POV-Ray : Newsgroups : povray.binaries.images : New Earth Station Server Time
19 Oct 2025 22:34:43 EDT (-0400)
  New Earth Station (Message 1 to 10 of 14)
Subject: New Earth Station
Date: 6 Jan 2021 16:26:05
Message: <5ff62aed@news.povray.org>
Another scene that I dug out from the archive and which I'm trying to
update now. Most work went into the planet. Slowly I'm learning how to
put texture maps to good use.
Also trying to make use of the "greebles" idea that Thomas de Groot
pointed me to. In this case a very simple approach using a bump map with
some rectangular, elevated patches.
Some of my PovRay works:
https://www.deviantart.com/antarasol/gallery/42758766/3D
Download 'new_earth_station_v06-t.jpg' (732 KB)
Preview of image 'new_earth_station_v06-t.jpg'
Subject: Re: New Earth Station
Date: 7 Jan 2021 02:28:38
Message: <5ff6b826$1@news.povray.org>
Op 06/01/2021 om 22:26 schreef Hj. Malthaner:
Very good looking indeed.
Yes, a bump_map is quite satisfying in this context.
Date: 7 Jan 2021 10:45:00
Message: <web.5ff72c579d01a69816086ed00@news.povray.org>
Great!
It shows a lot of work in the patterns. I believe more radiosity, with linear
workflow and some gamma added to bring  it back to 2.2 could greatly benefit to
this scene by revealing that detail in the shadows.
Date: 7 Jan 2021 19:17:08
Message: <5ff7a484@news.povray.org>
Another update, mostly fine tuning of object positions and lighting.
Download 'new_earth_station_v07-t.jpg' (708 KB)
Preview of image 'new_earth_station_v07-t.jpg'
Date: 8 Jan 2021 09:30:06
Message: <web.5ff867589d01a6986adeaecb0@news.povray.org>
Yes, I also think it's better in every aspect... The closest reactors flame was
of a nice color but its shape was too geometric, best to see the contrasted nose
of modules... I keep looking at the picture and of course see new details to
pick:
The furthest planet (rocky one on the left, don't you think it's pattern is too
regular?  I haven't used it much yet, but I would try the warp feature of
pattern modifiers, to give it a more cahotic look... And about the lighting
again, its too strong and flat: I think considering an ini file or command line
launch with display_gamma of around 2.2 or 2.5, if you just put all colors in
srgb and assumed_gamma 1.0 at start of globals (only the output image file
should be put back to 2.2 in gimp or whatever, after render if the final viewing
app shows it bad... But png probably wouldn't) Here is some tips for adapting
old scenes to new gamma maybe you've seen it already:
http://wiki.povray.org/content/HowTo:Migrate_old_scenes_to_work_with_the_new_gamma_system
This will allow you to use and actually take enourmous advantage in such a
scene, of inverse power law (new in POV3.8 and the most realistic), for every
light :
fade_distance 0
(requires  #version 3.8 directive at very top of the file)
Attenuation for the lights is never linear in reality and thus you can choose to
 dim those main light with more control maybe lower or more focused angle,
letting radiosity kick in, especially if you put the deep space tone the darkest
kind of blue you can get instead of pure black. you'd get a less dark shadow but
still bigger contrasts inside of these penumbras > richer tones used overall.
I really enjoy the atmosphere of planet on the right.
And now I see the whole tree populated area inside of the donut, lot of work,
it's awesome! This would also show better if environment light outside the ship
gets lower! please please ! try it :-) One last detail, as much as i love the
crossing streaks of background white stars, having them smaller would do them
good. (The color values can go higher than 1.)
Date: 8 Jan 2021 16:00:08
Message: <5ff8c7d8@news.povray.org>
> light :
> fade_distance 0
Thanks. I didn't know of these changes. I've tried to convert the scene,
but there are some problems cause it uses files that are shared with
other scenes and I need to figure out a way to specify colors that will
work well in pre-3.7 scenes and also 3.8 scenes (maybe the srgb keyword
does, but I still will have to adjust the colors)
Seems there is some work waiting for me to update all the files. But
more realistic output is something I was looking for since a while. So
thanks again!
Date: 8 Jan 2021 19:55:26
Message: <5ff8fefe$1@news.povray.org>
Implementing all suggestions will take some time. Not something I can do
in one evening. But I found some mistakes in ambient settings and some
more. Don't want to clog this server with data, so here's the link to
the version after the fixes.
https://www.deviantart.com/antarasol/art/New-Earth-Station-v-08-729424287
Thanks again! Wouldn't have spotted the problems without your
suggestions. Can't change the moon and stars easily, but I heard your
suggestions and I'm looking into solutions.
Hajo
Date: 9 Jan 2021 08:25:04
Message: <web.5ff9addb9d01a6986adeaecb0@news.povray.org>
> Hajo
It was already a pretty cool image anyway. Thanks for sharing
Date: 10 Jan 2021 20:40:43
Message: <5ffbac9b@news.povray.org>
> light :
> fade_distance 0
Took quite some adjustments to light brightness and also some colors,
The result looks much more natural though. I think the gamma problem was
what made many of my scenes look strange somehow.
Maybe not the final version, but to show the difference I've attached
the version with assumed_gamma 1.0, file and display gamma 2.2
But it looked very bland with those settings so I used the color-curve
tool in GIMP to enhance the contrast.
Download 'new_earth_station_v09-t.jpg' (642 KB)
Preview of image 'new_earth_station_v09-t.jpg'
Date: 11 Jan 2021 09:56:07
Message: <5ffc6707$1@news.povray.org>
Hj. Malthaner wrote on 08/01/2021 01:17:
I really like the colors of the whole composition.
Paolo
