POV-Ray : Newsgroups : povray.binaries.images : Crockery Jug Server Time
30 Jul 2026 19:54:34 EDT (-0400)
  Crockery Jug (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Crockery Jug
Date: 20 Sep 2008 10:58:01
Message: <48d50f79$1@news.povray.org>
"Jim Holsenback" <jho### [at] hotmailcom> schreef in bericht
news:48d50dbe@news.povray.org...
> Bingo! ..... I see where I wandered off the path. Thanks Thomas!
You are welcome, Jim. I remember some time ago, I hit my head against the
same wall  :-)
Date: 20 Sep 2008 15:27:06
Message: <48d54e8a@news.povray.org>
Jim Holsenback wrote:
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
> news:48d503c5$1@news.povray.org...
>> It should be possible to do this in a layered texture. See for instance
>> the following example from one of my textures where I added an image_map
>> as the uppermost texture layer:
> Jim
Now that you can place textures how you want them, you can always try my
proximity pattern macros
(news://news.povray.org:119/489f4610@news.povray.org) to get some dirt
into the inside edges. I'd like to see how it turns out :)
Sam
Date: 20 Sep 2008 17:36:45
Message: <48d56ced$1@news.povray.org>
Jim Holsenback nous illumina en ce 2008-09-20 08:04 -->
> Howdy,
> I'm working on some objects for a scene that have maker marks or
> decorations. The swan on this jug is from a photograph of an actual jug in
> my shop. I used Gimp to play with the color map. I saved the gif image with
> indexed color map, then I was able to use several transmit statements in my
> image_map statement to isolate the background and image. Before all this I
> had developed a texture_map that has some age marks (dents), but when I
> tried to overlay the swan texture onto the crock texture I ran into a
> problem (can't overlay a texture over a patterned texture). I was however
> able to at least get it this far when I removed the dents portion of my
> texture map. Now my jug looks rather sterile and I'd like to age it up a
> bit. Any ideas on how to do this?
> Jim
Why bothering using several transparency statements in am image_map? You can set
your GIF to have one, or several color, as transparent. That way, you can make
the background disapear.
Or, you could have used a PNG with an alpha channel, and have antialiased
transparency.
The tree of liberty must be refreshed from time to time with the blood of
patriots and tyrants.
Thomas Jefferson
Date: 21 Sep 2008 06:54:54
Message: <48d627fe@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:48d56ced$1@news.povray.org...
> can set your GIF to have one, or several color, as transparent. That way,
> you can make the background disapear.
> transparency.
this was something new to me so maybe my work flow needs a look still. I
ended up with a color_map with 16 colors. Some of thhe colors were gradients
of blue (transition between the blue swan outline and the background). I
made all the transition colors all blue or all white. Then ended up with the
texture statement looking like this:
      image_map {
        gif "Swan.gif"
        transmit 11,1.0
        transmit 12,1.0
        transmit 13 1.0
        transmit 14,1.0
        transmit 15,1.0
        once
      scale <0.05,0.25,0.05>
      scale 3
      warp {cylindrical}
      translate y*1.4
      rotate y*300
maybe not the most elegant but it worked for what I wanted.
Jim
Date: 21 Sep 2008 06:57:01
Message: <48d6287d@news.povray.org>
"stbenge" <THI### [at] hotmailcom> wrote in message
news:48d54e8a@news.povray.org...
> Sam
ooooo good idea .... i'll have a look :-)
Jim
Date: 21 Sep 2008 22:45:01
Message: <web.48d70593653cbf5c67b294d0@news.povray.org>
> > Sam
> Jim
If all else fails, function patterns can do almost anything...
-tgq
Date: 22 Sep 2008 05:03:45
Message: <48d75f71@news.povray.org>
news: web.48d70593653cbf5c67b294d0@news.povray.org...
>> > my
>> > Sam
>> Jim
Image pattern is a good choice as well :-)
Marc
Date: 22 Sep 2008 22:59:07
Message: <48d85b7b$1@news.povray.org>
That's *cheating*! ;-)
William Tracy
The UNIX system has a command, nice, which allows a user to voluntarily
reduce the priority of his process, in order to be nice to the other
users. Nobody ever uses it.
     -- Andrew Tannenbaum, _Modern Operating Systems_
Date: 23 Sep 2008 02:53:06
Message: <48d89252$1@news.povray.org>
48d85b7b$1@news.povray.org...
Uh why? where? too easy?
Marc
Date: 23 Sep 2008 03:19:50
Message: <48d89896$1@news.povray.org>
"William Tracy" <wtr### [at] calpolyedu> schreef in bericht
news:48d85b7b$1@news.povray.org...
Cheating is making a jug in POV-Ray and selling it for the real thing  :-)
