POV-Ray : Newsgroups : povray.binaries.images : A quick povr branch micro normal image. Server Time
15 Jun 2026 00:22:10 EDT (-0400)
  A quick povr branch micro normal image. (Message 61 to 70 of 97)
Subject: Re: A quick povr branch micro normal image.
Date: 18 Feb 2022 01:49:14
Message: <620f416a$1@news.povray.org>
On 2/17/22 02:39, jr wrote:
> chain-loading via 'file_exists()' is nice + "clean" (imo).
I'm not completely sure I'm following what you mean by chain-loading?
I've adopted the use of file_exists() on deciding to ship a version.inc
with povr. The overall implementation is done in a
scene->version.inc->forkversion.inc way. Is this what you mean by
chain-loading?
file_exist() is one of those things which is clean until it's not. :-)
Think about how we've often shipped binaries intended to run on a
earlier install base. There is build infrastructure to support this
model of update. A model somewhat workable because official POV-Ray
supports backward compatibility. It's problematic in that to safely
align with any given binary you need the binary's includes too -
something that in POV-Ray proper requires a full install.
Think too about how the search path is user modifiable.
Anyhow, it's the method we have. I agree too for normal users with a
single installation of POV-Ray, and relatively constant include files,
file_exist is safe enough.
>> Comments welcome.
>> Aside: I'm unsure when / if to change the povr code to force all
>> incoming SDL to run strictly at v3.8+. Internally, I've slowly been
>> tossing code for backward compatibility into the bit bucket. V3.8+ SDL
>> is all I intend to support. However, as many are still working with
>> older releases, scenes and includes, I've been maintaining the parser in
>> a state that allows earlier version settings. It's useful when looking
>> at posted issues...
> it would be interesting to see proposals for an updated v4+ SDL.
Practically, I don't think I've got the bandwidth for anything
revolutionary in the povr fork.
It would probably be TCL if I do get around to trying something radical.
I have a lot of that going today - as you know - but the implementation
writes SDL. In other words, it still leans on the current SDL parsers.
> out of interest, how difficult would it be to have two separate parsers?  one
> for pre 3.7/8 compatibility, one for newer style.  (I'm guessing that the
> executable would not be all that much larger, and separation might bring other
> benefits)
My up front answer - difficult. The parser is still too integrated with
the run time code. As something part of my povr branch it's not the most
unattractive idea because it tangles me in two different parser
implementations.
Aside: I've thought about hacking versions of POV-Ray in a way where
they could be run as 'parse to some intermediate form and stop'
utilities. And that thought reminds me I want to implement an actual
#stop after parse directive. I use #error, but it's an ugly way to stop
after the parsing stage.
Anyway, thanks for the ideas! As with the ini and options setting
approaches, I'm still uncertain where the povr code will go.
> have only spent a few minutes looking over the attached, seem ok (bar copy/paste
> typos 'str_var' in 'forkversion.inc'.)
Thanks. I believe that fixed.
And apologies. I must not of finished the editing of forkversion.inc (or
somehow didn't do a last save...) I picked up a number of other mistakes
'I thought' I'd fixed.
Bill P.
Date: 18 Feb 2022 07:05:00
Message: <web.620f8b0ec1365d061f9dae3025979125@news.povray.org>
do file_exists (filename)
if yes, run/include that file.
In THAT file is _another_ file_exists (filename)... and so on
daisy-chain everything together until you hit a dead-end.
Yes.
More useful would be to have that as a "function" that returns some sort of
state variable, visible to the OS/shell
I've also thought about a mechanism to "stop" and then _reparse_ the SDL file,
such that certain things could be scanned, written to file, or otherwise do a
pre-parse-and-render setup.  Maybe something like: #reparse 3
POV-Ray would parse until it hit that, decrement a counter, etc, until it read
through that directive at counter = 0.
I suppose we have workarounds for stuff like this.
I've also wondered about write-protecting files in some way to make editing them
a conscious and fully purposeful action.   Like locking the cells in a
spreadsheet so that critical, complicated formulas don't get edited by someone
trying to "improve" things.  ;)
Silly idea:   certain image formats have header sections where you can embed
virtually anything.   Would it be possible to have POV-Ray store scene files in
an image file format, with the SDL embedded in the header?  Not sure where I was
going with this a second ago - but just thinking about such a thing might spark
some new ideas about structuring scene, includes, etc.
Date: 18 Feb 2022 11:05:00
Message: <web.620fc298c1365d06ed36e5cb6cde94f1@news.povray.org>
as BE says.  what I tried to say is something like the mechanism is nice/clean
because it all is/can be transparent to the user (as your code snippet
demonstrates).
> > > Thinking
please do!  ;-)
I guess that a C(++) extension for Tcl, to drive the VM from Tcl, would do it
:-), access through some "specialising" packages/modules perhaps.
