POV-Ray : Newsgroups : povray.binaries.images : Cavorite Sphere (off the shelf) [~105K JPG] Server Time
15 Oct 2026 12:43:16 EDT (-0400)
  Cavorite Sphere (off the shelf) [~105K JPG] (Message 51 to 60 of 60)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: Cavorite Sphere (off the shelf) [~105K JPG]
Date: 25 Apr 2004 18:34:55
Message: <408c3d0f$1@news.povray.org>
Alain wrote:
> Receive visible light, absorbs it and transform it to heat, re-emit it
> as thermal infrared light. Energy in = energy out.
Haven't you heard of launching lasers and light sails? :-) Anyway, you
*can* hold energy from absobed light indefinitely. That's what
photosynthesis does.
Darren New, San Diego CA USA (PST)
   I am in geosynchronous orbit, supported by
   a quantum photon exchange drive....
Date: 25 Apr 2004 20:06:08
Message: <cjameshuff-A983E8.20050325042004@news.povray.org>
In article <408c3d0f$1@news.povray.org>, Darren New <dne### [at] sanrrcom>
But you can't continue to accumulate it indefinitely...for example, if
the stored energy were never used, plants would eventually run out of
CO2 and H20 to build the sugars which they store the energy in. You will
eventually reach some equilibrium where total input == total output.
However, if albedo includes radiation as well as reflection, then
objects like suns and gas giants have albedos greater than 1.
Also, albedo could be used to refer specifically to visible light...in
which case it would actually be possible for the reflective albedo to be
greater than 100%, due to fluorescent materials on the surface.
Extremely unlikely on a dead rock, though a planet with a large amount
of fluorescent plant life could do it naturally.
http://tag.povray.org/
Date: 25 Apr 2004 20:34:18
Message: <408c590a$1@news.povray.org>
Sure you can. You build oxygen and sugar from CO2 and H2O and photon
energy, and then you dump the resulting high-energy chemical bonds into
the environment. Someone else will eat it, and potentially emit more
radiation than they absorbed.
Someone wrote "Truth: A body cannot reflect less light than is applied
to it."  That particular statement is just not the truth without some
qualifiers like "for a large enough body (but not too dense) over a long
enough time." Radiation isn't conserved. Energy is conserved.
Granted, on something like a planet, the difference is likely to be small.
Follow-ups to off-topic.
Date: 25 Apr 2004 20:47:32
Message: <408c5c24$1@news.povray.org>
Alain wrote:
> Dan P nous apporta ses lumieres ainsi en ce 2004/04/25 13:04... :
>> Jellby wrote:
>>> Among other things, Dan P wrote:
>>>> Truth: A body cannot reflect less light than is applied to it.
>>> Huh?
>> Yep; strange to think that way, I know, but that is a truth!
>> (Please don't bring up black holes either -- we aren't modelling those)
Right; the light that is does not reflect it absorbs and converts to heat.
Respectfully,
Dan P
http://<broken link>
Date: 25 Apr 2004 20:49:23
Message: <408c5c93$1@news.povray.org>
Heat actually is a form of light. Actually, all matter is made of light
as well.
Respectfully,
Dan P
Date: 25 Apr 2004 20:58:38
Message: <408c5ebe$1@news.povray.org>
Albedo does not include radiation by definiton. An object that emits
light radiation, like a sun, is the light source!
Also, if you count radiation outside of the visible spectrum, an albedo
will be a fraction of /all/ of that radiation, including the visible
stuff, which would /still/ be a value between zero and one.
Such materials emit light and, therefore, cannot be a valid part of an
albedo value by definition. Albedos only concern /reflected/ light. If
an albedo value is above 1, it is an error -- it is not a /valid/ value;
it means that there is emissive material on the surface or a flaw in the
instrument that is reading the value.
Respectfully,
Dan P
Date: 25 Apr 2004 21:46:18
Message: <408c69ea$1@news.povray.org>
No, it's a form of energy, specifically kinetic energy of atoms. Heat
isn't measured in "photons". You seem to be confusing infrared photons
with energy.
> Actually, all matter is made of light as well.
No. Matter is made of energy. (Actually, no, not really. But matter can
be converted to energy and back again.) Light isn't energy, it's photons.
You seem to be confusing the concepts of "energy" and "light". A proton
isn't made of photons (but rather quarks), but it can be converted to
energy.
Date: 25 Apr 2004 22:11:31
Message: <cjameshuff-1982DA.22102625042004@news.povray.org>
In article <408c5c93$1@news.povray.org>,
Heat is a mass property of large groups of particles, related to the
kinetic energy of the particles in the group. Heat is not infrared
light, infrared just happens to be emitted by hot objects and readily
absorbed by objects, heating them in the process. Hotter objects will
emit in the visible range. Really, really hot objects emit in the
X-ray/gamma range, but you don't really even have things like atoms at
those energy levels.
Er, matter and energy are equivalent, and one can be converted to the
other. Light is another form of energy, but saying matter is made of
light is like saying mountains are made of stone walls because both are
made of stone.
Date: 25 Apr 2004 22:48:46
Message: <408c788e$1@news.povray.org>
> with energy.
> energy.
You're probably right; I'm confusing light with energy.
Respectfully,
Dan P
Date: 26 Apr 2004 09:29:01
Message: <408d0e9c@news.povray.org>
I albedo refers only to reflection, it cannot be higher than 1 and it can be
certainly lower. The emr (electromagnetic radiation) absorbed and then
emitted (possibly at a different wavelength) by the body is not reflection,
it's (heat, black-body) radiation, fluorescence, or whatever.
If albedo refers to all kinds of emissions, it can be higher than 1. The
Earth was probably born as a giant molten rock ball, now it has a more or
less solid crust, some energy has been lost and radiated to outer space.
The albedo can also be lower than 1 if the received energy is transformed
to a different kind of energy and accumulated in the body itself.
If we are talking about a closed system (no exchange of matter) and in
equilibrium (something not trivial), then yes, as much energy as it is
received must be released. But energy is not only emr.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
