POV-Ray : Newsgroups : povray.binaries.images : Tek's sea revisited Server Time
26 Jun 2026 06:18:08 EDT (-0400)
  Tek's sea revisited (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Tek's sea revisited
Date: 22 Nov 2006 07:27:05
Message: <45644219@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
news:web.45643206a1eb5d8bf1cb1e660@news.povray.org...
> Humph!
> Now you're showing your age :-) I only go back as far as dip pens
<cackle! cackle!> Just only 1..60 years old, young man!
Date: 22 Nov 2006 07:35:46
Message: <45644422@news.povray.org>
Experimenting further.
To align apparent wind direction and ship behaviour, I mirrored the
isosurface's function around x. Of course, I could have turned the ship, but
that is the easy way out and I prefer to experiment.
What I did was change: f_ridged_mf( (x+y*.2)/4, Q+y*.4, z/4, etc.  into:
f_ridged_mf( ((x+y*.2)/4)/-1, Q+y*.4, z/4, etc
and: (f_spotted(x/5+y/5, 0, z/5)-.5)*1  into: (f_spotted((x/5+y/5)/-1, 0,
z/5)-.5)*1
To stay on the save side, I added the parenteses before multiplying by -1.
This should be faster than mirroring the isosurface itself. But maybe this
introduces unwanted things. What do you think?
Download 'Tek_RoughSea.jpg' (180 KB)
Preview of image 'Tek_RoughSea.jpg'
Date: 22 Nov 2006 08:10:01
Message: <web.45644c0da1eb5d8bf1cb1e660@news.povray.org>
> z/5)-.5)*1
> Thomas
The sea looks very different, most of the white horses have gone and the
noticed that yourself.
What does the scene look like if the camera is placed on the other side of
your ship, should it not look like the way it was before?
Date: 22 Nov 2006 08:24:53
Message: <45644fa5$1@news.povray.org>
news:web.45644c0da1eb5d8bf1cb1e660@news.povray.org...
>> Thomas
> foreground is smooth. Quite reflective in fact. But then you'll have
Yes, you are right! I just discovered a moment ago that I forgot to mirror
the function in the texture too!! :-(
That accounts for the loss of white horses. A new image is being brewed on
the POV burner. I shall post it later this afternoon. From what I can
already see, the white horses are back!! :-)
One reason why I did not want to move the ship (or the camera, for the time
being) is that I like the light incidence on it. However, it is mainly
because I want to play a bit with the functions and see what happens in the
present context.
I don't know, presently about the foreground. There seems to be a large
swale here. Later I shall lift the camera to see how it looks from above and
if this is recurring elsewhere.
Date: 22 Nov 2006 09:05:00
Message: <web.456458a1a1eb5d8bf1cb1e660@news.povray.org>
One other thing in the original post of the modified scene you said that you
multiplied by -1 when you actually divided by -1.  I know the results are
the same (I hope) is there any particular reason?
Actually there were two other things. On my works monitor the image looks a
little washed out, what gamma settings are you using?
> present context.
> Thomas
Date: 22 Nov 2006 10:02:37
Message: <4564668d$1@news.povray.org>
news:web.456458a1a1eb5d8bf1cb1e660@news.povray.org...
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
> Oh! We learn by our mistakes and I've learned a lot :-)
> you
Ah! According to the documentation (c paragraph 2.3.3.3.9) transformations
on functions are different. So multiplying x by 2 is given as (x/2, y, z).
See the docs for more details. This is a very important paragraph because it
allows you to manipulate the functions as you want. It helped me enormously
in building my Geomorph macro a couple of years ago (see:
http://povray.tirnalong.com/ow.asp?GeoMorph ).
> a
I have the same when first viewing the image in WindowsExplorer for
instance. Saving it again in PSP without doing anything generally takes care
of the problem. It come from the new gamma handling in version 3.7. It has
been replaced by display_gamma in the ini, and set at 2.2. If  I read the
docs right, presently 'assumed_gamma = 1' is automatically translated to
'display_gamma = 2.2' but I am not sure about this. Still a thing to
investigate.
Date: 22 Nov 2006 11:20:00
Message: <web.45647829a1eb5d8bf1cb1e660@news.povray.org>
> > you
That makes sense to me <g> I don't do hard things.
> > a
> investigate.
Interesting, Thanks
Date: 22 Nov 2006 14:30:01
Message: <web.4564a442a1eb5d8ba0c272b50@news.povray.org>
> Here is an image with Tek's rough sea, and my Moray built VOC ship (in need
> of an upgrade!). Only the flags were not rendered due to a uv_mapping issue
> in version 3.7.
> total render time (v.3.7) about 2 hours, with a HP Media Center PC; Pentium
> D 2x3GHz
> Not the most perfect scene, but just to show off  :-)
> Thomas
Nice pic, but the captain will be court martialed and keel hauled for
running full sail in that kind of weather merely to appease your artistic
vision!
Date: 22 Nov 2006 15:55:45
Message: <a0e9m29nki4bu5ei6rbij87smtouu27frh@4ax.com>
On Wed, 22 Nov 2006 13:27:04 +0100, "Thomas de Groot" <t.d### [at] internlDOTnet>
>> Humph!
>Thomas
Young man! Why thank you. You "silver surfer". you :-)
I'm not far behind you only 4 years.
Regards
Date: 22 Nov 2006 16:04:56
Message: <pqe9m2d6nep75994s9fhm5lujkolg35k5b@4ax.com>
On Wed, 22 Nov 2006 16:02:36 +0100, "Thomas de Groot" <t.d### [at] internlDOTnet>
>investigate.
FYI
At home using my laptop I need to do a gamma correction of 0.38 with PSP. It
then looks dramatic & great.
Regards
