POV-Ray : Newsgroups : povray.binaries.images : PoVEarth, day #6.5 - problem with fading fill light Server Time
30 Jul 2026 22:31:42 EDT (-0400)
  PoVEarth, day #6.5 - problem with fading fill light (Message 11 to 13 of 13)
Subject: Re: PoVEarth, day #6.5 - problem with fading fill light
Date: 5 Aug 2008 15:47:53
Message: <4898ae69@news.povray.org>
High!
Reactor schrieb:
> Three different things come to mind:  The first is a composite of 2 or more
> renders with different light settings,
Too cumbersome, as I plan, in the long run, to render animations of "My
Place in the World"...
> the second is using HDRI in MegaPov,
I'm an orthodox PoV-Ray fundamentalist... (as you can tell from my beard!)
THOU SHALT NOT USE ANY OTHER RAYTRACER!!!
> and
> the last is something that occurred to me when you mentioned the rooms are
> differenced out of a larger object.  Why not use the same pigment for indoor
> and outdoor objects, but a different diffuse value?
I've tried that, but then the rooms in the building vis-a-vis drowned in
white...
Here is the closest I got towards what I aim for:
object
            light_group
              light_source
                <0.37, GWG_FrKarl_Block238to252_Floor_yOffset + a *
GWG_FrKarl_Block238to252_Floor_Height + 1.27, 2.43>/f
                color rgb 0.25
                spotlight
                point_at <11.08,  GWG_FrKarl_Block238to252_Floor_yOffset
+ a * GWG_FrKarl_Block238to252_Floor_Height + 1.27, 2.43>/f
                radius 89.9999
                falloff 89.9999
                shadowless
              object
                GWG_FrKarl_Block238to252_Floor_Cutout
                scale 1/f
                translate <0.37, GWG_FrKarl_Block238to252_Floor_yOffset +
a * GWG_FrKarl_Block238to252_Floor_Height, 0.37>/f
              global_lights on
...still the distribution of brightness on the inside wall is very
uniform, such as the room was in fact lit by artificial light
overshining the indirect illumination, although I used global_lights
on... perhaps I should try a smaller radius for the spotlight? Or
introducing some fade_distance/fade_power?
See you in Khyberspace!
Yadgar
Download '2008-08-05 my place on earth (altena version) wip, take 27 - inside my apartment,looking out, using light_groups with sp' (14 KB)
Preview of image '2008-08-05 my place on earth (altena version) wip, take 27 - inside my apartment,looking out, using light_groups with sp'
Date: 6 Aug 2008 04:09:51
Message: <48995c4f$1@news.povray.org>
"Reactor" <rea### [at] hotmailcom> schreef in bericht
news:web.48989ec3fa91c91bbf3475910@news.povray.org...
> more
Following that idea, why not try the technique developed by Tim Nikias (see:
Prepared for Company, a couple of years ago (2005), which I used in the
variation thereof in my ice age scene)? See:
http://www.nolights.de/gallery/reviews/prep4company.html
Tim described his technique in one of the ng's here. It makes use of a glare
macro (2003), which I do not see on his website. You might need to contact
Tim if you want to try out this path.
Date: 6 Aug 2008 19:30:00
Message: <489a33f8$1@news.povray.org>
> High!
> Blue Herring schrieb:
<Snippage>
> But how should that work if the objects are in different levels of a CSG
>  hierarchy - e. g. if the room is part of a difference, but the
> furniture in the room belongs to a union several levels higher (or even
> not at all to the same CSG object)?
> Yadgar
I find the question odd, I have done several projects of my own with
only a single point light, and a multi story, many room building
differenced in CSG.  As long as I remembered where the light was, the
angle it would hit the windows, the light seemed to reasonably mimic
what the eye might see.  From what I've seen, a "difference" behaves
like a physical hollowing, any openings will allow light in, if it's
directed in.
