POV-Ray : Newsgroups : povray.binaries.images : WIP Boat02 (85 Kb) Server Time
4 Jun 2026 06:45:02 EDT (-0400)
  WIP Boat02 (85 Kb) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: RE: WIP Boat02 (85 Kb)
Date: 19 Jan 2003 11:02:18
Message: <3e2acc0a@news.povray.org>
> Nice picture.
> How did you model the hull?
The hull has been modelled with Hamapatch.
First I tried to do it all by myself, but coudn't
get the right shape.
So I went to http://www.suurland.com/
in search of blueprints that I could use in Hamapatch
(using background image feature) to ease modelling
work and get the right size of the model.
I also found other blueprints at:
http://www.compumarine.com/
I made the hull following a blueprint, and when I got
a boat hull shape, I modified it so it fitted more with
what I think would be the shape of an antique boat
(Leonardo was born in the XV century).
Then I exported the hull model to .mdl (Moray)
and I scaled it to fit the paddle wheels' mechanism
(that is CSG).
Bye
Txemi Jendrix
http://www.txemijendrix.com
Subject: Re: WIP Boat02 (85 Kb)
Date: 19 Jan 2003 13:01:49
Message: <opri9dp8q83mw2t5@news.povray.org>
On Sun, 19 Jan 2003 05:45:41 +0100, Txemi Jendrix <tji### [at] euskalnetnet wrote:
> Still a lot of work to do woth the boat but as it is a WIP ;-)
If you want the construction to look a little more traditional, you could
take a look at this URL:
    http://www.cullisonsmallcraft.com/skylarkpage.htm
Notice the overlapping planks and the narrow frames inside.  Do a search
for "lapstrake"
for more examples.  Of course, you'd have to generate the hull a different
way, probably.
For a modern edge-glued stripper version, look here:
If you changed your texture you could make it look like strips.
Bob Bagwill
Date: 19 Jan 2003 15:34:52
Message: <3e2b0bec$1@news.povray.org>
> Bye
> Txemi Jendrix
Fascinating to see this come to life.
Date: 19 Jan 2003 16:56:34
Message: <3e2b1f12@news.povray.org>
opri9dp8q83mw2t5@news.povray.org...
> for "lapstrake"
> way, probably.
First, thanks for the link.
I think I'm gonna leave the hull as it is.
Surely I'll go for a "overlapping planks" look, but, as it is made
with hamapatch, I can end with an uv-mapped mesh with bump
maps for that..
Been there.
That's what I'm gonna do. Thanks for your comments.
> Bob Bagwill
Txemi Jendrix
Date: 19 Jan 2003 16:58:17
Message: <3e2b1f79@news.povray.org>
3e2b0bec$1@news.povray.org...
I'm glad you're enjoying it ;-)
Txemi Jendrix
Date: 20 Jan 2003 10:42:39
Message: <3e2c18ef$1@news.povray.org>
"Txemi Jendrix" <tji### [at] euskalnetnet> wrote in message
news:3e2a2d3b@news.povray.org...
Nice design and colors. The front needs a lot more detail, but I'm sure
you've got that planned already.
 -Shay
Date: 20 Jan 2003 17:48:32
Message: <3e2c7cc0@news.povray.org>
What's the gear ratio? To me, it looks impossible to operate at a
comfortable RPM, especially if you start from rest.
Date: 20 Jan 2003 18:37:34
Message: <3e2c883e@news.povray.org>
3e2c7cc0@news.povray.org...
From www.museoscienza.org\english\leonardo\barca.htm
"Leonardo envisaged the driving paddle wheels of a boat being about 90 cm
long. The wheels intended to magnify the oarsmen's strength were designed as
being about 60 cm in diameter, and fitted with 16 cogs that engaged with a
sprocket wheel of about 15 cm in diameter fitted with 12 cogs. According to
Leonardo's calculations - leaving aside all mechanical and nautical
difficulties -, with a driving wheel making 50 rpm the boat would have
sailed at 50 miles per hour."
Hope this helps ;-)
PS: It's obvious that Leonardo was an optimist.
Bye
Txemi Jendrix
Date: 20 Jan 2003 18:41:26
Message: <3e2c8926@news.povray.org>
Thanks, and yes, you are right, I'm working on it.
Bye
Txemi Jendrix
Date: 21 Jan 2003 04:10:22
Message: <3e2d0e7e$1@news.povray.org>
3e2c883e@news.povray.org...
> Bye
Lol he was indeed :)
mmm let's see if we can let aside some others little but ennoying
difficulties: eeeeeeer gravity? time arrow? light speed limit?
Leonardo, come back we need your help!!!!
Marc
