POV-Ray : Newsgroups : povray.binaries.images : Cavorite Sphere (off the shelf) [~105K JPG] Server Time
5 Aug 2026 00:01:18 EDT (-0400)
  Cavorite Sphere (off the shelf) [~105K JPG] (Message 41 to 50 of 60)
Subject: Re: Cavorite Sphere (off the shelf) [~105K JPG]
Date: 24 Apr 2004 19:21:46
Message: <408af68a@news.povray.org>
Christoph Hormann wrote:
> Dan P wrote:
>>> Earth is neither 21% brighter nor 21% more bright than moon assuming
>>> the given albedo values.  If you want to give percentual values you
>>> have to do it correctly, otherwise simply say the albedo of earth is
>>> 0.21 higher than that of earth (which of course isn't a very useful
>>> information).
>> The values are between 0 and 1. If they were between 0 and two, the
>> percentage would be half of what I said and so forth.
> That's nonsense - in fact the albedo isn't even limited to [0..1] by
> definition.  Anyway i am not really interested in convincing you from
> using correct formulations if you don't want to, my arguments were clear
> and easy to understand IMO, the rest is up to you.
You may be right. This is what I understand about albedo values:
0 = Reflects no light.
1 = Reflects all light.
An surface cannot reflect a negative amount of light.
An surface cannot reflect more light than is provided to it.
This understanding may be incorrect; I'm wrong a lot!
My ego is not invested in being right here -- for the good of the group,
please set us straight, Christoph! (The last sentence is actually not
being sarcastic).
Respectfully,
Dan P
http://<broken link>
Date: 24 Apr 2004 20:55:34
Message: <408b0c86$1@news.povray.org>
>> Dan P wrote:
<snip />
> being sarcastic).
Another thing; when I speak of an albedo value, I only speak of the
value itself, not the application of the value. As you have mentioned,
the albedo value depends on the angle the viewer observes it. If you
bring in time, a body like Venus rotates over time and, thus, the albedo
value changes because the surface the light is exposed to changes. So,
an albedo value like the ones the web site provided are averages at best
and are only useful for quantifying, somehow, the relative albedos of a
set of objects; for example, how much more bright the object appears
from earth compared to some other body in the set. It may also be useful
for detecting changes on a surface. There are all kinds of APPLICATIONS
for an albedo value, but this does not change the NATURE of an albedo value.
If an albedo value is not from 0 to 1, then it is bound within some
arbitrary range described by the object with the highest albedo value we
have observed at some moment in time. The definition, "the fraction of
light that is reflected by a body or surface." can support this: a
fraction can be 2+1/2, for example, or 250%. So, if we were to observe
an albedo value of Venus at some moment in time, then we could say at
some future moment in time that the albedo value is 250% higher than before.
I thought this was interesting:
"At BRW and MLO, albedo values above 1.0 are due to instrument noise at
low aerosol concentration. These high albedo values are not present in
daily averaged data. Furthermore, these high albedo values are not
present if data are excluded where ?sp is below 1 Mm-1. Hence, the high
albedo values result from an instrument detection limitation problem."
http://www.cmdl.noaa.gov/publications/annrpt26/3_1_3.pdf
So, an albedo value can be above 1, but is it valid?
I'm finding it hard to find albedo values above 1. Take the following
example of snow albedos:
http://www.agu.org/pubs/sample_articles/cr/2001JD001160/figures.shtml#fig15
They assume from 0 to 1 on their graphs. Same for this site:
http://cires.colorado.edu/~maurerj/albedo/albedo.htm
So, the crux: the definition itself does not specify that an albedo must
be from 0 to 1, but I believe that to be axiomatic (self-evident). I
will attempt to create a proof:
Truth: A surface may not reflect less light than is applied to it.
Truth: A surface may not reflect more light than is applied to it.
Truth: A body cannot reflect less light than is applied to it.
Truth: A body cannot reflect more light than is applied to it.
Therefore
A minimum albedo means a surface reflects no light.
A minimum albedo means a body reflects no light.
A maximum albedo means a surface reflects all light.
A maximum albedo means a body reflects all light.
0% of light means no light.
100% of light means all light.
0% may be represented as 0.
100% may be represetnted as 1.
Therefore
A minimum albedo is 0
A maximum albedo is 1
If you have some further truths to add to this proof to disprove my
claim, please add them; it will help mine and other's understanding of
this interesting subject!
Some more web-sites of interest:
http://www.experimentarium.dk/uk/naturvidenskab_og_teknik/artikler/artikel.118.html
http://en.wikipedia.org/wiki/Albedo
(See, Mom, I can sound smart too!)
Respectfully,
Dan P
Date: 25 Apr 2004 01:14:21
Message: <408b492d@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-253827.19080523042004@news.povray.org...
> In article <40889a54@news.povray.org>, "St." <dot### [at] dotcom> wrote:
> > > We've been there, remember? ;-)
> >     Heh, yes, I think I was about 6-7yo, cross-legged, wearing
grey
> > shorts, grey socks, in our sports-hall, watching a black and white
TV
> > when they touched down. A nice memory.  :)
> Er...well, I didn't mean personally remembering the landing (I
wasn't
> even alive yet), but remembering that we have landed.
    Ah yes, but it was still a nice memory...  :)
> Damn...try this:
> http://tinyurl.com/34weg
   Thanks! Amazing images. Almost PoV-like.
