iRecLevel,iScaleFraction,iBaseTexture,iRecTexture )
> texture {
> checker
> texture { iBaseTexture }
> #if (iRecLevel=0)
> texture { iRecTexture }
> #else
> RecText( iRecLevel-1,iScaleFraction,iRecTexture,iBaseTexture )
> scale 1/iScaleFraction
> #end
> #end
> plane {
> y, 0
> RecText( 2, 3, MaterialTexture, RecursionTexture )
> camera
> location < 0.0, 2.0,-7.0>
> look_at < 0.0, 0.5, 0.0>
> // look_at < 0.0, 0.0,-7.0>
> light_source
> < 0.0, 20.0, -20.0>
> color White
> light_source
> < 20.0, 25.0, -25.0>
> color White
> difference {
> plane {
> z, 0
> texture {
> material_map {
> gif "joy.gif"
> interpolate 2
> once
> texture { pigment { color rgbt <0,0,0,1> } }
> texture { Tx2 }
> translate <-0.5,-0.03, 0.0>
> scale 3
> bounded_by {
> box { <-1.5, 0.0,-0.01>,<1.5,3.0,0.01> }
> text {
> ttf "timrom.ttf"
> "High Tech Automation"
> 0.1, 0
> scale 0.15
> translate <-0.2, 2.6,-0.01>
> hollow
> intersection {
> plane {
> z, 0
> texture {
> material_map {
> gif "joy.gif"
> interpolate 2
> once
> box {
> < 0.01,0.01,-0.01>, < 0.99,0.99,0.01>
> translate <-0.1,-0.03,-0.3>
> scale 3
> hollow
> light_source {
> < 3,4,-3>,
> color White
> spotlight
> radius 15
> falloff 20
> point_at <0,1.5,-0.3>
> fog {
> fog_type 2
> color rgbt <1,1,1,0.3>
> distance 10
> fog_offset 0
> fog_alt 1
Well, thanks for the tips and the information...
Lo van den Berg
In article <389AE2C2.30701F15@pacbell.net>, lin### [at] povrayorg
Also, the text object is differenced from a plane. Since a plane is
infinite, the combination of plane - text object is tested for every
pixel. If you used a large box instead of a plane, you would probably
notice a big increase in rendering speed, since the object can be
bounded so it is only tested for in a specific area. To possibly get
even more of a speedup, use a separate box for the area with the text
object differenced from it, and surround it with other boxes to create a
seamless floor.(confining the area with the text object CSG to as small
an area as possible)
Chris Huff
e-mail: chr### [at] yahoocom
Wasn't it Lo van den Berg who wrote:
>Hi,
>At 576x432:
I can't really explain the exact technical details about what is
happening, but I can give you a rough idea, and provide a fix.
What's happening is that the automatic generation of bounding slabs has
some sort of a problem with CGI differences, and this is causing it to
check for intersections with the text in lots of places where the text
can't possibly be.
The fix is to add a manual bounding box to the text, like:-
text {
ttf "timrom.ttf"
0.1, 0
scale 0.15
bounded_by {
box { <-0.2, 2.6,-0.01>,<1.5,3.0,0.01> }
With this slight change, you'll find that the version with the text
renders in only twice the time of the textless version, and there'll
only be 602,080 True Type Font tests instead of 60,249,600
In article <mYR### [at] econymdemoncouk>, Mike Williams
> can't possibly be.
Probably due to the plane being an infinite object. Oh, and it's CSG,
not CGI. :-)
Why did I not think of this? It is much better than my previously
suggested box method...although a box is a bit faster than a plane
anyway. Try using a single large box(instead of a plane) and also
bounding the text object.
I still can't see how I missed that bounding thing... :-(
Chris Huff
I thought about it about 5 min. after I posted my response but
without first testing to see if it made an appreciable difference
I decided to remain silent instead - I didn't have time to test
it.
