A common problem facing POVers is how to difference (ouch, that
shouldn't be a verb!) a bunch of CSG objects from another one, without
taking hours and hours to render.
Mike Williams has a great tutorial (
http://www.econym.demon.co.uk/holetut/ ) that talks about two of the
methods (subdividing the object and using isosurfaces). Another handy
method is to use blobs with negative strength component.
In the first and second pictures I created a blob with a big, flat
sphere and a bunch of negative cylinders, and then intersected the
result with a box. Render times were under 2 minutes, and, as the
second picture shows, an advantage is that you don't need regularly
spaced holes (as you would with the subdivision method.)
The third picture shows why I was needing a quicker difference. I've
been modeling "milling processes," where a milling tool rotates and cuts
pieces out of a block. If the block is a cylinder or a box, the
subdivision method works fine, with a little prep work, but when you're
carving out of some more irregularly shaped thing, this negative blob
method is much easier. In the fourth picture, I put the milling union
back in (slightly smaller) as a separate blob, to see how the carving
was done.
If anyone's interested, I can post the sources to PBSF or PTSF.
Dave Matthews
Download 'nt007b.jpg' (31 KB)
Download 'nt007c.jpg' (20 KB)
Download 'nt006e.jpg' (24 KB)
Download 'nt006d.jpg' (24 KB)
Preview of image 'nt007b.jpg'
![nt007b.jpg](/povray.binaries.images/attachment/%3C41b0a858%40news.povray.org%3E/nt007b.jpg?preview=1)
Preview of image 'nt007c.jpg'
![nt007c.jpg](/povray.binaries.images/attachment/%3C41b0a858%40news.povray.org%3E/nt007c.jpg?preview=1)
Preview of image 'nt006e.jpg'
![nt006e.jpg](/povray.binaries.images/attachment/%3C41b0a858%40news.povray.org%3E/nt006e.jpg?preview=1)
Preview of image 'nt006d.jpg'
![nt006d.jpg](/povray.binaries.images/attachment/%3C41b0a858%40news.povray.org%3E/nt006d.jpg?preview=1)
