POV-Ray : Newsgroups : povray.binaries.images : Text Isosurfaces Server Time
25 Mar 2026 10:41:45 EDT (-0400)
  Text Isosurfaces (Message 1 to 9 of 9)
Subject: Text Isosurfaces
Date: 12 Mar 2025 14:35:00
Message: <web.67d1d3b0dd1b1e6044dc80f55cc1b6e@news.povray.org>
If you have seen any of my posted renderings and read my comments, you will know
that I am a big fan of using isosurfaces.  Most of the objects in any scene I
create are isosurfaces, unless I am absolutely sure I will not need to apply any
sort of irregular, visible, surface texture to them.
With my latest exploration of SDFs, and how to use them with isosurfaces, I have
a library that covers pretty much all of the POV-RAY SDL primitive objects as
isosurface SDF functions, so I can create just about anything... except text.
There are a number of articles about how to create SDFs for text objects,
including GPU-based game platforms that do this automatically, but I haven't
found anything that would work well with POV-Ray, other than something that
generates meshes.  Even then, applying a bumpy surface to a pre-defined mesh
isn't easy.
So, I have resorted to the following:
1. Create a text{} object representing the text I want to render.
2. Create a pigment using the object pattern from that text:
      object {
         _text_object
         rgb 1
         rgb -1
3. Create a pigment function from the pigment
4. Create an isosurface using the pigment function as the function and
add/subtract my surface texture function to it.
The difficulty I have had with this is that the pigment function isn't
continuous, so it doesn't really function as an SDF.  This can make it difficult
to get the surface texture to "stick" correctly.  Plus, the wider the difference
between the "in" and "out" values, the higher the max_gradient I need to get rid
of artifacts.
It does help to use smaller, more appropriate values for the in/out, generally
something just large enough to reflect the maximum extent of the surface texture
being applied, but the discontinuity can still be an issue.
So, I have taken a new approach to create a pseudo SDF by creating N instances
of the pigment function with the object scaled smaller than 1, (representing the
interior), and M instances scaled at greater than 1, (representing the
exterior), and assigning a distance from the surface of the original object that
those scales represent.  The isosurface shape function then finds the smallest
scaled instance of the object that the point lies within and assigns the
distance associated with that scale as the distance from the surface.
Depending on how accurate, (and slow), I want the image to be, I can make the
new step-distance-function as close to continuous as I need to get a good
result, while keeping the max_gradient reasonable.
Here is an example.  The top, white object is just text {... "What" }.  The
bottom, textured one is an isosurface using this pseudo-SDF function with 3
interior and 3 exterior scale values that cover the range where the bumpy
surface texture would apply.  (The surface texture is a warped crackle pattern).
 Accuracy was 0.005, and max_gradient was 10.
I added some code for creating the pseudo-SDF to libisoshapes.inc:
Iso_object(Object,Gradient) and some functions for creating the gradients that
define the values and scales Iso_object_scale_gradient_create_size().
One important note using this method; the object to be converted should be
centered at the origin.  I used the previously defined Text_metrics macros from
libtext.inc to help with this.
-- Chris R.
Download 'text_test.png' (230 KB)
Preview of image 'text_test.png'
Subject: Re: Text Isosurfaces
Date: 13 Mar 2025 14:10:56
Message: <67d31fb0$1@news.povray.org>
Interesting. This is an approach different than I've seen for
establishing a gradient about the surface of an object. Wondering some
about how the scaling is handled in detail. I've put it on my list to
review your code. Thank for making it available!
Bill P.
Date: 13 Mar 2025 15:50:00
Message: <web.67d3364b3b40b7dcd2a18eff25979125@news.povray.org>
> Bill P.
Yes, I thought so too.
I remember doing something with f_r (), and creating an artificial gradient
across the hard boundary of the object pattern - but I've looked for the past 2
days and haven't found the file or render where I did those experiments.
I'm pretty dure that I discussed the details with you though - in reference to
your object-as-isosurface project.
- BW
Date: 14 Mar 2025 12:15:00
Message: <web.67d455363b40b7dc53fb81ab5cc1b6e@news.povray.org>
> > Bill P.
> - BW
I'd be interested when you find your method of doing this as well.  I'm finding
the scaling method breaks down under some transformations on the object, so it
isn't always perfect.  I tried creating text that explodes from a single point
to the full text (like a cone along the Z axis) and got lots of jaggy edges when
using the scaling method.
-- Chris R.
Date: 14 Mar 2025 18:10:00
Message: <web.67d4a81e3b40b7dc1f9dae3025979125@news.povray.org>
I'll keep digging in the archive.
So. Many. Files.
The general gist of the method was like doing a Laplacian - rather than
evaluating the isosurface at <x, y, z>, Something like an inside test was done
across the 9 or 27 "voxels" surrounding and including the point.
The sum of this would then _gradually_ drop off, as more and more sample points
were zero, and only a few were inside the object.
I guess it's also like dithering, and edge-finding with a convolution kernel.
I could swear that I mapped / graphed this all out and got it to work very
nicely - I just have to find it.
- BW
Date: 15 Mar 2025 15:37:20
Message: <67d5d6f0$1@news.povray.org>
>> Bill P.
I came up with a method a few years ago.  It uses trace() to find the
distance to the edge of an object from voxels in a vertical plane, and
creates an image map with the desired gradient.  You can use the pigment
function in an isosurface.
  https://github.com/CousinRicky/IsoBevelTut
There are a couple of issues:
 - Creating the image for the pigment function is a slow process.
   However, you only have to create the image once.
 - No matter the resolution, there will always be hard boundaries at the
   pixel level.  The interpolate option in the image map can mitigate
   this in some cases.
Date: 16 Mar 2025 03:26:56
Message: <67d67d40$1@news.povray.org>
Thanks for posting. Another interesting approach.
I started an effort to create image file based characters with gradients
years ago by projecting a (parallel?) area light through each character
onto a white plane. It looked like it might more or less work, but I got
distracted...
Aside: There is in the yuqk fork the soft_object{} and hard_object{}
patterns which use two different, on the fly, methods to create
gradients for objects with a defined inside. At the start of the covid
shutdown I posted an image that I think used the hard_object{} feature
IIRC. Ah, found it:
https://news.povray.org/povray.binaries.images/thread/%3C5e95fae5%241%40news.povray.org%3E
Bill P.
Date: 17 Mar 2025 12:40:00
Message: <web.67d84faf3b40b7dca40969eb5cc1b6e@news.povray.org>
> So. Many. Files.
> - BW
That was actually the first approach I thought about; it's very similar to what
Inigo Quilez proposes for doing repeating patterns of SDFs.  I had trouble
visualizing how much variance it would introduce in the edges while introducing
27 calls to the pigment function at each point.  Did you find you needed to
expand the box beyond the neighboring points, perhaps to 2 points out, which
would be 125 calls to the pigment function to get a good gradient for shading?
-- Chris R
Date: 17 Mar 2025 13:15:00
Message: <web.67d857f63b40b7dc3bc22bca25979125@news.povray.org>
Where does he cover that?
> I had trouble
I don't recall the specifics, as it was several years ago.
I'm not sure if I'm remembering or speculating post hoc, but I think the idea
was to simply establish what the gradient vector was, and then take several
samples along that vector. Then those samples were just averaged.
It seems like there was slightly more to it than that, possibly using the
bounding box of the object {} to govern the spacing of the samples...?
I'm really not going to know for sure until I somehow stumble upon my files.
If all else fails, I may just have to try and rewrite everything from scratch.
- BW
