Just quick and random, but I like it so I thought I should share. I'll
continue tweaking and add some randomness to the color also.
Download 'rsweep.png' (262 KB)
Preview of image 'rsweep.png'
I like that! Especially the "roughly glued" joints which look extremely
realistic.
> realistic.
> Thomas
I think that those "roughly glued joints" are realy sphere_sweep
artefacts...
But, in this case, those do look good.
> artefacts...
> Alain
Yes, indeed they are just that.
I made the object a bit transparent, added some lights to make some
colorization and changed to 3.7 to get more threads on quad-core system.
...the new version has now been rendering for 1d, 5h and 50 minutes to
reach 32%. I guess it came out a bit too heavy and won't pay off the
extra load, but now I really DO want to see what will come out of this,
so I'll let it run.
> so I'll let it run.
The original picture has 20 joints. Here's one with 10 joints from 3.6,
apparently it renders in under 9 minutes, even though 3.7 is taking it's
share of the CPU resources at the same time. Also 3.6 is now going in
33% after just 18 minutes. Even though the different versions seem to
render the scenes differently (3.6 in lines, 3.7 in pieces) and possibly
to calculate the percentages a bit differently (or hitting more load at
one time to be precise) due to this, it seems that this scene is way
harder for 3.7 to render. OTOH the visible part of the image seems to
say that 3.7 makes a lot better quality (mostly concerning the
sphere_sweep artefacts).
Download 'rsweep-lite.png' (68 KB)
Preview of image 'rsweep-lite.png'
Am 25.06.2012 21:57, schrieb Eero Ahonen:
Yes, fixing a good deal of the sphere_sweep artifacts came at a price.
We found the problem to be rounding issues in some optimization code; as
it would have been difficult to fix, we decided to turn it off for now.
Yes, that indeed explains it all. I could see a possibility to choose
the behavior with some option of the object to be nice, but if there is
none, I'm more happy with more precise results, even if the cost is this
huge difference in rendering time.
