I just finished the object part of the particle_system patch, and have
implemented object interaction. The particle_system object is actually
an automatically generated blob, though the syntax looks like a separate
object. I might turn it into a blob component eventually.
These are two images of the same system: A single particle emitter at
the left, spraying particles along the surface of a plane toward a
slightly offset sphere.
Christopher James Huff - Personal e-mail: chr### [at] maccom
TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
Download 'particleSystemA.jpg' (17 KB)
Download 'particleSystemB.jpg' (16 KB)
Preview of image 'particleSystemA.jpg'
Preview of image 'particleSystemB.jpg'
Subject: Re: Particle blobs - attached files (1/1)
Date: 28 Jun 2000 14:56:58
Message: <395a4a7a@news.povray.org>
Make it transparent, add a very small spotted white texture and you have
foam on the crest of a wave!
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-4B2C3F.12370928062000@news.povray.org...
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Does this particle system include collision detection? (Please say yes...)
In article <395a4b25@news.povray.org>, "Tony[B]"
Yes, that is what I mean by object interaction. The particles don't
interact with each other yet, but they do bounce off of specified
objects. Look at the second image, with the sphere splitting the
"stream" into two.
Drool... me want particles... :-}_
> the "stream" into two.
I thought that's what I saw. Joy.
That's great, Chris! Do you call it like a standard object? It seems to use
trace, does it? I hope your patch makes it into the next MegaPov release :)
~Sam
> [Image]
> [Image]
At the moment, it can be called as an object or a pattern. I may change
it so it is a blob component type, and remove the pattern(which is
unnecessary with the additions I have made to blob_pigment).
> It seems to use trace, does it? I hope your patch makes it into the
Depends on what you mean...it uses the same internal functions that
POV-Script trace() does, but it doesn't use the internal Trace()
function.
I forgot to ask, if you get interaction between particles worked in, will
the spray let you use any object? Like if I wanted grain to pour out of a
tube, etc.
> function.
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
In article <395A766A.F93A0502@aol.com>, SamuelT <STB### [at] aolcom>
> tube, etc.
Hmm, I was actually only planning on point or sphere particles, though
possibly a way to specify a particle object and a "rotational jitter"
amount. I also wasn't planning on actual particle-particle collision
detection, just attractive/repulsive fields.
Doing collision detection between two arbitrary objects would be very
difficult, approximating them with spheres would probably be sufficient
for most cases.
What would be very nice would be the ability to specify a macro for
creating particles. The POV engine would pass position, velocity,
temperature, age, and other particle data to the macro through it's
parameters, the user would write the macro to create the particles
themselves. I have no idea how to do this, but I do plan on looking into
it.
Hi Chris!
The particle_system very interesting!
I have some questions:
Is the particle_system frame independent? That is, when animated, is it
relying completely on the clock, and not on saving data between the frames?
Or is it frame dependent, that is, you may not get the same result when you
render an animation with 20 frames and another with 100 frames. I hope it is
frame independent.
How does the collision detection work? Do you have to specify all objects
the particles should detects, or does it automatically detect all objects in
the scene? I hope it detects all objects automatically, maybe with an option
to turn detection *off* for specified objects, rather than having an option
turning detection *on* for specified objects. But I may not have thought
this through well enough...
Anyway, as I said, seems very interesting!
Greetings,
Rune
Updated June 12: http://rsj.mobilixnet.dk
3D images, include files, stereograms, tutorials,
The POV Desktop Theme, The POV-Ray Logo Contest,
music, 350+ raytracing jokes, and much more!
