POV-Ray : Newsgroups : povray.binaries.images : Copying pigments with crackle (124k jpg) Server Time
30 Jul 2026 22:33:41 EDT (-0400)
  Copying pigments with crackle (124k jpg) (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: crystal mass (64k jpg)
Date: 30 Jul 2008 04:07:33
Message: <48902145@news.povray.org>
"stbenge" <THI### [at] hotmailcom> schreef in bericht
news:488f9aa2@news.povray.org...
> Using the code modified to work in three dimensions, I applied a
> radiating crackle pattern to each cell. The resulting isosurface
> resembles aragonite.
I am speachless, Sam...
I just now realize the potentiality of your code!
Date: 30 Jul 2008 04:31:22
Message: <489026da$1@news.povray.org>
Ah, Sam!
This is fascinating! It seems carved wood too.
Paolo
> Don't mind the really low-quality aa settings. Isosurfaces render very
> slowly...
> Sam
Date: 30 Jul 2008 09:44:32
Message: <48907040$1@news.povray.org>
Fantastic!!
-The Mildly Infamous Blue Herring
Subject: Re: Copying pigments with crackle (124k jpg)
Date: 30 Jul 2008 14:31:53
Message: <4890b399@news.povray.org>
Here's something I made using Sam's techinique, slightly adapted to allow
coloured pigments, and some photos I took of the london motorshow.
My version of the  code is *really* inefficient, it took 48 minutes to
render at 1600x1200!
Tek
http://evilsuperbrain.com
"stbenge" <THI### [at] hotmailcom> wrote in message
news:488e5300@news.povray.org...
> Hi everyone,
> Years ago, somebody posted a swirly pigment. It resembled the swirls you
> see in clouds sometimes. I have tried looking for the code many times,
> but to no avail. The code has been lost.
> Every once in a while I try to recreate that code using pigment
> functions. Every time I've tried, I've failed. Until today.
> I based my work on the premise that the target pattern must be
> translated according to another pattern, in this case crackle form x.
> What I have arrived at must be different from the aforementioned
> poster's code, since his tended to have small gray boxes right at the
> center of each crackle cell. There is no such artifact in my code, and I
> can't be sure just how close my effect comes to his.
> Here is some code:
> #macro pcc(pgmt, Mod)
>  #local pgmt2=function{pigment{pgmt}}
>  #local pg1=
>  function{
>   pigment{
>    crackle form x
>    scale .25
>  pigment_pattern{
>   function{
>    pgmt2(
>     (pow(pg1(x+Mod,y,z).grey,2)-pow(pg1(x-Mod,y,z).grey,2))/(Mod*64),
>     (pow(pg1(x,y+Mod,z).grey,2)-pow(pg1(x,y-Mod,z).grey,2))/(Mod*64),
>     z
>    ).grey
> #end
> #declare my_pigment=
> pigment{
>  pcc(
>   pigment{
>    spiral1 1
>    sine_wave frequency 1
>    scale .125
>   ,.085
> The macro takes two arguments. The first is the pigment you wish to have
> copied into each crackle cell. The second indicates how sharp you want
> the edges to be. Smaller values = sharper edges. The macro returns a
> pigment_pattern, so it can be used in any pattern block (pigment,
> normal, texture, etc.)
> I hope some of you find a use for this. I had hoped to use it for making
> height fields. I'll post any interesting results I might get.
> Sam
Download 'crackle_paternizedphoto.jpg' (242 KB)
Preview of image 'crackle_paternizedphoto.jpg'
Date: 30 Jul 2008 15:03:21
Message: <4890baf9@news.povray.org>
Thanks, I hope you find it useful!
My original idea for this code was to fake erosion by placing a radial
pigment at each hill/cell. In my mind it worked brilliantly, but in
reality, well, I don't have to show you :)
Sam
Date: 30 Jul 2008 15:03:47
Message: <4890bb13$1@news.povray.org>
Paolo Gibellini wrote:
> Ah, Sam!
> Paolo
Thanks!
Sam
Date: 30 Jul 2008 15:05:07
Message: <4890bb63$1@news.povray.org>
Blue Herring wrote:
> Fantastic!!
I was actually inspired by some real aragonite we found not far from
here. I'll post a photo if I can find a specimen in time...
Sam
Date: 30 Jul 2008 15:20:01
Message: <web.4890be074f928167ff8a991c0@news.povray.org>
> > Yes, you can get some interesting effects. Here, try this out:
> Yeah but it distorts the pattern, one of the things that's great about your
> first post is that it duplicates my pattern into every cell, but with metric
> one it breaks it.
Hmm, I don't know if what you want is possible... "You can't change the laws of
physics," as my mom would say, or in this case, the laws of mathematics ;)
> > It makes rectangular masses all over the place. Nest a few of those with
> > different translation values, and a cityscape might be possible.
> I've already got the city:
Ah yes, now I remember.
> But I really need a perpendicular pattern to the crackle, something like the
> radial example in your original post, but perpendicular to metric 1.
> I don't think it's possible though :(
What are you after? Are you planning to make vertical ridges going up along the
sides of each building? Can my code (without metric 1) be applied into each
metric 1 cell to achieve your goal? It wouldn't wrap perfectly around the
metric 1 cells, but would still be central to each cell. Buried in a
pigment_map, you could hide the discontinuities between the metric 1 and metric
2 cell edges.
Sam
Date: 30 Jul 2008 15:25:00
Message: <web.4890bfd54f928167ff8a991c0@news.povray.org>
Actually, my code is rather slow, too. It doesn't seem slow until you try to
make a height_field with it. Most height fields don't take that long to parse!
Isosurfaces don't seem to be affected in the same way.
Sam
Date: 30 Jul 2008 15:45:00
Message: <4890c4bc@news.povray.org>
Crackle seems to be pov's slowest pattern, and this technique accesses it
multiple times.
Tek
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:web.4890bfd54f928167ff8a991c0@news.povray.org...
> to
> parse!
> Sam