> > benefits)
> implementations.
ah, naively I'd thought that the existing CLI/ini 'version' could be (ab)used,
ie if not given start with forked parser, if any file read needs <3.8 stop/error
tell user either needs option switch (to start with the "compatible") or edit
offending file.
agree with BE, being able to return a status from a scene would be neat,
particularly if it's available for 'post_frame_command's.
also re his "silly idea", SDL (and or pre-parsed VM calls) storage -- how about
DB (sqlite) storage?
:-)  you'll have to tell me when to stop.
regards, jr.
Date: 28 Feb 2022 06:50:00
Message: <web.621cb65ec1365d06ed36e5cb6cde94f1@news.povray.org>
hi,
look at attached with:
  $ hexdump -C hu_8.png | less
that what you mean?  ;-)
anyway, long story short, you can do in Tcl, for .png files.  install the
'Tcllib' package, then check out the man page (section n on my box) for 'png'.
regards, jr.
Download 'hu_8.png' (17 KB)
Preview of image 'hu_8.png'
Date: 28 Feb 2022 15:30:00
Message: <web.621d30c1c1365d061f9dae3025979125@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
Well, not exactly.   I think I wrote that on my way out to work, so it was just
a short brain-dump.
What I was actually thinking was that POV-Ray could use an image format as the
actual file format for storing the SDL text, and the editor could extract it
from that, display it, allow for editing, and re-save into the image file
wrapper.
Why do this:
I guess the idea was that since POV-Ray already has the ability to
parse/interpret image file formats already, it might be possible to somehow
embed a series of text files into the image header - like includes, etc and use
it kind of like a zip file.
Also, then we could have the image and the code that generated it all in one
place, so they aren't separated and lost/confused.
It might also be possible to implement security by obscurity, to protect certain
parts of code that an author might not want users casually messing with.  If you
really wanted to edit that code, you'd have to work for it, rather than just
"Ooops!  I broke it!"
But binary copy, hexdump, Tcp, and other tools might provide a sort of
functional work-around / proof of concept to see how a suite of files could
potentially be used ....
Date: 1 Mar 2022 06:50:37
Message: <621e088d$1@news.povray.org>
> that what you mean?;-)
Neat.
What particular commands and versions of TCL and Tcllib are you using?
It's been maybe 4-5 years since I played in the tcl/png sandbox but, not
too long after tcl 8.6 was first released, I found the png support from
within tcl/tk/tcllib buggy. Supposing you are finding it better?
I was primarily trying to load/create/modify/save actual image channel
data but, I don't recall even the particular 'TCL' packages and commands
I tried at the moment...
Bill P.
Date: 1 Mar 2022 07:40:00
Message: <web.621e1309c1365d06ed36e5cb6cde94f1@news.povray.org>
hi,
> wrapper.
> Why do this:
- keeping "image and the code" in one place, along with the includes, bg
image(s) etc, would be ideal.  a project oriented approach.  and zip would be a
good format.
- hate the idea/concept of "allow for editing, and re-save into the image file
wrapper".  if anything the other way round, keep everything plain human-readable
text and include image(s) and other binary content 'base64' encoded.
anyway, thanks, have a clearer picture now of the "silly idea".
also not keen on this.  if an author feels .. so strongly, well, then don't
publish.  simples.
why binary anyway?  what's wrong with a plain text (or utf8) encoding?
regards, jr.
Date: 1 Mar 2022 08:00:00
Message: <web.621e17b8c1365d06ed36e5cb6cde94f1@news.povray.org>
hi,
(typed)
% set tcl_version
8.6
% package require crc32
% package require png
% png::addComment foo.png theTag theValue
and using a 'tcllib1.18' (though mean to upgrade to 1.19).
guess so, cannot recall any problem(s) with 'image' and 'photo' etc.
fwiw 'df3util' can split PNGs into rgba (and stored in a DF3, but there's the
'export' command).
hope to post a 'compare(1)' image in the next days, showing some/much difference
for the sphere_sweep between 'povr' and stock POV-Ray.  will need to
systematically try with 'sturm' and 'tolerance' etc first though.
regards, jr.
Date: 1 Mar 2022 12:06:17
Message: <621e5289$1@news.povray.org>
On 28/02/2022 12:47, jr wrote:
> hi,
Really funny !
<https://en.wikipedia.org/wiki/Steganography>
Kurtz le pirate
Compagnie de la Banquise
Date: 1 Mar 2022 13:50:00
Message: <web.621e6a50c1365d06ed36e5cb6cde94f1@news.povray.org>
thinking some more..
> Neat.
and super-easy, _and_ since Tcl also runs on Redmond's finest, potentially of
interest to every user of POV-Ray who wants to publish/distribute an image.
therefore, imo, in a separate thread, we ("all interested parties" :-)) should
have a discussion to come up with an informal set of useful "recommended"
tags/keys. think will start one tomorrow (unless you/someone gets there first
</grin>).
@kurtz
"covered writing" indeed, as many (most?) image viewers simply ignore the info.
regards, jr.
