POV-Ray : Newsgroups : povray.binaries.images : Ripple Tank Sim Server Time
23 Jun 2026 04:26:26 EDT (-0400)
  Ripple Tank Sim (Message 11 to 16 of 16)
Subject: Re: Ripple Tank Sim
Date: 12 Aug 2009 05:34:18
Message: <4a828c9a$1@news.povray.org>
clipka wrote:
> I mainly did it because the C(/++) program I had written earlier only
> produced ASCII art output, and it did quite well for starters, but I got
> tired of its limitations, and was too lazy to integrate support for
> proper image reading and writing ;-)
> And, of course, misusing POV-Ray in this manner was an interesting
> challenge to do ;-)
I'm all for misusing programs and languages in this way. Heck, I'd go as
far as to say that the more unique ways you can find to accomplish a
singular goal, the better! "Unique ways" being the key of course ;)
> Next on the agenda: Game of life.  Should be a piece of cake if done
> properly: Read in last frame, apply a color map according to birth/death
> rules  overlay with 8 tuned-down displaced copies to add birth/death
> hints for the next step - render.
  Ah, with the #if statement right near the apex of that calculation?
And with an average pattern instead of a function? Any way, I'd like to
see it :)
Date: 12 Aug 2009 14:25:18
Message: <4a83090e$1@news.povray.org>
Yeah, I'm in for such stuff, too.
>> birth/death rules  overlay with 8 tuned-down displaced copies to add
>> birth/death
>  Ah, with the #if statement right near the apex of that calculation? And
> with an average pattern instead of a function? Any way, I'd like to see
> it :)
What #if statement? The code won't need any #if :-) (the color map will
serve as a kind of #switch statement).
Date: 12 Aug 2009 16:55:45
Message: <4a832c51$1@news.povray.org>
>> to see it :)
Oh, I guess I was surmising based on your previous statements...
Date: 18 Aug 2009 05:22:45
Message: <4a8a72e5$1@news.povray.org>
>> Good job! I think I'll stick to C programming for this effect though.
>> It's easy enough to produce a barrier and generator mask using POV, and
>> then take it into C to run the sim :/
> tired of its limitations, and was too lazy to integrate support for proper
> challenge to do ;-)
> rules, overlay with 8 tuned-down displaced copies to add birth/death hints
What you are doing here is actually very similar to how you write such
things for the GPU.  I wrote a wave simulator for the GPU a while back and
it works almost identically, never thought of the GoL on a GPU, should be
easy to implement.
Date: 18 Aug 2009 12:07:28
Message: <4a8ad1c0$1@news.povray.org>
clipka wrote:
> ...., and was too lazy to integrate support for
I'm sure you already know this but ascii PPM images are the way forward
here - a nice easy human readable/writable HDRI image format.
Obviously I admire your abuse of PovRay.
Date: 18 Aug 2009 12:49:39
Message: <4a8adba3$1@news.povray.org>
scott schrieb:
> never thought of the GoL on a GPU, should be easy to implement.
I bet. If it can be done in POV-Ray with textures only...
Here's the full POV-Ray SDL code for a GoL sim starting with a random
pattern - the only non-linearity in control flow is the #if to care for
first-frame initialization.
The world is toroidal, though this can be chaned by enabling the "once"
keyword in the definition of PgNext.
As an interesting side note, the sim does /not/ store the end result of
each generation, but interim results: The status of the cell itself,
combined with a count of the surrounding live cells. This allows easy
use of a color_map for the conditionals.
(The code could be made shorter by using macros, but I reckon this would
be counter-productive for parsing speed.)
// +W100 +H100 +KFI1 +KFF9999 +FE
#version 3.6;
global_settings {
   assumed_gamma 1.0
   ambient_light 1.0
   max_trace_level 15
   orthographic
   location <0,0,100>
   look_at  <0,0,0>
   right   -1*x
   up       1*y
default {
   finish { ambient 1.0 diffuse 0.0 }
#local FrameDigits  = int(log(final_frame)) + 1;
#local NumLayers    = 9;
#local Delta        = 1/max(image_width,image_height);
#local NeighborFactor   = 0.05;
#local CellFactor       = 0.50;
#local EPSILON          = 1e-6;
#if (frame_number = 1)
   #local PgNext = pigment { bozo color_map { [ 0.499 rgb 0 ] [ 0.501
rgb 1 ] } scale Delta }
#else
     image_pattern { concat("Life", str(frame_number-1,-FrameDigits,0))
/*once*/ }
     color_map {
       // dead cell
       [ 0*CellFactor + 2.5*NeighborFactor -EPSILON  rgb 0 ]
       [ 0*CellFactor + 2.5*NeighborFactor +EPSILON  rgb 1 ]
       [ 0*CellFactor + 3.5*NeighborFactor -EPSILON  rgb 1 ]
       [ 0*CellFactor + 3.5*NeighborFactor +EPSILON  rgb 0 ]
       // live cell
       [ 1*CellFactor + 1.5*NeighborFactor -EPSILON  rgb 0 ]
       [ 1*CellFactor + 1.5*NeighborFactor +EPSILON  rgb 1 ]
       [ 1*CellFactor + 3.5*NeighborFactor -EPSILON  rgb 1 ]
       [ 1*CellFactor + 3.5*NeighborFactor +EPSILON  rgb 0 ]
     translate -<0.5,0.5,0>
#local Tx1 = texture { pigment { PgNext translate <-1,-1, 0>*Delta }
finish { ambient NumLayers * NeighborFactor } }
#local Tx2 = texture { pigment { PgNext translate <-1, 0, 0>*Delta }
#local Tx3 = texture { pigment { PgNext translate <-1, 1, 0>*Delta }
#local Tx4 = texture { pigment { PgNext translate < 0,-1, 0>*Delta }
#local Tx5 = texture { pigment { PgNext translate < 0, 0, 0>*Delta }
finish { ambient NumLayers * CellFactor } }
#local Tx6 = texture { pigment { PgNext translate < 0, 1, 0>*Delta }
#local Tx7 = texture { pigment { PgNext translate < 1,-1, 0>*Delta }
#local Tx8 = texture { pigment { PgNext translate < 1, 0, 0>*Delta }
#local Tx9 = texture { pigment { PgNext translate < 1, 1, 0>*Delta }
#local TxOutput = texture {
   average
   texture_map {
     [1 Tx1 ]
     [1 Tx2 ]
     [1 Tx3 ]
     [1 Tx4 ]
     [1 Tx5 ]
     [1 Tx6 ]
     [1 Tx7 ]
     [1 Tx8 ]
     [1 Tx9 ]
box { <-1.5, -0.5, 0.0>, <1.5, 0.5, 0.0> texture { TxOutput } }
