POV-Ray : Newsgroups : povray.binaries.images : Height field macros - attached files (1/1) Server Time
14 Apr 2026 00:28:30 EDT (-0400)
  Height field macros - attached files (1/1) (Message 11 to 20 of 20)
Subject: Re: Height field macros - attached files (1/1)
Date: 4 Mar 2001 13:21:32
Message: <3AA286FF.6BBED86F@faricy.net>
Is this standard POV? How are you evaluating the pigment?
Date: 4 Mar 2001 14:24:25
Message: <chrishuff-0E1B08.14212604032001@news.povray.org>
In article <3AA286FF.6BBED86F@faricy.net>, David Fontaine
Yes/no...it requires MegaPOV or POV 3.5.
With the eval_pigment() function.
Christopher James Huff
Date: 4 Mar 2001 14:29:01
Message: <chrishuff-A23C6C.14260404032001@news.povray.org>
In article <3AA27C54.A661D09B@gmx.de>, Christoph Hormann
<chr### [at] gmxde> wrote:
> I think i also understand better now how it works, more like a displace
> warp for the surface, right?
No. While I do plan to add a feature that can displace the surface in
other ways, the surface is only displaced along it's original normal,
just like the height_field object.
Date: 4 Mar 2001 15:22:00
Message: <3AA2A3E8.36F5245@gmx.de>
All right, now i think i got it :-)
Date: 4 Mar 2001 18:29:33
Message: <3aa2cfdd@news.povray.org>
Where?! When?! Who?! What?!
LOL!
Date: 4 Mar 2001 19:00:10
Message: <chrishuff-354E3B.18571104032001@news.povray.org>
In article <3aa2cfdd@news.povray.org>, "Tony[B]" <ben### [at] catholicorg>
MegaPOV? Where: http://nathan.kopp.com/patched.htm, When: now, Who:
Nathan Kopp, What: an unofficial version of POV-Ray.
Oh, you meant POV 3.5? Where: http://www.povray.org/, When: when it's
released, Who: the POV-Team, What: the next official version of POV-Ray.
I should have written it this way: "it currently requires MegaPOV but
will work under 3.5 when it is released". Sorry to get you so exited...
Date: 4 Mar 2001 22:38:19
Message: <3AA30972.5880067E@faricy.net>
Okay. I was wondering how you might have eval_pigment()ed in 3.1...
Date: 5 Mar 2001 02:14:43
Message: <3aa33ce3@news.povray.org>
This look like just the thing I need for my 'spherical Mandel mountain'. -
when you've figured out the smoothing that is.
Good luck with the smoothing.
Nekar Xenos
Chris Huff <chr### [at] maccom> wrote in message
news:chrishuff-26BCD9.13120903032001@news.povray.org...
> These macros generate height field meshes from pigments from within POV.
> SquareHF.jpeg is an ordinary square height field, like the
> height_field {} primitive object in POV.
> SphereHF.jpeg is the first type of spherical height field, using a 2D
> square wrapped around a sphere with spherical coordinates.
> Sphere2HF.jpeg is the second type of spherical height field, generated
> by recursively subdividing an octahedron, dividing each triangle into 4
> triangles. This doesn't have the "pinching" toward the y axis like the
> first type does.
> I still haven't done smoothing, I'll try to figure out a good way to do
> it.
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 5 Mar 2001 11:31:22
Message: <Xns905BB27653D2Aseed7@povray.org>
in <chrishuff-26BCD9.13120903032001@news.povray.org> Chris Huff
>do it.
How about brute force, patching Warp's mesh_smoother into Povray.
mesh{
  triangle<...>
  triangle<...>
  smooth {angle 89}
Also for making bumpmapping and mesh deformation macros it would be
handy if there was a way to access the vertex/normal/uv-vectors,
indices and lists as arrays.
mesh2arr(Mesh, vv_arr, nv_arr, tl_arr, fi_arr ...etc)
Ingo
Date: 5 Mar 2001 12:07:18
Message: <chrishuff-192BC1.12035705032001@news.povray.org>
In article <Xns### [at] povrayorg>, ing### [at] homenl (ingo)
> >do it.
> mesh{
>   triangle<...>
>   triangle<...>
>   smooth {angle 89}
Well, I don't want to make these macros rely on a patch that isn't in
MegaPOV and won't be in POV 3.5. Anyway, I think I have figured out a
way to do it using the displacing pigment that would be even better than
anything that could be done with the triangle data alone.
However, having "post processes" for meshes, things like subdivide,
smooth, etc, is something that I've been thinking of for a while.
Unfortunately, I can't even get a simple warping to work correctly...it
appears that the mesh code was written for the mesh object, and only the
mesh object, it isn't very friendly for other uses. Maybe there's
something in Warp's tesselation patch that will be useful for this,
though...
