POV-Ray : Newsgroups : povray.binaries.images : mesh2 coloring problems Server Time
31 May 2026 13:07:44 EDT (-0400)
  mesh2 coloring problems (Message 1 to 3 of 3)
Subject: mesh2 coloring problems
Date: 8 May 2006 10:09:23
Message: <445f5113@news.povray.org>
Maybe someone has some info that might help me out.  The only thing I
can think this could be is the scaling problem that comes up when
someone tries to render our solar system and a pencil on earth in real
scale in relation to each other - something to do with working with
really large and really small numbers at the same time.
I'm trying to render a mesh2 and am running into some problems with the
pigment on individual triangles.
The following scene is a single mesh2 face that was painstakingly
isolated so that I could better understand the problem.
The first image is the render of the scene - a white triangle, not the
expected results.
But if I modify one of the vectors I get something similar to image #2.
image 2 - modify vector 1
<57312.569,784.27165,53547.105>,  original
<57312.568,784.27165,53547.105>,  modified
But results vary with what I modify - image 3
image 3 - modify vector 2
<57310.236,784.35367,53548.234>,  original
<57310.237,784.35367,53548.234>,  modified
Image 4 is what the big mesh looks like with the little white faces
sticking out like a sore thumb.  The white face on the far right is my
example face that I was able to isolate.
This is not a mesh that I want to modify by hand.  It is about 400,000
faces with about 200,000 vertexes.  The final scene will likely have
many more faces and vertexes.
Does anyone know what might be going on, and/or know what can be done to
fix it?  It would be really nice to get rid of the white as it detracts
from the presentation that we are trying to do.
light_source {<57312,1784,53547> rgb 1}
camera {location <57312,804,53547> look_at <57312,784,53547>}
mesh2 {
vertex_vectors {
3,
<57312.756,784.26509,53547.605>,
texture_list {
3,
texture{pigment{rgb<0.1,0,0>}}
texture{pigment{rgb<0,0,1>}}
texture{pigment{rgb<0.3,0.3,0.3>}}
face_indices {
1,
<1,0,2>,1,0,2,
Download 'white_triangle_isolated_1.jpg' (3 KB) Download 'white_triangle_isolated_2.jpg' (3 KB) Download 'white_triangle_isolated_3.jpg' (3 KB) Download 'white_triangle_many_4.jpg' (88 KB)
Preview of image 'white_triangle_isolated_1.jpg'
Preview of image 'white_triangle_isolated_2.jpg'
Preview of image 'white_triangle_isolated_3.jpg'
Preview of image 'white_triangle_many_4.jpg'
Subject: Re: mesh2 coloring problems
Date: 10 May 2006 12:45:05
Message: <44621891$1@news.povray.org>
> I can think this could be is the scaling problem that comes up when
> real scale in relation to each other - something to do with working
> with really large and really small numbers at the same time.
Have you tried search/replace the camera and vertex_vectors sections
'>/10' for '>'? Fixes your examples.
  -Shay
Date: 11 May 2006 08:40:51
Message: <446330d3$1@news.povray.org>
You are saying scale down the scene by a factor of 10- right...
I don't believe that we've tried a pure scale like that on the whole
data set.  I'll have to try it to see if it kills the problem.
For now we translate the whole thing closer to the origin.  It's worked
for now, but if we have to do more of this work, it might not.
I am curious as to what causes this behavior in POV-Ray. When one
understands the cause, then one has the ability to avoid it.
Thanks for your help
Tom