>... I don't know if
> > it was magma, it could have been anything native I guess, but I
> > wouldn't know what.
> Technically, magma is the still molten stuff under the crust. It
becomes
> lava when it leaks out onto the surface, and some form of igneous
rock
> when it solidifies. Solidified lava is often called just "lava
rock".
> What you describe sounds like some kind of obsidian (volcanic glass)
> rich lava rock.
> >    I found many shell fossils too, if that's a clue?
> Shells are found in sedimentary rock, lava rock is igneous. Though
it
> could be from lava that flowed into sedimentary rock, or sedimentary
> rock formed from ash and volcanic debris falling on a body of water.
> Perhaps beach sand partially melted by lava? (That would explain the
> glassiness and the shells.)
Lava rock is what someone else called it back then too - I'd forgotten
that. Yes, it was very 'glassy' and would break cleanly, so I also
like the melted beach sand theory too - I guess that it actually
happens somewhere on earth.
    ~Steve~
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: <chr### [at] tagpovrayorg>
> http://tag.povray.org/
Date: 25 Apr 2004 01:14:22
Message: <408b492e@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message
news:4089a790@news.povray.org...
> St. wrote:
> >  Yes, I used to walk our defunct railway lines when I was younger,
and
> > believe that I found samples of magma - I'm not sure, but that was
> > what I was told. It was a dark substance with a golden
> > sheen/iridescence to it, but it definitely looked molten and was
round
> > in shape when solidified. It was very 'glassy', and would break in
> > half very cleanly, leaving a very reflective surface. I don't know
if
> > wouldn't know what.
> Interesting! Where did you live when you were younger? Was it near
any
> volcanic activity?
    Near Swindon, Wiltshire? No, I don't think so. ;)
   The aggregate was probably imported, but from where, I wouldn't
know. One of the other 'stones' that was common, was a very 'spongy'
looking mineral, very light in weight with zillions of holes and
bubbles in it - I've no idea what that was, but probably an indication
of intense heat too.
   Another one was a beige coloured solid stone that smelled of
sulphur - I really liked this one, but it was the wildlife that I was
looking for that really interested me, lizards, mice, slow-worms, etc.
  The fossils were great too. There were plenty of "Devils Toenails",
with which I would scare the life out of my sister...
 ~Steve~
> Respectfully,
> Dan P
Date: 25 Apr 2004 05:27:05
Message: <408b8468@news.povray.org>
Among other things, Alain wrote:
> Albedo is the fraction of the total light, from low infrared to the
> hardest UVs, faling onto a celestial body that is sent back into space.
> Depending on the caracteristics of the surface, the body can be more
> reflective along prevelieged directions, but the amount of incident
> light won't chage it. Taking the moon closer to the sun, like at the
> same distance as Mercury, will have no effect on it's albedo, altough it
> will looks much brighter if you are to look at it from the same distance
> as you look at it now.
OK, If you say so I believe you.
BUT, from other scientific courses and past experience I've learnt that
things are often not so simple. Sometimes it is convenient to express
quantities as quotients between other quantities, so that you have a number
which will, hopefully, remain constant. Sometimes this number is constant
only in a certain range of conditions (for example, the "rate constant" of
chemical reactions is not constant, it changes with the Temperature; the
"absorption coefficient" of Lambert-Beer's Law is constant in a range of
concentrations, but not outside it).
So, I believe this could well be the case of albedo. Maybe, given the set of
conditions usually found in the solar system, we can take the fraction of
the incident radiation being reflected as constant for a given body. But
this doesn't mean it *has* to be constant, it could change with extremely
high or low light intensities. I believe this is a valid concern, given the
way the real world behaves.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 25 Apr 2004 05:30:37
Message: <408b853c@news.povray.org>
Huh?
Date: 25 Apr 2004 12:36:19
Message: <cjameshuff-254D59.12351425042004@news.povray.org>
In article <408b492d@news.povray.org>, "St." <dot### [at] dotcom> wrote:
> > Damn...try this:
Pretty realistic, huh?
Oh, wait... ;-)
Well, obsidian is usually formed from the lava itself, from flows rich
in silica, not from sand melted by it (though underground quartz may be
the actual source). It's just the combination of glassy rock and shells
that made me think of that possibility...shells aren't likely to stand
immersion in lava for long, but a lava flow onto a beach may cool
quickly enough to preserve them.
Date: 25 Apr 2004 12:41:17
Message: <cjameshuff-EDFF7C.12401225042004@news.povray.org>
That was probably pumice, formed from lava containing a lot of dissolved
gasses. It can often float due to its low density. It's often used as an
abrasive, either ground into a powder or as solid blocks.
Don't know what that was...but native sulfur is often yellow-amber in
color, that might have been an impure form.
Devil's Toenails...trilobites?
Date: 25 Apr 2004 13:04:47
Message: <408befaf$1@news.povray.org>
> Huh?
Yep; strange to think that way, I know, but that is a truth!
(Please don't bring up black holes either -- we aren't modelling those)
Respectfully,
Dan P
Date: 25 Apr 2004 17:48:46
Message: <408c323e$1@news.povray.org>
Dan P nous apporta ses lumieres ainsi en ce 2004/04/25 13:04... :
>> Huh?
Receive visible light, absorbs it and transform it to heat, re-emit it
as thermal infrared light. Energy in = energy out.
