POV-Ray : Newsgroups : povray.binaries.images : M over P - 1 attachment Server Time
15 Apr 2026 00:55:57 EDT (-0400)
  M over P - 1 attachment (Message 21 to 27 of 27)
Subject: Re: M over P - revision 2
Date: 2 Nov 2001 13:10:40
Message: <3BE1E4EE.D6941BC@ndh.net>
High! ;-)
Coridon Henshaw schrieb:
> Yadgar <j.b### [at] ndhnet> wrote in news:3BE17DEF.FC307C13@ndh.net:
> > Is your planet intended to have an atmosphere? If yes, then perhaps a
> > narrow seam of media along the horizon could be appropriate!
> <cough> Look closely at the limb on the left hand side.  Also look for the
> whispy dust clouds in the lower right.  The entire planet is contained in a
> media.
Yes, I see... but the moon is still completely featureless, as if it was
engulfed in a global dust storm, like Mars was back in 1971 at the arrival of
Mariner 9 (and also this year was... hoping the dust settles in the coming
months, otherwise bad luck for Odyssey Orbiter!)... sorry, but I just can't
keep back the astronomy/space flight geek in such a context!
By the way, which image map did you use for the planet? A real map of Mars?
> Anyhow, here's revision 2 -- at 1024x768x24bpp.
The ship looks wicked... are the groups of three blue triangles on the hull
simply ambient 1 finish or is there more about them?
See you in Khyberspace - http://www.geocities.com/electricafghan/index-e.html
Afghanistan Chronicle: http://www.ndh.net/home/bleimann/
Yadgar
Subject: Re: M over P - 1 attachment
Date: 2 Nov 2001 17:51:55
Message: <3BE332E8.B249CD3C@ndh.net>
Francois Labreque schrieb:
> >>Any comments?
> >> [Image]
> > Really cool... but obviously it is not Mars (Mars has only two tiny,
> > asteroid-like moons), but some other, extra-solar desert world - perhaps
> > Frank Herbert's Arrakis?
> Arrakis had (has?, will have?) two moons as well.
Yes, but both are large enough to be spherical - which means at least 400 km
in diameter, while Deimos and Phobos are only about 8 and 20 km large!
Yadgar
Subject: Re: M over P - revision 3
Date: 3 Nov 2001 17:18:02
Message: <Xns914EAFFA2C560CQ@204.213.191.226>
Yadgar <j.b### [at] ndhnet> wrote in news:3BE### [at] ndhnet:
> Mars?
I posted most of the source a few days back.  The planet is an image map of
mars with some fake normal effects added.
> hull simply ambient 1 finish or is there more about them?
They're just rgb <0,0,1> ambient 1.  I don't have the patience to use
anything more complicated on little logos.
Anyhow, here's revision 3.  I've added some texturing on the moon, a little
lens flare, and increased the lighting on the ship.  This image took 8
hours to render on an 866MHz P3.
Download 'MoP.jpg' (55 KB)
Preview of image 'MoP.jpg'
Date: 4 Nov 2001 12:57:43
Message: <3BE58E2F.391F91F3@ndh.net>
> > Mars?
Cool, now the moon looks really like a moon (texture of Earth's moon?)... and
I like the subtle rectangular structures (normals?) on the ship's hull. Is the
lensflare positioned at the actual position of the light source?
Yadgar
Date: 4 Nov 2001 14:19:42
Message: <3BE594BF.9FCD974A@saber.net>
Dear Coridon and Folks,
Very simple, clean, and elegant...I like this a lot.
Simple is good.
Blessings,
          Brendan
Michael Brendan Hurley           ShadowDancerEnterprizes, LTD.
POV:  http://www.geocities.com/mbrendanh/index.html
HOME: http://www.saber.net/~mbhcgc/index.shtml
mbh### [at] sabernet
Date: 5 Nov 2001 03:00:26
Message: <Xns91501E93FC197CoridonHenshaw@204.213.191.226>
Yadgar <j.b### [at] ndhnet> wrote in news:3BE58E2F.391F91F3@ndh.net:
> moon?)...
It's an image map of Phobos, which is one of Mars' two moons.
> and I like the subtle rectangular structures (normals?) on
> the ship's hull.
Yes; the rectangular bits are from using cells as a normal pattern.  The
rest of the hull texture is simply made with layers of bozo-marble bozo
patterns with varying color maps.
> Is the lensflare positioned at the actual position of
> the light source?
No.  The light source is far offscreen on the right hand side.  The lens
flare is purely decorative.  Indeed, a light at the lens flare wouldn't
have any effect whatsoever on the visible portions of the scene.
Date: 7 Nov 2001 22:56:40
Message: <3bea024d.1007665@localhost>
Very cool.
Pete
