![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 14/05/2021 om 23:38 schreef jr:
> hi,
> Thomas de Groot <tho### [at] degroot org> wrote:
>> I guess we should discuss the macro here, as images will be important items.
>> The macro can be found in p.b.s-f
> had a brief first look. it will be difficult to discuss fully, in isolation, I
> guess, because various prefixes imply a place in a greater schema. one
> immediate thing though is comments within the macro code/body, I have learned
> from 'Foreach()' that moving comments out of the code does improve performance.
About the comments: yes I guess you are right; moving them should be
done indeed /before/ the final version and included into the Docs file.
Noted.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 14/05/2021 om 14:20 schreef Thomas de Groot:
Already the first corrections implemented! Beta #1.1 has been uploaded.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
My idea is/was that users simply try the different possibilities in
their own environment, primarily for usefulness in their own scenes,
like Dave Blandston has done. I guess that questions about the
/structure/ will come automatically, like yours about the "greater
scheme" (short answer: there isn't!). Those will probably lead to, e.g.,
name simplifications.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
grabbed an old (comparison) scene, just for a quick test, hope to find time (and
a more interesting shape) to begin explore (some of) the settings. the
animation is just over the 5M limit, so have attached a frame.
on the first run the alpha.10064268 crashed at frame #46, something about a
doubly-linked list, but re-running with 'script' didn't reproduce.
fwiw, needed to add a second light source because I thought the image a little
dark, that quadrupled the per frame render time. :-)
regards, jr
Download 'icosa_anim_07.png' (352 KB)
Preview of image 'icosa_anim_07.png'
![icosa_anim_07.png](/povray.binaries.images/attachment/%3Cweb.609ff7f2581f2f6879819d986cde94f1%40news.povray.org%3E/icosa_anim_07.png?ttop=437698&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 15/05/2021 om 18:33 schreef jr:
> hi,
This looks very good indeed! The objects look smooth and a bit rough at
the same time: the normals do their job as they should!
That could be expected indeed. The macro is not very animation-friendly :-)
> regards, jr
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
> > a more interesting shape) to begin explore (some of) the settings. ...
thanks. not my doing. :-) both objs textured with your default.
still, a massive increase, and, for me ("numpty") an unexpected "surprise".
perhaps a sentence or two in the documentation, regarding the .. sensitivity to
the environment.
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 16-5-2021 om 12:45 schreef jr:
> hi,
> the environment.
I am just thinking aloud here, but I wonder /what/ makes the render time
quadruple? I shall make some test on my side too, because I don not
entirely understand the phenomenon.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
no idea whether this info is any help. the scene was, apart from added
light_source, the same. both objects are a 'mesh2' type, the one on the right
with ("weighted average") normal_vectors.
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 16-5-2021 om 14:19 schreef jr:
> hi,
It is strange. The attached image is a simple scene with a mesh2 object
(twice). A first render with only one light source took 8m39s; a second,
with an added shadowless light, took 8m52s; a third render (attached)
with the second light /not/ shadowless, took 10m20s.
We are far from a quadruple render time... I have no idea.
Download 'granitetest.jpg' (78 KB)
Preview of image 'granitetest.jpg'
![granitetest.jpg](/povray.binaries.images/attachment/%3C60a11239%241%40news.povray.org%3E/granitetest.jpg?ttop=437698&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
I wonder whether the normal vectors in the rightmost object somehow ..
interfere. no idea, have attached the code I use. nearly forgot - the
output_file_names in the ini file will need adjusting.
regards, jr.
Download 'tdg_tst_beta.zip' (3 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
