POV-Ray : Newsgroups : povray.binaries.images : Doctor John - FieldCam conundrum Server Time
18 Jun 2024 05:23:53 EDT (-0400)
  Doctor John - FieldCam conundrum (Message 21 to 29 of 29)
Subject: Re: Doctor John - FieldCam conundrum
Date: 18 Nov 2020 19:15:01
Message: <web.5fb5b8d0ed460f771f9dae300@news.povray.org>
So I turned off the field cam, but added the macro invocation to the other
camera definition.
Then I made an axes object, made an object {axes transform {NoFall}}
and overlayed them.
There's no difference if they are at the origin, but when the axes are
translated up (by 50) before applying the transform, I indeed get the up and
forward behaviour.
I can fix the forward movement, but the vertical movement is really puzzling.
  #declare NoFall =
  transform {
   matrix <     1,     0,      0,
           ShearX,  VCorr, ShearZ,
                0,     0,      1,
                0,     0,      -50*ShearZ>
Date: 18 Nov 2020 19:30:00
Message: <web.5fb5bc18ed460f771f9dae300@news.povray.org>
So for now, just try
  #declare NoFall =
  transform {
  matrix < 1,     0,      0,
           ShearX, 1, ShearZ,
    0,     0,      1,
   -CamLoc.y*ShearX,     0,      -CamLoc.y*ShearZ>
Date: 19 Nov 2020 03:02:14
Message: <5fb62686$1@news.povray.org>
Op 19/11/2020 om 01:28 schreef Bald Eagle:
>    #declare NoFall =
>    transform {
>    matrix < 1,     0,      0,
>             ShearX, 1, ShearZ,
>      0,     0,      1,
[aside: OK. New Thunderbird version... seems I clicked on wrong answer
button... Sorry]
YOU MADE MY DAY!! :-)
This is the correct answer indeed. I tried a couple of exotic scene
settings and the scene remains rock-solid.
Sir, I bow before your fathomless wisdom and sharp insight. I only got
as far as to understand that the last row of the matrix was crucial.
Thank you infinitely indeed.
Date: 19 Nov 2020 03:06:04
Message: <5fb6276c@news.povray.org>
Op 18/11/2020 om 13:16 schreef Jörg "Yadgar" Bleimann:
> My digital cameras (even the relatively sophisticated Panasonic Lumix
> DMC-LZ100) are no able to correct for falling lines... but perhaps this
> macro can do that with the photos?
I do not see how. If you import your photograph into a povray scene,
applying the macro will not correct the '/content/ of the photograph,
only the scene it is part of.
Date: 19 Nov 2020 06:35:00
Message: <web.5fb65763ed460f771f9dae300@news.povray.org>
Thanks, Thomas.
I'm glad that it seems that I've mostly solved the issue - at least for all of
the use cases you've tested.
I still have a feeling that there's a bit more to be done, and somehow VCorr
_may_ be needed in there.
It's not very noticeable from far away, you need steep viewing angles to see
what I mean.
Possibly.
But you'd need the camera and look_at data from your original photo to get the
right angle of tilt needed.
You may just try making an animation with your photo and rotating it around -x
to see what happens, since AFAIA, that's the bulk of the effect.
Mr Le Coat seems to have a much firmer grasp of all of this:
http://news.povray.org/povray.advanced-users/thread/%3C5bb67852%40news.povray.org%3E/?mtop=425362
Date: 20 Nov 2020 02:27:32
Message: <5fb76fe4@news.povray.org>
Op 19/11/2020 om 12:30 schreef Bald Eagle:
> Thanks, Thomas.
> what I mean.
I agree with you. One of the things which still puzzles me is that there
seems also to be a slight zoom effect, mostly noticiably in cloud
patterns for instance in the background. Maybe that is what you observe.
However, for the time being, the macro is more useful than it was.
I shall put version 4.0 of the macro in povray.binaries,utilities.
Date: 20 Nov 2020 02:37:45
Message: <5fb77249$1@news.povray.org>
> Possibly.
I woke up this night with a possible solution. You need to simulate a
technical camera using the combinationof your digital camera and povray:
1. Take a photograph of a (tall) building with your camera, tilting it
/backwards/ by 20 degrees (for instance);
2. In povray, put this photograph on a vertical flat plane in front of
the camera, and tilt the plane /forwards/ by 20 degrees. Be sure that
the camera is level (both location and look_at with identical y-value);
3. In povray, you may need an orthographic camera for better results.
I /think/ this would do the trick; you will need to experiment.
Date: 20 Nov 2020 06:30:00
Message: <web.5fb7a86fed460f771f9dae300@news.povray.org>
OK, I wanted to make sure that it wasn't just me.
The zoom, I think, is part uncorrected stuff, and part unexpected "optical
illusion".  It's real, but it's the effect of tilting the camera's "film plane",
so that some parts are closer to the scene objects than they were.
Try 2 things.
use:
  #local _j = vlength (<ShearX, VCorr, ShearZ>);
  #debug "\nIgnore the following Parse Warning: \n"
  #debug "----------------------------------- \n"
  #declare NoFall =
  transform {
   matrix <     1,     0,      0,
                0,     0,      1,
     -CamLoc.y*ShearX,     -CamLoc.y/_j*VCorr,      -CamLoc.y*ShearZ*_j>
_j is the length of the new modified y-axis, and I think that there needs to be
a shift back to compensate for that, and average out the "zoom" effect, as shown
in the new matrix term.
and _then_ follow up with:
#if (FC)
  //FieldCam (CamLoc, CamLookAt)
  FieldCam2 (CamLoc, CamLookAt)
  perspective
  location  CamLoc
  sky       CamSky
  up        CamSky
  direction z*CamZoom
  right     x*AspectRatio
  angle     CamAng
  translate -CamLoc
  transform {NoFall}
  translate CamLoc
  look_at   CamLookAt
To apply the camera matrix with the camera at the origin.
I think any further work will really need to quantify the effect.
Date: 21 Nov 2020 02:32:53
Message: <5fb8c2a5$1@news.povray.org>
Op 20/11/2020 om 12:28 schreef Bald Eagle:
Yes, I guessed something like that.
> Try 2 things.
> use:
>    #declare NoFall =
>    transform {
>     matrix <     1,     0,      0,
>                  0,     0,      1,
> #if (FC)
>   camera {
>    perspective
>    location  CamLoc
>    sky       CamSky
>    up        CamSky
>    direction z*CamZoom
>    right     x*AspectRatio
>    angle     CamAng
>    translate -CamLoc
>    transform {NoFall}
>    translate CamLoc
>    look_at   CamLookAt
This does not work correctly: the camera is pushed below the surface
(above the surface when y becomes negative, obviously). the VCorr
remains a puzzle to me and the _j does not help in the matter. I also
have a hunch that putting the camera at the origin is not helpful. It
doe not make any difference as far as I can tell.
Yes, I think that is the correct conclusion. So far, you have done a
great job already and made the macro much more useful than it was
originally.
