POV-Ray : Newsgroups : povray.binaries.images : IRTC WIP Server Time
23 Jun 2026 00:36:13 EDT (-0400)
  IRTC WIP (Message 9 to 18 of 38)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: IRTC WIP
Date: 10 Apr 2010 21:30:01
Message: <web.4bc124edfef3d34785de7b680@news.povray.org>
> BTW, I know this sounds like a newbie question but: has anyone got a nice
> way to round or bevel the edges on those letters?
Were you aware of the macro Bevelled_Text from shapes.inc?
http://www.povray.org/documentation/view/3.6.1/468/
Date: 10 Apr 2010 22:56:02
Message: <4bc13a42$1@news.povray.org>
"Cousin Ricky" <ric### [at] yahoocom> wrote in message
news:web.4bc124edfef3d34785de7b680@news.povray.org...
Hah! I was not. There I go reinventing the wheel... :)
Tek
http://evilsuperbrain.com
Date: 11 Apr 2010 00:00:38
Message: <4bc14966@news.povray.org>
Here's a tweaked version with better radiosity and the aforementioned
bevelling. It looks much better but the radiosity has a strange artefact
around the brightly coloured things.
Tek
news:4bc0c6f5@news.povray.org...
> Some postcards from across the universe!
> Obviously I don't have enough images yet, so I've duplicated some, but I
> thought people might be interested in what I'm working on :)
> For my purposes it would suffice to have a mesh of a nicely rounded font,
> but ideally i'd like an all-pov solution which could handle strings of
> text.
> The only option I can think of is to intersect sheared version of the text
> object to get a bevel... in fact that would work quite well! I'll do that
> if
> nobody has a better solution!
> Comments/criticism appreciated :)
> Tek
Download 'stella.jpg' (100 KB)
Preview of image 'stella.jpg'
Date: 11 Apr 2010 06:31:50
Message: <4bc1a516$1@news.povray.org>
Am 11.04.2010 06:00, schrieb Tek:
Would you mind posting your scene code (or throwing together a minimal
sample scene showing the effect)? I'd like to have a closer look at that
issue.
Date: 11 Apr 2010 08:16:09
Message: <4bc1bd89$1@news.povray.org>
Sure, I've just had a bit of a play with a test scene, here's a really good
example of the artefact:
#include "rad_def.inc"
global_settings {
 assumed_gamma 1
 radiosity { Rad_Settings(Radiosity_IndoorHQ,on,on) }
background { rgb .5 }
plane { -z, -1 pigment { rgb 1 } finish { diffuse .9 ambient 0 } }
sphere { vrotate(y*.3+z,0*z), .1 pigment { rgb x } finish { diffuse 0
ambient 4 } }
sphere { vrotate(y*.3+z,120*z), .1 pigment { rgb y } finish { diffuse 0
ambient 4 } }
sphere { vrotate(y*.3+z,240*z), .1 pigment { rgb z } finish { diffuse 0
ambient 4 } }
Tek
"clipka" <ano### [at] anonymousorg> wrote in message
news:4bc1a516$1@news.povray.org...
> issue.
Download 'temp.jpg' (11 KB)
Preview of image 'temp.jpg'
Date: 11 Apr 2010 09:59:52
Message: <4bc1d5d8@news.povray.org>
> "Cousin Ricky"<ric### [at] yahoocom>  wrote in message
You'r version is much beter. Your imperfections are very light compared
to the result from that macro.
Date: 11 Apr 2010 10:10:17
Message: <4bc1d849$1@news.povray.org>
> global_settings {
>   assumed_gamma 1
> ambient 4 } }
> ambient 4 } }
> ambient 4 } }
With 3.7, I don't see that.
What is strange, is the fact that the artefacts are of the complementary
colour.
Date: 11 Apr 2010 10:34:37
Message: <4bc1ddfd$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> wrote in message
news:4bc1d849$1@news.povray.org...
I get it in both Megapov 1.21 & Povray 3.6. I might try moving over to 3.7
but my scene's probably using a couple of megapov features.
> colour.
It's as if it's using negative lighting values.
Tek
Date: 11 Apr 2010 19:22:53
Message: <4bc259cd$1@news.povray.org>
Am 11.04.2010 16:34, schrieb Tek:
> I get it in both Megapov 1.21&  Povray 3.6. I might try moving over to 3.7
Um, sorry... I'm so focused on POV-Ray 3.7 that it didn't even cross my
mind that you may still be using 3.6. >_<
>> colour.
It is indeed! Thanks for pointing me in the right direction, that did
ring a bell:
At each radiosity sample location, POV-Ray 3.6 does not only compute the
total incoming diffuse illumination, but also tries to guesstimate the
illumination /gradient/ at that point.
I had always been suspicious of that mechanism's implementation, though
I never managed to demonstrate its bogosity with a sample scene. On the
other hand I couldn't make out any noticeable benefits either, so I
decided to disable it in POV-Ray 3.7, if only to save memory and
processing time.
To verify this theory, I just threw together a patched 3.7.0.beta.36
with the "gradient code" re-enabled, and it did indeed show the very
same complementary-color halos (current official 3.7 betas don't, as
already mentioned in this thread).
Patching POV-Ray 3.6 (or MegaPOV, for that matter) to fix this issue
should be pretty easy: In radiosity.cpp, just delete (or comment out)
the line reading:
     #define RAD_GRADIENT 1
That should be all that's needed.
Date: 11 Apr 2010 20:46:19
Message: <4bc26d5b$1@news.povray.org>
Glad I could help :)
I've been meaning to compile povray for a while (so I can make a few
changes), and this might finally give me the excuse I need.
Tek
news:4bc259cd$1@news.povray.org...
>> 3.7
>>> colour.
> It is indeed! Thanks for pointing me in the right direction, that did ring
> a bell:
> I had always been suspicious of that mechanism's implementation, though I
> processing time.
> To verify this theory, I just threw together a patched 3.7.0.beta.36 with
> the "gradient code" re-enabled, and it did indeed show the very same
> complementary-color halos (current official 3.7 betas don't, as already
> should be pretty easy: In radiosity.cpp, just delete (or comment out) the
> line reading:
