POV-Ray : Newsgroups : povray.binaries.images : it's HDRI-tiiimee :) Server Time
4 Jun 2026 09:58:01 EDT (-0400)
  it's HDRI-tiiimee :) (Message 11 to 14 of 14)
Subject: Re: it's HDRI-tiiimee :)
Date: 29 Dec 2002 05:06:27
Message: <Xns92F370B614C60raf256com@204.213.191.226>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in
news:3e0e6579$1@news.povray.org
> "Slime" <slm### [at] slimelandcom> schreef in bericht
> news:3e0e6159$1@news.povray.org...
>> > but if the radiosity-algorithm takes ior's into account, high
>> > enough radiosity-settings should produce accurate caustics, no?
>> Correct.
> but does it take IOR's and reflections into account?
AFAIR no, same as it ignores specular/phong :( maybe it will could be done
in Pov 4.0 ?
Date: 23 Jun 2003 09:56:41
Message: <3ef70719@news.povray.org>
can you tell me the material of middle ball ?
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3e0d1dde@news.povray.org...
> Just a slightly adjusted version of the demo-scene included with MLPov.
> First image is the POV-Ray-version, second image is a post-processed
> version.
> Here are some more tests: http://sad.studentenweb.org/hdri/
> cu!
> ZK AKA SaD
> http://www.povplace.be.tf
> "Wake up! Time to die."
Date: 23 Jun 2003 12:02:06
Message: <3ef7247e@news.povray.org>
"ilker yigit" <ilk### [at] 2noktacom> schreef in bericht
news:3ef70719@news.povray.org...
I dont believe I changed any materials, but I'll check.
This is the material I used:
  pigment { color rgb 1 }
  finish { ambient 0 diffuse .8 reflection {0,.1 fresnel on}
   irid {.1 thickness .5 turbulence .5}
  interior {ior 28}
cu!
ZK AKA SaD
"Begin the unnecessarily slow-moving dipping mechanism!"
Date: 23 Jun 2003 13:32:04
Message: <3ef73994@news.povray.org>
Thanx for your reply. But i try this code but result is not some your
material.
What is wrong ?
#include "rad_def.inc"
global_settings{  max_trace_level 30
radiosity{ Rad_Settings(Radiosity_IndoorHQ, on, on)   }}
  location  <0.0, 2.0, -5.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <-20, 40, -20>
sphere {
  <0, 1, 0> // center of sphere <X Y Z>
  0.5       // radius of sphere
  // scale <1,2,1> // <= Note: Spheres can become ellipses by uneven scaling
  interior {ior 28}
news:3ef7247e@news.povray.org...
>   interior {ior 28}
> cu!
> ZK AKA SaD
