![](/i/fill.gif) |
Christoph Hormann wrote:
> The snow is indeed the weak point - i played with the idea of a
> subsurface scattering version but this scene is not fast enough and the
> geometry is not that good to show the scattering anyway.
Well, SSS will have made it a christmas card for next year... :)
> The problem i have with the skylight macro is that it does not offer
> much control over the colors. I used a different light color for the
> sky than for the light source to have more freedom in that part.
By "not much control" you mean really "no control at all", isn't? I
think this is a "feature", the main feature for a sky model, IMHO: I
don't have to think on the colors. Of course, you can always ignore
SunColor and use whatever you want for a concrete artistic effect. I
tried for example using a blackbody between 2000 and 6500 K, depending
on the altitude, and it also works nicely.
> Another thing is of course that the use of a mesh for the sky is
> certainly not the best solution - although it is of course the only
> viable one with standard POV. A feature to have image_maps based on an
> internal array (or an ascii hdr file format) would be useful for this.
Yes, the mesh is a bit slow to generate when you need great detail on
the sky, to avoid seing the triangles. I hope Phillipe will have the
time this year to add the save/load feature for the mesh.
Regards..
Jaime
![](/i/fill.gif) |
![](/i/fill.gif) |
You have quite a bit of control over the sky appearance with the
Current_Turbidity and Intensity_Mult parameters. But still it is
somewhat limited - there is no difference made between dust turbidity
and fog turbidity for example. I agree that it's a nice thing to have a
light setup you can use without thinking and that works reasonably well
then but for a scene that needs a lot of work otherwise you usually want
to have more control on the sky as well.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
