POV-Ray : Newsgroups : povray.binaries.images : Kotoji again [117 kb jpeg] Server Time
4 Aug 2026 22:41:40 EDT (-0400)
  Kotoji again [117 kb jpeg] (Message 11 to 16 of 16)
Subject: Re: Kotoji again [117 kb jpeg]
Date: 7 Apr 2004 20:45:52
Message: <4074a0c0$1@news.povray.org>
Looks very nice. The surface of the chip would probably be at least a
slightly different color, probably lighter, not having been as weathered.
Date: 8 Apr 2004 08:20:35
Message: <40754393$1@news.povray.org>
> Other changes:
> Pigment function to distribute the leaf colours in the
> overhang, more variety of leaf colours.
I think the leaves have a much better "depth" to them now, very nice.
> There's still something not quite right about the darkest
> shadows on the lantern, could it be I need to up the
> recursion_limit from 1 to 2?
Do you have an ambient setting on the lantern, I've found having that having
it too high gives artificial looking shadows.
> Anyway I hope you think it's a significant enough
> improvement to merit a re-post.
Yep definitely.
Date: 8 Apr 2004 12:07:51
Message: <407578d7$1@news.povray.org>
"Bill Hails" <bil### [at] europeyahoo-inccom> wrote in message
news:40748065@news.povray.org...
> "Chris Johnson" <chris(at)chris-j(dot)co(dot)uk> wrote:
> > Very nice! I must say I rather like the way the water looks in the
> > distance - you can get that kind of blurred effect in longer exposure
> > photographs.
> Thanks. I'd better point out again (I did in my first post of this WIP,
> but not in this one) that the trees in the bg are a photo. It's cheating
> really and I'd hope to model them in any final post. The water is
>     texture {
>         pigment { rgbt 1.0 }
>         normal {
>             bumps 0.008
>             scale 0.16
>             // turbulence 0.5
I'm always a big fan of averaged normals in a normal map for water. or a
height field built from a pigment_map of the same patterns... this will give
me a good excuse to post one of many works-not-quite-in-progress-anymore.
I love the leaves, though like others said, a little more variation in
brightness or translucency would look great.
The texture on the foreground tree could use some work. It's a little flat
looking. Other than that, it's looking really nice.
-ross.
Date: 8 Apr 2004 15:57:59
Message: <4075aec7@news.povray.org>
> give me a good excuse to post one of many
Right, I haven't tried that. I was thinking of a large-scale bozo
pattern to modulate between 2 different normals, to get the effect
of wind rippling different areas of the lake.
yes, I'll work on that.
I was wondering when someone would notice :-) it's one of the simplest
textures in the picture, I only got away with it because it's so dark.
> -ross.
Thanks for your comments.
Bill Hails
Date: 8 Apr 2004 16:01:39
Message: <4075afa3@news.povray.org>
Right, I was also thinking of using an isosurface with the same pigment as
the lantern used as a noise function to get a rough surface to the
chip.
Bill Hails
Date: 8 Apr 2004 16:04:10
Message: <4075b03a@news.povray.org>
Felbrigg wrote:
>> Other changes:
> having it too high gives artificial looking shadows.
it's:
#local F_Lantern = finish {
    ambient 0.05
    diffuse 1.0
    specular 0.3
    roughness 0.05
maybe I should just drop it to 0.0
> Yep definitely.
Thanks.
Bill Hails
