POV-Ray : Newsgroups : povray.binaries.images : Raytraced luminous color bleeding (80kb jpeg) Server Time
4 Aug 2026 16:54:43 EDT (-0400)
  Raytraced luminous color bleeding (80kb jpeg) (Message 21 to 23 of 23)
Subject: Re: Raytraced luminous color bleeding (80kb jpeg)
Date: 26 Jun 2004 12:54:25
Message: <40DDA9DA.3060101@hotmail.com>
Tim Nikias wrote:
> This reminds me of my Glare-Include I've written a while ago. What I did was
> to render the scene with Black-Textures and Specular-Highlights only, then
> calculate the position for the Glare-Image in-scene. Using average-pattern,
> I blurred the image a little and thus got me the glaring effect.
That would be perfect for ocean scenes and rolex scenes :) I can't
imagine lining the image up 'in scene' though... sounds very difficult.
Can you post a link to an example of your technique?
> Do you use the colored output of your image as input for the blooming
> effect?
Yes. I have to first place the #declared image_map inside a
pigment_pattern block, which makes it grayscale. With that map I am able
to make the darks parts transparent and the light parts colored with my
original image_map. I blur the result over a plane with the original
image_map, untouched. I am thinking of releasing the code, but it has to
be cleaned up quite a bit.
-Sam
Date: 26 Jun 2004 19:50:52
Message: <40de0bdc$1@news.povray.org>
was
then
average-pattern,
It's in my Download-Section:
http://www.nolights.de/download.html#Glare Macros
What I do is just a little arithmetic: take the camera's location and
look_at (along with right, up, and sky) and calculate the viewing frustrum
from that. Place a quad (two triangles) in the line of sight with the
described image_map-function, and there you go! You can have a look at the
source if you like. But linking to my Download-Section should imply that.
"Tim Nikias v2.0"
Date: 28 Jun 2004 05:53:05
Message: <40dfea81$1@news.povray.org>
Samuel Benge wrote:
> Hello everyone. Today I made a scene file which takes an image and
> applies a 'bloom' effect to the bright parts. The example attached is a
> bit overdone to show the results. I can control which values in the
> image are active.
   It's a very nice effect, and the scene you used for the test is also
beautiful and very apropiated.
> I think that this technique is probably okay to use in the IRTC, but I
> wonder if it would be considered a post-processing step or not....
   I think it is clearly a postprocessing filter, but it is allowed as
it is done by the same renderer. If you do it automatically using a two
pass technique it's perfectly "legal". Other thing is if the judges will
detract point for it not being a "true" 3D effect... I will not, as I
see it as a very creative use of the renderer, wich is what the spirit
of the competition is all about, IMHO.
   Indeed, congrats: I see your inspiration is coming back!
Jaime
