POV-Ray : Newsgroups : povray.binaries.images : many cubes [75 KB] Server Time
4 Aug 2026 21:30:16 EDT (-0400)
  many cubes [75 KB] (Message 12 to 21 of 21)
Subject: Re: many cubes [45 KB]
Date: 18 Apr 2004 07:59:23
Message: <40826d9b@news.povray.org>
Hash: SHA1
	Here it is at recursion 4...
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAgm2ZqIYJdJhyixIRAn7xAJ9GAPreW0mjdGtMkAtxAjit2cTTkQCfU42j
kVlZLwukg0ibNBmTNU1xEMQ=
=RbfS
-----END PGP SIGNATURE-----
Download 'blok.jpg' (45 KB)
Preview of image 'blok.jpg'
Date: 18 Apr 2004 08:03:34
Message: <40826e96@news.povray.org>
very cool!, but you turned of the reflection of the ground plane didn't you?
How long did it take to parse/render?
Greetings,
JWV
news:40826d9b@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Jerome
> =RbfS
Date: 18 Apr 2004 14:25:14
Message: <4082c80a@news.povray.org>
Hash: SHA1
	Parse time: 19s
	Render time: 3236s (~55mn)
	The computer used is an Athlon XP 2700+ with 2x256M of RAM in dual
channel mode and 1GB of swap running linux mandrake 9.1 (kernel
upgraded to 2.4.22)
		Jerome
iD8DBQFAgsgJqIYJdJhyixIRAk9lAKCdc4d8N+qOB3cs6N53NU788F9R+wCgj5UF
aUQsLh3ytNglrW5WHRnSJ4I=
=HYFZ
Date: 19 Apr 2004 13:40:39
Message: <40840f17@news.povray.org>
Hash: SHA1
	Higher resolution version (1152x864) is at
http://jeberger.free.fr/tmp/blok.jpg
	Render time was 28min????
		Jerome
iD8DBQFAhA8WqIYJdJhyixIRAsXTAJ4gPp4sfmldBsVfT9yNCHoltcN/4ACghnUw
2J7t3HdTml6eCMC+ZQ8QewU=
=CZQf
Subject: Re: many cubes [75 KB]
Date: 19 Apr 2004 15:26:43
Message: <opr6pxmsrnzjc5hb@news.povray.org>
On Sat, 17 Apr 2004 19:27:53 +0200, JWV <jwv|at|planet.nl> wrote:
> Thanks for trying it! The level 4 scene should have about 48^4=5.308.416
> cubes. I am not sure how much memory is used for this amount, but it
> apears
> to be quite a lot.
There are ways to overcome such limitations and render fractals with
greater recursion depth. The most effective (in my experience) is to
generate a mesh (either externally or in POV-SDL) of the fractal at a
convenient depth, and then use that mesh as the low level building block
in the bigger fractal. The reduction in memory usage can be quite
dramatic. The important thing is to keep the total number of objects
within reasonable bounds. 48^4 cubes is a little much for POV-Ray to
handle; 48^2 or 48^3 mesh instances might work better. Unfortunately,
POV-Ray doesn't handle huge meshes very well, but you might be able to
reach level 5 (or more) that way.
FE
Date: 20 Apr 2004 16:00:28
Message: <opr6rtu8fxzjc5hb@news.povray.org>
On Mon, 19 Apr 2004 21:26:42 +0200, Fredrik Eriksson <noo### [at] nowherecom>
Just to show that it's possible:
http://hem.bredband.net/b230591/povray/cubefractal5_2048.jpg (828 kB)
http://hem.bredband.net/b230591/povray/cubefractal6_4096.jpg (2.69 MB)
FE
Date: 20 Apr 2004 16:51:06
Message: <40858d3a@news.povray.org>
Is that POV or Pixie?
Date: 20 Apr 2004 21:29:38
Message: <4085ce82@news.povray.org>
> wrote:
<snip />
God bless recursion, every one in a one in a one in a one...
Respectfully,
Dan P
http://<broken link>
Date: 21 Apr 2004 13:27:40
Message: <4086af0c@news.povray.org>
Hash: SHA1
	Both my renders were done with pixie...
		Jerome
iD8DBQFAhq8LqIYJdJhyixIRAu45AJkBdMlHf7cKISheH638sPvcC/YlFACfTuy4
C/a1/nogEGaY59x2PcCDOlI=
=ZdrS
Date: 22 Dec 2004 15:20:00
Message: <web.41c9d6789e31cbafdcad99600@news.povray.org>
Sorry to be coming late to this, but I'm willing to try it...I have a G5
with 4 gig of RAM and would be interested to see how it goes.
Zesty
"JWV" <jwv|at|planet.nl> wrote:
> The level-4 render was to much for my laptop :-(. It used 2GB of memory
> while parsing, and it wasn't finished jet.
> I will post the source in p.b.sf if someone wants to give it a try on a
> machine with a LOT of memory  :-).
> Greetings JWV
> "JWV" <jwv|at|planet.nl> wrote in message news:408027c5@news.povray.org...
> > Hello,
> > This is my latest desktop wallpaper attempt. Is are 110592 cubes, placed
> my
> > an algoritm. This image has an "recursion-level"of 3, and i am currently
> > rendering one with level 4, which has 48 times as much cubes.
> > a large .jpg version [1600x1200] of both images will be available at
> > home.student.utwente.nl/j.w.a.vaandrager/background_L3g.jpg
> > change the L3g to L4g to view the "level-4" image when it's done.
> > Comments and critisism is welcome as usual.
> > Greetings,
> > JWV
