POV-Ray : Newsgroups : povray.binaries.images : Piles of things (with Bullet Physics Playground) Server Time
28 Jul 2026 04:46:49 EDT (-0400)
  Piles of things (with Bullet Physics Playground) (Message 35 to 44 of 44)
Subject: Re: Piles of things (with Bullet Physics Playground)
Date: 18 Sep 2012 04:23:44
Message: <50582f90@news.povray.org>
On 18-9-2012 9:19, Thomas de Groot wrote:
> I want to do the same with only collision objects and see what happens
> but I believe that there is a serious constrain on Poser Physics... :-(
It seems to be as I thought. Simulating with only collision objects
works well. This means that mesh objects need to be as close in shape to
the collision objects as possible.
Download 'poserphysicstest_02.png' (178 KB)
Preview of image 'poserphysicstest_02.png'
Date: 18 Sep 2012 08:00:01
Message: <web.505862222fe15fc5f7aa22b40@news.povray.org>
Maybe you could use combined collision shapes like Sam did with the nails? After
seeing that little trick I dug into Bullet a bit more and found how to do it
directly. While I was poking around I also found that the ragdoll is really just
a simple collection of capsules and joint constraints:
class RagDoll
   enum
      BODYPART_PELVIS = 0,
      BODYPART_SPINE,
      BODYPART_HEAD,
      BODYPART_LEFT_UPPER_LEG,
      BODYPART_LEFT_LOWER_LEG,
      BODYPART_RIGHT_UPPER_LEG,
      BODYPART_RIGHT_LOWER_LEG,
      BODYPART_LEFT_UPPER_ARM,
      BODYPART_LEFT_LOWER_ARM,
      BODYPART_RIGHT_UPPER_ARM,
      BODYPART_RIGHT_LOWER_ARM,
      BODYPART_COUNT
   enum
      JOINT_PELVIS_SPINE = 0,
      JOINT_SPINE_HEAD,
      JOINT_LEFT_HIP,
      JOINT_LEFT_KNEE,
      JOINT_RIGHT_HIP,
      JOINT_RIGHT_KNEE,
      JOINT_LEFT_SHOULDER,
      JOINT_LEFT_ELBOW,
      JOINT_RIGHT_SHOULDER,
      JOINT_RIGHT_ELBOW,
      JOINT_COUNT
   m_shapes[BODYPART_PELVIS] = new btCapsuleShape(
      btScalar(0.15), btScalar(0.20));
   m_shapes[BODYPART_SPINE] = new btCapsuleShape(
      btScalar(0.15), btScalar(0.28));
   m_shapes[BODYPART_HEAD] = new btCapsuleShape(
      btScalar(0.10), btScalar(0.05));
   m_shapes[BODYPART_LEFT_UPPER_LEG] = new btCapsuleShape(
      btScalar(0.07), btScalar(0.45));
   m_shapes[BODYPART_LEFT_LOWER_LEG] = new btCapsuleShape(
      btScalar(0.05), btScalar(0.37));
   m_shapes[BODYPART_RIGHT_UPPER_LEG] = new btCapsuleShape(
   m_shapes[BODYPART_RIGHT_LOWER_LEG] = new btCapsuleShape(
   m_shapes[BODYPART_LEFT_UPPER_ARM] = new btCapsuleShape(
      btScalar(0.05), btScalar(0.33));
   m_shapes[BODYPART_LEFT_LOWER_ARM] = new btCapsuleShape(
      btScalar(0.04), btScalar(0.25));
   m_shapes[BODYPART_RIGHT_UPPER_ARM] = new btCapsuleShape(
   m_shapes[BODYPART_RIGHT_LOWER_ARM] = new btCapsuleShape(
Another thought, maybe try making the collision shapes smaller for the floating
meshes?
www.McGregorFineArt.com
Date: 18 Sep 2012 10:38:21
Message: <5058875d$1@news.povray.org>
> meshes?
The problem is that in Poser Physics you have no control on these. You
can set one of the pre-defined collision objects to (e.g.) a mesh, but
you have no control over those collision objects. This seems to be a
serious limitation on the Poser Physics plugin for Poser.
Date: 18 Sep 2012 15:30:05
Message: <5058cbbd$1@news.povray.org>
Too true. I believe that it is unsupported now.
Regards
Date: 19 Sep 2012 02:44:42
Message: <505969da@news.povray.org>
However, there is a Poser Physics 2012, for Poser Pro 2012.
Date: 19 Sep 2012 14:21:59
Message: <505a0d47@news.povray.org>
I don't think it is worth upgrading from Pro 2010 just for that, do you.
I do intend to get to grips with the latest version of Blender though.
Sometime
Regards
Date: 20 Sep 2012 03:51:56
Message: <505acb1c$1@news.povray.org>
No, I don't think so. I shall upgrade to Poser Pro one day however.
Me too...
> Sometime
slowly... ;-)
Date: 20 Sep 2012 11:20:01
Message: <web.505b33322fe15fc5f2eb76540@news.povray.org>
I find that Poser Pro is much faster than Poser 8 (I think that it is 8 I have).
It is faster to load and close and the cloth room simulations are faster too.
> Me too...
> > Sometime
> slowly... ;-)
I have a project that I would like to start in Blender as well. A 1908 MB
So I might try a still life to try and improve my textures.
Date: 21 Sep 2012 03:20:03
Message: <505c1523$1@news.povray.org>
Yes, it takes advantage of multiple cores, doesn't it? As soon as there
is an interesting offer to upgrade I shall probably make the move.
Textures are fun to work on. I learned a lot when I used Moray on a
daily basis. And there are all those macros provided by friendly povers.
Date: 27 Sep 2012 17:35:22
Message: <5064c69a$1@news.povray.org>
On 16/09/12 21:21, Samuel Benge wrote:
> It makes for some fantastic explosions, though ;)
   Thanks for the idea! I used it to do some primitive fireworks, adding
random vertical velocities too:
   http://www.youtube.com/watch?v=t0ys3EBgROs
Jaime
